Question about Maytag PYE2300AY Electric Dryer
Maytag Dryer Tstat wiring
Have Maytag Part# 306911 need correct wiring diagram(what color wire to which prong?)
  • Anonymous Feb 27, 2009
    earth on case no earth on connector
  • Anonymous Mar 18, 2014
    need color picture of wires going into the motor and were on a GE DBXR453GT3WW gas dryer
Have maytag dryer dg309 put 3 new coils in the dryer but no flam glowing start up but no flam what next
please and thanks
Posted on Dec 29, 2011
  • 240 Answers
I believe that this part is a thermostat. If im not mistaken, it shouldnt matter which wire goes on which prong. Think this is a reversable thermostat. It should have just 2 prongs correct? Jim
Posted on Sep 09, 2007
Looking for a color diagram to wire my Maytag MDE4000AYW from a 3 prong to a 4 prong. Any help is greatly appreciated
Here is a tip that will help you with changing your dryer plug. Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Aug 06, 2011 | Dryers
Maytag neptune dryer
Hey white to white, black to black red to the multi colored pole, and the green one is the ground wire,, . I done that before,, lol,, good luck ,, thanks
Oct 05, 2008 | Maytag Neptune MDE6700A Electric Dryer
Just brougth used maytag neptune dryer.model MDE3000AYW
If you are connecting a power cord with a 3-wire configuration, you match the corresponding wire colors from the power cord to the wires on the terminal block in the back of the dryer. The correct color-code is as follows:
RED - HOT (120VAC)
BLACK - HOT (120VAC)
WHITE - NEUTRAL (0VAC)*
*There should be a ground strap or ground wire connected to neutral at the terminal block in a 3-wire configuration.
NOTE: If the wires are not color-coded, the outer two wires (Left and Right) are the HOT leads. The center conductor is Neutral.
If you have any questions, you can refer to this link for further explanation:
http://www.fixya.com/support/r3575913-installing_a_220_vac_appliance_cord
This explains the difference in 4-wire and 3-wire configurations. I hope this helps you.
Mar 09, 2010 | Dryers
Need to change power cord on maytag dryer from 3 prong to 4
Always disconnect electricity before beginning this process.
All the 4 wire cords I have seen are color-coded. The white wire goes to the middle terminal, the green wire goes to any screw you can reach that goes into the metal case of the dyer. The red and black go to the outside terminals of the block and while it doesn't matter which color goes to which terminal I usually follow the color code of the interior dryer wiring that already exists. Good Luck.
Oct 04, 2009 | Maytag SDE3606A Electric Dryer
How to change a 3 prong to a four prong on a mde4000 Maytag Neptu
the red wire to red black wire to black white wire to white and disconect the ground wire to the white lug and conect the green wire to the screw that is on the other end of the ground strap you disconected from the white lug
Dec 24, 2008 | Maytag Neptune MDE4000 Electric Dryer
MAYTAG DRYER ELECTRICAL CONNECTION
how do you change a 3 prong plug to a 4 prong plug when the colors dont match on the wires to the dryer?colors on the wires are red white black and green. colors on the terminal of the dryer are a black and yellow tied together a white in the middle and 2 blues tied together. this is a maytag atlantis dryer. thankyou chad....
Jul 30, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Need to change the cord on my Maytag MDE6000AYW from 3 prong to 4 prong. The (4) prong cable has black, white, green, red cables. Which colored cable connects to which terminal inside the dryer?
BLACK and RED are 110-120VAC each. WHITE is NEUTRAL - does not carry power. GREEN is GROUND. The Black, Red, and White Wires should connect to the terminal block & should correspond the colored wires already connected to the block from the machine. The Green wire should be grounded to the equipment chassis. I hope this answers your question.
Jul 13, 2008 | Maytag Dryers
Installing washing machine motor P/N 35-5022, need wiring schematic to hook up to machine internals
Is there a white or black connector that clips on the motor switch? it should be an easy unplug and plug the new motor in.
I dont of any Manufacturer that uses single wire connectors any more.
Are you sure you got the correct motor?
Apr 22, 2008 | Maytag Legacy Series Top Load Washer
The black or brown connection block on the motor should be color coded to match the harness. If not you will need to remove the control panel and find the service guide sheet. This will give you the wiring diagram for the whole machine.
Jan 10, 2008 | Maytag Performa PAV2200
Maytag PYE2300AY Electric Dryer Logo
605 people viewed this question
Top Maytag Dryers Experts
Marvin
Marvin
Sal De
Archie Ferrarini
Archie Ferrarini
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
