Question about HP Business InkJet 2800 Printer
Troubleshooting hp business inkjet 2800 ps won't print anything except the test page.how do i solve this problem.?
    Problem Solver:
  • 6 Answers
Reinstall ur printer software andb then check
Posted on Oct 28, 2008
2800 HP business inkjet won't stop initializing after installing print heads
BECAUSE IT CANNOT FIND THE PROPER HARDWARE AND INK. TRY TO PRINT A TEST PAGE, AS WHEN YOU FIRST TEST IT.
Jun 18, 2015 | HP Business InkJet 2800 Printer
HP Business Inkjet 2800 firmware PMR2006A
Unfortunately the page you are trying to reach is not a valid page. As an HP tech I searched internal for a firmware update on that model and there isnt one available.
Jun 05, 2010 | HP Business InkJet 2800 Printer
My hp business inkjet 2800 prints blurry even after replacing heads and run heads alignment and cleaning procedure. Is there anything I could do to solve this issue? thanks
Forgive me for asking this, but roughly speaking about 80 to 95% of problems involving ink or toner are resolved by the following:
Are you using a factory new ink cartridge supplied by the manufacturer of the printer?
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
Don
Nov 30, 2009 | HP Business InkJet 2800 Printer
HP Bus Inkjet 2800 won't print 11x17 with Vista
Many people had a similar problem with the Color Inkjet cp1700 B-size printer.
Vista Patch for cp1700 Printer - Fixes Duplex and Large Format Printing
http://h30434.www3.hp.com/psg/board/message?board.id=Software&thread.id=2916&
General page with links to the cp1700 and other printers as well.
Vista Duplex Solution - Back Page Upside Down
http://h30434.www3.hp.com/psg/board/message?board.id=Software&thread.id=43
and
http://www.vistax64.com/vista-print-fax-scan/172813-cannot-print-wide-format-hp-cp1700-2.html
Another solution that worked for some people was installing the hp deskjet 9800 printer driver.
It appears what you need is a patched .gpd file for the BI 2800.
Try emailing Bob Headrick, who has done these patches. (Thanks Bob)!
Be sure to put Vista and Large Format Printing 11x17 in the subject line.
bobh@mvps.org (or see his profile for email address)
Bob Headrick, Microsoft MVP Printing/Imaging
You'd think between HP and MS, they'd have this working right out of the box.
Did they think people would buy a B-size printer so they could hook it up to Vista and then not want to print mainly B-size documents?
They would have had happier customers if they would have included B-size support but left out A-size!
Amazing!
Good Luck
Jun 05, 2009 | HP Business InkJet 2800 Printer
Error message on HP 2800 business inkjet, message reads 1% ink left on brand new cartridge
View the user manual here. http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c00449611/c00449611.pdf
go to page 60 and follow the instructions for replacing the ink cartridge, remember to have the printer on when you do.
Then go to page 62 and allign the print head automaticly following the instructions it gives.
This will re-callibrate the ink level on the printer and should read correctly for you.
Thanks
CompuFirm
May 27, 2009 | HP Business InkJet 2800 Printer
Hp business inkjet 2800 will not print cyan although have replaced cartridge and run all onboard diagnostics. hp troubleshoot shows no problem yet printer will not print
You say you replaced the cartridge but did you replace the print head. If you fully lift the cartridge cover you will see a row of print heads. The Cyan print head is C4811A. Try replacing this.
or
If you feel lucky you can run the print head cleaner diagnostics. The print head may simply be dirty or clogged.
Apr 04, 2009 | HP Business InkJet 2800 Printer
HP BUSINESS INKJET 2800 SERIES OUT OF THE BOX WON'T PRINT BLACK
Usually this happens when the black cartridge is out of ink or when it is damaged.
Try to print with a new black cartridge
Dec 12, 2008 | HP Business InkJet 2800 Printer
Sounds like your driver is sending A4 size documents, and you've got Letter in the drawer. When you do that, it runs out of room on the Letter-size page, since A4 is a tad longer, and has to continue onto a second page. Margins being what they are, the second page is usually blank.
Hope that helps.
Jun 20, 2008 | HP Business InkJet 2800 Printer
Printer prints blank pages
Do print calibration so it will solve problem for it.
Apr 14, 2008 | HP Business InkJet 2800 Printer
HP Business InkJet 2800 Printer Logo
140 people viewed this question
Seeker5211
Seeker5211
