Question about Dishwashers
Adjust door spring tension on a viking dishwasher
5 Suggested Answers
  • 209 Answers
SOURCE: Door Tension
just about the most difficult job to do on a dishwasher, not normally a job for the home mechanic, i am an appliance engineer of 20 years and often shy away from jobs like this,
there is often no adjustment, the hinges are sprained, more often that not by people either putting weight on the door to stand back up, or children climbing on to get higher
the only thing i think you can do is to check the springs are in place and nothing is broken or just come off that can be put back?? sorry
Posted on Oct 15, 2007
SOURCE: Dishwasher detergent door spring
I ordered and received the new Bosch dishwasher detergent door, but do not know how to repalce it!
Posted on May 15, 2008
SOURCE: adjusting the door on a neff dishwasher
I have the same problem with my newly installed Miele integrated dishwasher. The door does not stay open when you are trying to load dishes. I heard that there is an adjustable internal mechanism to adjust the tension on the door. But, I am still working on solving my problem.
Posted on Aug 17, 2008
aborcass
  • 2651 Answers
SOURCE: Door Tension Adjustment on Electrolux Dishwasher
you should be able to remove the lower acess panel, and the tension springs are on both sides, cant really picture how to adjust tension( font or back), but there should be enough room to get a flashlight and you hands under there to make the adjustment
Posted on Oct 26, 2008
Door lift spring came off how to put it back on
the spring will be at the lowest tension when the door is in the raised position
there should be an adjustment at one end where the spring is attached to adjust the ease to lift the door and hold it open so if thee is loosen that adjustment off and with the door held up ,refit the spring
Oct 22, 2015 | Hobart Used AM14 Pass Thru Commercial...
How do I adjust the springs on the door of a Frigidaire dishwasher Model # FDB24?
Springs run down both sides of the dishwasher from the door hinge to the back leg area of the frame at the bottom leg area. You adjust the spring/door tension but moving the spring to different holes in the frame area. Going one direction in the holes will loosen the door, going the other direction will make the door tighter.
Mar 26, 2015 | Frigidaire Dishwashers
Bosch dishwasher door tension
Most dishwashers have big springs that run front to back at the bottom sides of the body. These are the door springs. Tension is adjusted by moving the spring to one of several holes in the frame. One way will give you less tension on the door the other way will increase it. If the dishwasher is new, why not call service and let them deal with it. Should be under warranty.
Mar 24, 2015 | Bosch Dishwashers
Adjusting door spring tension on a Bosch dishwasher
underneath are 2 L-brackets with the springs attached. Pull those out (with the door closed) and tension will be released. Shorten the strings attached to the springs and reinsert the L-brackets.
Nov 18, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
The door on my dishwasher will not close
There are a few problems that can occur with the diswasher door assembly. These usually involve the latching mechanism, the door seal, the counterbalance spring assembly or the hinges. 1) The door latch plate can occasionally become out of alignment. Some door latch plates are adjustable, some aren't. If yours is adjustable, try loosening the retaining screws and repositioning the plate. It's trial-and-error, so have a lot of patience. If this doesn't work, then the latch needs replacing.
2) A new dishwasher or a newly installed door seal can be difficult to close for a while until the seal softens and compresses over time. You can try adjusting the latch, if possible.
3) If the door feels unusually heavy, there could be a problem with the counterbalance spring assembly. These counterbalance assemblies allow the door to open and close easier and are held by two springs. On some dishwasher models, holes are positioned in line so you can re-tension the springs by moving the spring hooks to other tensioning holes. If any of these springs break, they will need to be replaced as a pair.
4) The door hinges might be bent. They can seldom be adequately fixed and should be replaced.
hope this helps
Nov 24, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Dishwasher Door Tension Adjust on Electrolux EDW5500DSS
I just adjusted my Electrolux DW springs. The springs are on the bottom sides near the back. They pull on cables that hold the door (via pulleys). The springs can be moved to five different holes to change the tension, but I needed to pull the DW about 2/3 out for side access.
Oct 26, 2008 | Dishwashers
Oct 26, 2008 | Indesit 23 in. DV62 IX Built-in Dishwasher
Door Tension
Oct 14, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwashers Logo
Top Dishwashers Experts
