Question about Keurig B60 Coffee Maker
Keurig B60 will not stay on
Menu displays "Not Ready" without a back light. Press power button, display lights showing "Not Ready," within 3 seconds, hear relay click and display goes dim as if power is shut off.
  • 1,511 Answers
Turn off Auto Start. see manual page 17 for indstructions.
Posted on Feb 07, 2014
SOURCE: Love my Keurig B60. Bought the B70 with lager cup
You have to remove teh 5 screws from the bottom plate on the unit and they there is a small translucent corrugated hose fastened with a small ty-rep. Remove this hose and simply drain the stainless tank to the sink and replace the hose over the barb, slide the ty-rap back in place and it is EMPTY. Takes ten minutes start to finish. Phillips screwdriver and needlenose pliers are all that is needed.
Posted on Dec 03, 2010
shannon_m_pe
SOURCE: I just bought it Keurig
I have the same one. fill side tank with water and close down place to put coffee. it should **** up some water. Than in a few it will say ready to use. Hope this helps....
Posted on Jan 26, 2009
SOURCE: My Keurig B60 will not brew.... it is like the
won't brew
Posted on Dec 16, 2009
SOURCE: New Keurig B60 stopped working!
I had the same issue. I now believe that there was some "vapor lock" type issue. Mine would say the same thing, and i could hear the pump running, but the water level was not changing in the reservoir. I unplugged it, removed the reservoir, let it cool, then tipped it on its back for a few minutes, then on each side. Truthfully I was trying to see if there was some kink in the tubing. Couldn't find a problem, so set it back up and it runs great again.
Posted on Jan 02, 2010
  • 28 Answers
SOURCE: My Keurig B60 just stays flashing
Try removing the water reservoir tank, the replacing it. Make sure the reservoir tank is seated properly. There seems to be a problem with this model with the water reservoirs not seating properly and causing the unit to stop working or shut off. Hope that helps! Best of luck...
Posted on Feb 07, 2010
Why does the keurig menu button not work
www.keurig.com/.../brewer...support/frequently-asked-questions
Try here.
May 23, 2014 | Keurig B60 Coffee Maker
Keurig B60 coffee maker won't draw or heat and "not ready" stays on
Handel not in positive position to start brew process.
Jan 26, 2013 | Keurig B60 Coffee Maker
Keurig B60 error message "not ready" and ""turn off auto off"
Button on Auto needs to be depressed and turned off. See manual.
Oct 10, 2012 | Keurig Special Edition B60 Coffee Maker
My Keurig coffee maker won't turn on. When I press the power button, it starts to make some noise, and the display reads "Not Ready to Brew" and then it continues to make the same noise for a...
sounds to me that you have a bad pump. Try calling keurig customer service,1-866-901-2739.Be ready with your model number, found under the drip tray on the machine. If your machine isnt to, to old, bet they will send you a new one. Just makes better sense to have a happy customer. Let me know how you make out.
Mar 04, 2011 | Keurig B60 Coffee Maker
I set the auto off on my new Keurig and it has now locked me out. The led display is flashing "Not ready, auto off set". Any button I press does not allow me into the menu to change settings....
Sorry to read about your problem, I hope this helps you out.
unplug the unit, that should solve your problem..then re program
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
Dec 25, 2010 | Keurig B60 Coffee Maker
Our Keurig B60 displays "NOT READY Auto off set" and does nothing. What can we do to bring it back to life?
Press the off/on switch and poof on the machine and then check. If that is not helping then try this procedure as follows:--- 1. Simultaneously press and release "small mug" and "medium mug". Immediately afterward press "menu" 3 times. (Menu is the black button under the display screen .) You should see a time 6:09 on your screen.
2. Press "menu" once. Your LCD screen should say Brew 0:00.
3. (I messed this step up like 10 times and had to unplug the machine, then replug it and start over at step one. You have to unplug if the LCD displays "auto ____". If it continues to flash "Not Ready" and "Brew" then you can just keep trying step 3). Press and hold "medium mug". While holding "medium mug" press and release "menu". Immediately after pressing "menu" (while still holding "medium mug") press "small mug". Release "small mug" and "medium mug" at the same time. This entire thing needs to be done very quickly. as soon as you release "menu" go to "small mug" and release both buttons quickly.
4. Unplug the machine (do not turn it off). Wait for 3 seconds or so. Plug it back in, turn it on and follow the instructions for priming.
--------- If this instructions also not helping then try this, instead of holding the medium cup while pushing and releasing menu .you simutaneously push and release medium cup and menu and then medium cup and small cup and then check out. Thanks. keep updated for any more query.you can rate this solution and show your appreciation.
Aug 28, 2010 | Keurig B100 Coffee Maker
My Keurig B60 does not run at all. The screen comes on and says: Not Ready and also says auto off set. The cup lights do not flash. I cannot get the menu to come on. Unplugging it and plugging it in...
Not sure if this will help, but I had the same problem over Xmas. This was posted 8 Jan, and I cut/pasted it here. Sounds complicated, but it's not. Just print it off instead of trying to remember it! I'd be interested to see if you had the same 'codes' as I, and if your machine had hot water when it ran... I have not done anything since that post...
Patient: Keurig B60
Symptom: "Not ready" light is on. Reservoir is filled and needles are clean, so problem is not user related.
Internet search yeilded some hope for another Keurig machine. While turned off, simultaneously press and release the small and med button, then menu three times. You get into a programming/diagostics menu. As you scroll (via the menu button) mine says Ready 602, Brew 265, Autooff 099, Set 007, Set/set 099, Descale 099, and Menu 000.
While at 000, press the med button but do not release. Press and release menu and immediately press small, then let go of small and med together. Pump runs and water is circulating, but is cold. Not sure if it should be cold (just a test routine, etc) or whether the heater is blown or something more troublesome.
Anyone have any ideas/experience with this information (I have no problem in ripping the machine apart if I have to. It can't be that complicated!).
Jan 31, 2010 | Keurig B60 Coffee Maker
Keruig Coffee maker (B60)
Keurig alluded to the fact that it is the heating element that buring out and causing these problems.
Oct 25, 2008 | Keurig B60 Coffee Maker
Keurig B60 Coffee Maker Logo
309 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
