Question about Rowenta Irons
Dz9030 no power
I have a rowenta iron, i have switched on and there is no power, how do i go about fixing it. i have taken the back off but there is no signs of it burnt out. please help.
  • brian_housem
    brian_housem Feb 25, 2012
    checked that and its fine, also changed the fuse.
    Sergeant:
  • 167 Answers
I think its main internal connection maybe lose
Posted on Feb 23, 2012
SOURCE: Rowenta Effective Iron - Model DX1700-U1 NRB01-01
I just drop it a few times on the floor really hard a few times and then it gets hot again!!!
Posted on Sep 14, 2008
SOURCE: rowenta dx6700
The wire inside the cord is likely torn ant it connects and disconnects as it is moved back and forth. This happened to me too. I just need to find where to get a new cord.
Posted on Jul 31, 2008
wizzard8955
  • 18 Answers
SOURCE: iron leaks water from the back end of the base
This problem is the way that rowenta seals the water tank. If the iron is disassembled and the seal is properly put on it will not leak,, however this seal is a silicone based product and not just an off the shelf gasket. I have sealed and repaired some using a high temp silicone
Posted on Mar 06, 2009
SOURCE: new rowenta effective iron that doesn't heat and steam correctly
Don't use distilled water-I had same problem. It was built to use regular water. Solved problem
Posted on Mar 08, 2009
omaromid
  • 332 Answers
SOURCE: I have a Rowenta DX1700. The iron will only stay
The problem is with the iron's thermostat which controls the temperature of the iron
Posted on Feb 07, 2010
Rowenta steam iron fell down and top part is broken can it be replaced
Rowenta Iron Parts - eReplacementParts.com
www.ereplacementparts.com/rowenta-iron-parts-c-180639_180647.html Fix your Rowenta Iron today with parts, diagrams, accessories and repair advice from eReplacement Parts! Worldwide ... DE0554 Rowenta Steam Iron Parts.
Aug 08, 2015 | Rowenta Irons
My rowenta steam iron fell down and top part has broken any chance it can be replaced
I GET NO HEAT IT JUST STOPPED
U got a busted thermal fuse or the thermostat switch is not functioning.
If u have a knowhow in replacing and adjusting the thermal switch, u could fix it by urself!
Better check also the power cord, mostly flat irons main prob, if there are no lights on ur iron, it means internal probs!
Better take that iron in ur friendly hungry technician to fix that!
Dec 02, 2010 | Rowenta Professional DE880 Iron
My iron will not consistently get HOT.
Hi.
The clicking sound is given by the solenoid that turns on and off the iron element. Heating cannot be turned on, and the iron keeps clicking without making any heat.
The cause of the problem can be a defective solenoid, a broken contact, or an open thermistor (it will turn the solenoid back on). The oven must be taken apart and tested to find the fault.
Regards.
Mar 02, 2010 | Rowenta Irons
Rowenta surfline iron turned off and won't go back on.
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Jan 27, 2010 | Rowenta Surfline Iron DE-333 Iron
My rowenta effective will not heat up.
This is a problem with a lot of Rowenta irons. It is the auto shut off that is not working properly and the only way to fix it is to have it disassembled and the switch hardwired to be on whenever the iron it plugged in. It is a thermal metal switch and it just stops working and then the iron will not turn on and the yellow light blinks.
Dec 15, 2008 | Rowenta DG5030 Iron
I have a Rowenta 1700 iron. The iron has started to act up. When I plug the iron in it just flashes & does not get hot. It is like it is in the stand by mode when you leave it on & don't iron...
Oct 14, 2008 | Rowenta DZ1700 Iron
Iron leaks water from the back end of the base
Sep 26, 2008 | Rowenta Power Duo Iron
Rowenta dx6700
Sep 23, 2007 | Rowenta DX6700 Iron
Irons Logo
63 people viewed this question
Top Rowenta Irons Experts
Henry  Thomas
Henry Thomas
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
