Question about Dishwashers
Kenmore 17539 ultras wash dishwasher does not fill up with water.
I have a kenmore ultra wash dishwaher stock no. 17539. All the functions work, but does not fill the wash tub with water. The motor seems to be turning. The resistance on the fill valve, capacitor, and drain motor is normal range. It cycles to all the program mode with no water in the tub. The water supply is on and the pressure sufficient. Whats wrong here?
heatman101
  • 43501 Answers
SOURCE: Ultra Wash Dishwasher Stock #
The PF code means power failure...
This could be a loose connection anywhere in the power to the main board...it could be either the hot or the neutral wires...
Check all of the connections in the power wiring to the dishwasher...
Check the wiring harness to the main board and also to the door switch...
It could also be a loose wire in the circuit breaker panel that is allowing the voltage to drop on the startup of the motor...
Bottom line is that this could be very difficult to track down...
Comment back if you have anymore questions...
heatman101
Posted on Feb 09, 2011
markevans
  • 148 Answers
SOURCE: Kenmore Ultra Wash Dishwasher wiring diagram
if unavailable on line, contact mfg's parts and you should be able to order it.
also, they likely do not make the unit. the sears may be able to tell you who made it. that company would be able to get you a diagram. just make some phone calls.
Posted on Dec 21, 2007
SOURCE: Kenmore Elite Ultra Wash Dishwasher - top rack arm not spinning
Hi: I just posted a similar problem, but found a solution. After taking the arm, etc. apart (and verifying no blockages), I thought maybe the lack of water pressure was being caused by the fact that there are TWO holes for the top spray arm (higher and lower rack setting) on my model. ie. that water was being forced out of both holes, causing a drop in water pressure, which was causing the top spray arm to stop spinning. I plugged the unused hole with a wine bottle cork (to keep the water from spraying out the unused hole), and voila, it now works.
I wish all appliance fixes were this easy...!
S
Posted on Apr 21, 2009
  • 83 Answers
SOURCE: Kenmore Ultra Wash dishwasher
check and see if you are getting ac 110 volts to your water vave when trying to start the unit. if no power check your breakers and /or the incoming power to your dishwasher if they are ok and show 110 voltage coming to the unit then you probably have a control board or touchpad problem which would need a little more detailed check out.
If you do have ac 110 to your water valve then you may just have a bad water valve. Because the washer has to fill first. Hope that helps!!
Posted on Jul 02, 2009
SOURCE: My Kenmore Ultra Wash III dishwasher 665.1584990
My Kenmore Ultra Wash III won't open the water valve. The pump starts and the heater turns on, but no water. Any ideas?
Posted on Jun 06, 2010
Kenmore ultra wash dishwasher
Bad triac on control board. Replace control board.
Aug 23, 2014 | Kenmore 24" Built-In Dishwasher with Ultra...
Kenmore Ultra Wash Dishwasher door won't open
It seems most likely door latch stock and you going to need buy new door latch as for stock one most likely you hsve to forceit to open and replace it with new one
Dec 09, 2013 | Kenmore Dishwashers
Kenmore ultra wash diswasher top rack not cleaning
see please the next video for your fix it: God bless you
Jul 21, 2012 | Kenmore 24" Built-In Dishwasher with Ultra...
My kenmore ultra wash dishwasher wont fill with water i checked the float it seems ok what could be wrong
Here is a tip that will help you to find out why water will not come into the dishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
Mar 27, 2011 | Kenmore Dishwashers
My Kenmore Ultra Wash II fills with water but doesn't spray.
i would suspect water mains problem, not enough water getting to the machine sometimes inlet get clogged with lime.adrian,,,,
Jul 13, 2010 | Kenmore 17024 Built-in Dishwasher
Jun 29, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
Smelly dishes from Kenmore Ultra Wash
If you post the model number of your dishwasher plus its approximate age (in years) I can help more.
But the most common cause is a weakening pump motor. On many dishwashers, the wash pump motor is also the drain motor. Replacing that motor / pump assembly will solve the problem. While you are replacing the pump, check the heating element to confirm that it is not shorted out or broken.
For now, add a cap full of bleach to the water _after_ the initial dishwasher fill cycle ends and the wash cycle begins. White vinegar would also work, but this will not fix your problem.
Good Luck!
May 04, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
Dishwashers Logo
32 people viewed this question
Top Dishwashers Experts
Owen Barnes
