Question about JVC SP-PW100 Subwoofer
Jvc compact stereo system model ca-fss57
The unit was working just fine then was packaged up in it original box and stored for a month or so while we moved. plug it in and it just keeps popping a fuse that is labeled F1000. its not the wall power i checked it in another house on the other side of city and same thing. it is a 2.5 amp 125v fuse. i have tried plugging in the unit with the transformer unplugged and the fuse does not blow, in fact a relay clicks and the unit wants to power up but wont because of missing voltages i assume. i replug transformer and as soon as i plug into wall power zap its done. i guess what i need to know is what voltage should be comming out of the transformer,it is a white and orange wire or maybe there could be another solution that you the expert may have and or another path to go down...i am kinda stuck without having a repair manual
snakehead
  • 1074 Answers
SOURCE: JVC KD-AVX2 new installation will not power up
your set could have damage after powering it up and connecting speakers.have the tech repair it.good luck.
Posted on Apr 01, 2007
  • 3 Answers
SOURCE: Stopped working
I had a similar problem with a jvc 8040. when I replaced the fuse it became very obvious that the b1560 output on the center channel was blown (smoke and sparks, always a dead giveaway). I haven't fixed the center channel yet but simply unplugged the center channel board and removed it from the unit. Now everything works fine except of course the center channel. Pre outs still operate just fine so a slave amp could be used for center channel power, or you could just go and buy a marantz amp; I did and then I realized that I was lucky that the old jvc quit.
Posted on Jan 30, 2008
  • 7 Answers
SOURCE: JVC KD-G396 wont Play any cd or mp3 PLEASE HELP
take it back
Posted on Dec 14, 2008
SOURCE: JVC receiver Auto muting?
I had the same problem. I had bad antennae connection. I re-did the antennae conection and it fixed it. HOpe this will work for you...
Posted on Mar 26, 2009
josetejas
  • 300 Answers
SOURCE: Connecting iPod to JVC KD-LH810!?!
Hi, KD-LH810 has no option for external input. Refer to the picture attached. It is only front and rear line outputs. Don't get disappointed. Buy the accessory cable KS-U100 and you are set. This info is from the installation manual.
Posted on Jan 19, 2010
Codes for JVC rm-sr558u universal remote control
Codes are stored in the remote. If you are using a JVC remote, no "programming" should be necessary.
Oct 17, 2015 | JVC HX-D7 DVD Compact Stereo Audio / Video...
Jvc stereo model mx-kc4 cd tray won't open make loud noise
sounds like theres something keeping it jammed in might be one of those pull hard and hope jobs :) good luck
Mar 24, 2012 | JVC MXKC4 360-Watt Compact Component Audio...
JVC CA-D661T compact home stereo stopped playing burned CDs (it used to play these same CDs, now it doesn't recognize them). Everything else works, including playing of original CDs. Any ideas?
You can try cleaning the laser lens. You can do this using qtips and rubbing alcohol. Be sure you are very gentle though or you could risk scratching the lens which would completely ruin the laser assembly.
Mar 21, 2012 | Car Audio & Video
HX-D7 DVD Compact Stereo Audio / Video System with 5 DVD Changer Shelf System: my jvc was working fine but all of a sudden it sto...
Hello
this could be a power fault, but first check the power plug if it is in contact with the power socket and if it is then you have to open the back cover of the system to check the fuses if blown resistor,capacitor and transistor with the use of a multimeter to check for back component and if bad replace faulty ones.
Then power on to confirm, if not on then take it to the manufacturer or a skilled personnel to handle it
May 17, 2010 | JVC HX-D7 DVD Compact Stereo Audio / Video...
Need to set clock on jvc compact component stereo amp
How do I set the clock on my jvc compact disc audio system. model # KD-G110
Oct 21, 2009 | JVC MXKC4 360-Watt Compact Component Audio...
Open the speaker unit
You probably need to remove the speaker itself, the cabnet is probably sealed.
Hope that fixed Ya...
Geno
Mar 29, 2008 | Audio Players & Recorders
How to unlock protected mode on a jvc 5 disc cd changer?
cheack the speaker wireing.if thats not the pro i sugg the repair shop your unit could have over heated.
Jan 06, 2008 | JVC HXD7 5-disc Home Stereo Theater System...
JVC SP-PW100 Subwoofer Logo
94 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
