Question about Dishwashers
My bush dishwasher is coming up with error code E1
SOURCE: hoover dishwasher error codes
Hi we have a Hoover DT999 and according to the manual for that machine error E1 is water inlet tap turned off
Posted on Dec 23, 2007
  • 110 Answers
SOURCE: lg dishwasher lds 5811st E1 error code
Hi Chaz,
The impeller breaks on the motor shaft. The motor still turns, but the impeller doesn't, so it doesn't pump water. Because the machine senses there is no water pressure from the pump, it shuts down & displays E1 (it thinks there's a water leak, due to no pressure)
Unfortunately the motor/impeller is only available as a complete assembly
Hope this helps
Col
Posted on Dec 11, 2008
  • 423 Answers
SOURCE: What is an E1 error code for an LG Dishwasher? Model LD12AW2
Please check at both ends of the drain hose and confirm that you do nit have a leak. Also, please confirm that water is not leaking directly under the dishwasher.
If you are certain that you do not have a real leak, check the impeller (under the mesh filter in the sump area beneath the lower dish rack) is not damaged and is firmly in place.
The E1 error code is a Leakage Error, detected by the motor spinning faster than it should if the unit is filled with water.
Please report back with what you find. Good Luck!
Posted on Mar 30, 2009
  • 423 Answers
SOURCE: LG Dishwasher making grinding noise then blinking E1 code 10 minutes later
Well done by resolving this problem. The other way to avoid the siphoning problem through the drain hose is adding an air gap valve/connector (available at any hardware store). You can use it even if you don't have a garbage disposal in your kitchen sink. That will assure that you have the proper height of the drain hose.
Hope this helps!
  • 254 Answers
SOURCE: I have a LG 4821st
This code is for a "leak" that the system's computer is detecting. Let me guess...Does the system make a groaning noise like it's not getting enough water? Here's what you should do...First, pull the lower dish rack out and thoroughly clean the filter. If you're easily able to remove the filter, do so and continue to clean. Also look for any debris under the filter assembly. A final step to completely make sure all of the water lines are clear of debris, you'll need to remove power, pull the washer out of the cabinet, and then (carefully) tip it on its right side. Next, remove the two plastic assemblies that are on the left side and remove them from the dishwasher you will need a vice grips to remove the hose clamps from behind them, you will also need to remove the round circular water intake plastic disk that is on the inside of your dishwasher on the left hand side right in the middle of the left wall and clean them. Once the water can run freely through these plastic parts you will get a good water flow and you should be fine. It's a bit of a task, but not too difficult. To minimize this from happening in the not-too-distant future, you may want to ensure that you're not putting too many dishes in that contain heavy, solid food debris. Also, I recommend using the Finish brand tablets instead of heavy liquid detergent. It not only is more cost-effective, it also does a wonderful job and won't build up in the water lines of your nice dishwasher.
I hope this helps and please feel free to ask me if you need any further assistance!
Take care and have a WONDERFUL holiday season!
-Jason
Posted on Dec 14, 2010
Weve just bought a new bush dishwasher we used it for the first time and it come up with E1 when i opened it the water had not drained
The E1 code indicates a fault with either the machine or the way outlet hose is installed.
If it was installed by a third party give them a call.
If you installed it yourself have a good look at the user guide and see if the placement of the hose could be improved. Make sure there is not a 'dog-leg' bend in the hose. If the error code persists call the supplier as it might indicate a fault with the machine.
Jun 25, 2016 | Bush DW12TFE3 Dishwasher
1E error code
Search Results
    E1 error on LG Dishwasher - YouTube
    ? 2:40
    www.youtube.com/watch?v=2qcwAyHI9ik
    Aug 24, 2012 - Uploaded by 62spindrift My fix for E1 error on LF Dishwasher. ... Dishwasher Pump and Motor Assembly Replacement - LG ...
Sep 30, 2015 | Dishwashers
E1 error code on omega dishwasher
? 2:40
Aug 24, 2012 - Uploaded by 62spindrift My fix for E1 error on LF Dishwasher. ... Maytag Maxima steam Washer has F8 & E1 error code - Pressure sensor & no water detected ...
Aug 28, 2015 | Dishwashers
How do i fix electrolux dishwasher when error code 1 is flashing
Hello friend, thanks for your post!
I see your Electrolux dishwasher is displaying an "E1" error code. "E1" stands for a leak detected which means your dishwasher base has detected a leak. If you can't see a leak you may want to perform a reset on your dishwasher you can do that by disconnecting the power from your appliance for roughly ten minutes.
If that does not correct the issue you may want to seek assistance from a technician. They would need to come out to diagnosis and repair your dishwasher. I hope this information has been helpful. -Matt
Oct 03, 2014 | Electrolux Dishwashers
My dishwasher wv9-6s a bush brand is displaying error E1 can someone helpe please
E1 error is the water is not filling quickly enough or restricted or low water pressure or not filling at all.
check your faucet is turned on, if it is turn it off and take the water hose off. There is a small strainer or filter in the line at the dishwasher end, ensure it is clean and clear.
May 22, 2014 | Dishwashers
Error code E1
Hello simonhall900 - Typically error code E1 indicates that the unit has detected a leak. At this point, I highly recommend connecting with a professional to accurately diagnosis the leak and to properly assist with the repair(s).
Mar 01, 2013 | Electrolux WT30H240DU Dishwasher
E1 code comes up on the display, but how do you solve this? ...
E1 Leakage error. Cause : water leakage in hose connections. Water is leaked by damages.
Feb 18, 2010 | LG 24 in. LD-12BW5 Free-standing...
Hope this helps!
Oct 22, 2008 | LG LDF6810ST Stainless Steel Built-in...
Hoover dishwasher error codes
Dec 18, 2007 | Dishwashers
Dishwashers Logo
913 people viewed this question
Top Dishwashers Experts
