Question about Savin Office Equipment & Supplies
I have a savin c9145 and cannot send or receive faxes for the last 3 days.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 72 Answers
Press the "on hook" icon and listen for a dial tone.
Posted on Nov 12, 2013
SOURCE: Faxing
Make sure that you have settings to RECIEVE FAX.
Go to start on your Desktop. Click on All Programs. When window opens, click on accessories. When accessories window opens, click on COMMUNICATIONS. When the Communications window opens, click on Fax. When the Fax window opens, click on FAX CONSOLE. When the FAX CONSOLE window opens, click on RECEIVE FAX NOW.
You might have to wait until your telephone/fax machine, rings and then click RECEIVE FAX NOW if it does not work automatically.
The person who is sending you a Fax might have to inform you they are sending a Fax to you right now.
Hope this is helpful to you. Good luck.
Posted on Oct 17, 2007
Ajkill
  • 2035 Answers
SOURCE: Lexmark 7350 all in one
Before you begin
To pinpoint the cause of the issue, please record answers to the following questions:
Can a fax be sent or received?
Can a fax be sent, but not received?
Has the fax function ever worked in the past?
Any error messages may also help to narrow down the cause of the issues.
Print out the following:
- a settings list to view the current fax settings
- a receive log if there are issues receiving faxes
- a send log if there are issues sending faxes
- an activity log if faxes cannot be sent or received.
Initial checks
If the fax option has worked in the past and does not do so now, check that the same connection is being used and that it still works.
Check to see if any configuration settings have been changed that could have affected the fax settings.
Faxes cannot be sent/received:
If you are using a digital line, you need an analog card, an ISDN adapter, or an ADSL filter in order to send faxes.
If a PBX is being used, an ISDN Adapter/ADSL filter will not be used as these are supplied within the system. (A PBX is normally used within a company to share a small number of public lines among a large number of private ones to save on cost.) For instructions on configuring the X6100 Series machine with a PBX, see How and When to Use the PBX Option.
Check the phone line (without the printer):
Test the line by connecting a phone directly into the phone port.
Check for a dialing tone.
If you cannot hear a dialing tone, try another phone cable. Once you can hear a dialing tone, you know that the phone port is live and working.
Make sure the RJ11 cable is not damaged.
Check that the printer is accessing the dialing tone correctly:
Press the Options button on the operator panel five times until ON HOOK DIAL is displayed.
Press Select. You should hear a dialing tone.
If you can't hear a dial tone, make sure that the speaker volume is set to High. (Go to Fax, press Options eight times until SPEAKER VOLUME is displayed, then use the plus or minus buttons to change the setting to HIGH. Press Select.)
If there is still no dial tone, unplug the power cable and the phone lead, then plug them back in and try again.
Faxes can be sent but not received:
Connect the Lexmark All-in-One directly to the phone port. IMPORTANT: Do NOT connect any phones to the EXT port.
Make sure the Fax receive mode is set to answer the fax after 3 rings. (Press the Fax button on the operator panel and then press Options three times until ANSWER FAX WHEN is displayed. Change the settings using the - or + buttons as appropriate.)
Faxes can be received but not sent:
Make sure that Country Code is set correctly:
Press the Fax button on the operator panel and then press Options 15 times until Advanced is displayed.
Press Select.
Press Options 13 times and then press the + or - button until the right country is displayed.
Press Select.
IMPORTANT! These tests must be carried out with NO EXTENSIONS, i.e. phones or answering machines, connected to the EXT port on the All-In-One.
Posted on Mar 11, 2008
agnelkj
  • 210 Answers
SOURCE: my fax sound but dont received any fax
hi,
check whether the auto answer is turned on...
either u have the button on the front panel of the printer itself "auto answer" or u will have it in the fax menu...
press the menu button and scroll down to fax setup or advanced fax setup, make sure the auto answer option is turned on....
thanks and regards
agnel
Posted on Mar 19, 2008
SOURCE: Brother MFC 8860DN: Send Problems
Update the firmware and it does support SMTP-AUTH
Posted on Apr 15, 2008
SOURCE: Unable to send fax
I called HP and they had a free solution promptly.
Thanks tho
Posted on Apr 09, 2009
Customer with Brother Intelifax 4100e cannot "handshake" with our Savin 816 multifunction. The Savin is receiving hundreds of faxes daily, and is also used to scan to document management, etc. ...
I have a fax line with packet8 which is a voip carrier. I am having trouble receiving faxes. I was told to change the baud rate on the fax to less than 9600. I don't know how to do it on my brother intellifax 4100e. can you advise?
Thanx,
Mar 22, 2011 | Brother IntelliFax-4100e Fax
Savin 3750 Fax error code 0549H call for service . What is it
Why do i receive parts of the papers being faxed the gives me an error code. then later sends them again?
Jan 26, 2010 | Office Equipment & Supplies
Want to know how far back in time can I get a verification of fax
The last 50 transactions are held in memory (send and receive)
Aug 21, 2009 | Brother IntelliFax-2820 Laser Fax
Wish to print outgoing fax log date/time/number
I don't think there's a log you can print but you can do the following. Not quite what you want, but better than nothing...
You need to set the fax confirmation option to log faxes before you send anything. The default option is off, so you won't be able to get a fax log for anything you've already sent unfortunately.
1. Press Setup
2. Press 2 then press 1. This displays the Print Report menu
3. Select Fax Confirmation
4. Press c00424037.gif to highlight one of the following, then press OK
Off Does not print a fax confirmation report when you send and receive faxes successfully. This is the default setting.
On Fax Send Prints a fax confirmation report for every fax you send.
On Fax Receive Prints a fax confirmation report for every fax you receive.
Send & Receive Prints a fax confirmation report for every fax you send and receive.
May 06, 2009 | HP Officejet 5610 All-In-One InkJet...
Unable to send fax
Thanks tho
Apr 08, 2009 | HP Officejet 4315 All-in-One Printer
Error code 634 on Panafax UF-770
The receiving fax machine is turned off or not functioning. Try calling your cell phone.
Do you have a DSL phone line?
Nov 21, 2008 | Office Equipment & Supplies
Storing numbers in speed dail for the Savin Fax 3699
1. Press "USER TOOL"
2. Press 1.
3. Press 1 again
4. Enter 01
5. Press a free Quick Dial key
6. Enter the fax number.
7. Press [Name]
8. Enter name for this Quick Dial
9. Press [OK]
10 Press [OK] again
11 Press [PrevMenu]
12 Press [PrevMenu] again
13.Press [Menu]
14.Press[Exit]
Aug 18, 2008 | Office Equipment & Supplies
Need to reset savin 3740 fax to factory defaults
Found documentation of Ricoh's website. They are the manufacturor of Savin products. The default access code is 2222. Entering this allowed me to get into the network settings and change the IP scheme.
Jul 25, 2008 | Office Equipment & Supplies
FAX BROTHER mfc 885cw
This is obviously a phone company issue or a defect in GE fax machine keypad or circuitry. Last but not least turn off your machine at night. Turn it back on when you wake up.
Jun 15, 2008 | Brother Office Equipment & Supplies
I can neither send or receive faxes
hi 003 - Recording paper jammed when feeding from the 3rd cassette. Remove the jammed paper. (1) Open the Printer Cover. (2) Remove the jammed paper. (3) Slide out the Paper Cassette. (4) Remove the jammed or wrinkled paper and reload the recording paper into the paper cassette. Caution: Make sure that the paper is set under the clips of the Paper Cassette. You can load about 500 sheets with standard weight paper (20 lb. or 75 g/m2). good luck
Feb 23, 2006 | Panasonic Panafax UF-885 Plain Paper Laser...
150 people viewed this question
Top Savin Office Equipment & Supplies Experts
quennie732
Adorjani Laszlo
Don  Farrell
Don Farrell
Are you a Savin Office Equipment and Supply Expert? Answer questions, earn points and help others
