Question about Kenmore Washing Machines
How do you check to see if the lid switch is good or bad?
    Problem Solver:
  • 16 Answers
The buzzer will continue to sound even if you close the lid and set a wash cycle.
Posted on Feb 23, 2012
Can a lid switch on a maytag bravos quiet series 400 model MVWB800VU0 be bypassed for testing, lid switch passes continuity tests but machine won't finish a agitate cycle?
the switch can still be bad manually even though it shows good electronically. How ever if its bad you seldom get some agitation then goes off unless ur opening and closing it? once its bad u get nothing, hence ur problem may be elsewhere. but Im u pics on how to jumper it, I myself think ur problem is in the timer perhaps sticking? if u have no agitation then check the water pressure switch and the door switch
Jun 22, 2015 | Maytag Washing Machines
Why is the agitator not working or not spinning?
Here are a few problems, The lid switch may be bad ( to check it )Raise the lid, find the switch. remove the 2 wires from switch and tape them together, but do no let them touch any steel or you will get zapped. If the agitator works fine, The switch is bad. #2 drive coupling on motor to agitator is bad, #3 clutch is bad, Check out the switch first. If the lid switch is bad it will not send current to start the motor ( safety precaution ). Good-Day!
Aug 29, 2014 | Kenmore Washing Machines
My ge wash machine wbsr1060t2ww will fill with water but then does nothing
You have a bad lid switch. If the lid switch or lid switch circuit is open the motor is not going to run. Trace the lid switch wires and look for any breaks or loose connections. If that circuit is good, then you have a bad capacitor on the motor circuit or the motor is bad. Here is a link to the motor kit should you need it.
Nov 01, 2012 | GE Washing Machines
WATER GOES IN BUT WILL NOT SPIN ROUND
check the lid switch. if its bad it will not spin. and also check for a broken drive coupler, from motor to the transmission. to check lid switch. pull the lid switch out. tape the 2 wires together, if it works fine then youve found the problem. good-day !
Apr 20, 2012 | Washing Machines
Is not spinning just filling with water
check for a bad lid switch. just open lid and hold switch in, if tub will not spin its the lid switch. here is a few other things to try. belt broken ( if it has one ) drive coupling, clutch, good-day ! HOPE THIS HELPS YOU!
Nov 20, 2011 | Kenmore Washing Machines
The machine does not perform last spin cycle
check lid..either the lid switch is bad or the lid switch actuator which is made into top...when in final spin push down on the right hand top part of lid,,,if it starts replace part needed,,,good luck
Sep 12, 2011 | Avanti Top Load Washer W797
I have a Kenmore (110-22642100) that will fill, agitate through wash cycle and that's it. It will not drain or spin.
check the lid switch,if it's bad this will happen,you can set the timer to spin and push it in,open the lid and push down on the lid switch with a screw driver,also when you push down on the lid switch and let it up you should hear a clicking sound,if you don't hear a clicking sound the switch is no good.part number 3949238 and it's around 35 dollars........http://www.youtube.com/watch?v=pbQU-NlkHcw......copy and paste
May 04, 2011 | Kenmore Washing Machines
Does not drain and go into spin cycle. Checked outlet for 110v power supply, and good. Also ran an extension cord from laundry room into an interior outlet to double check and still to no evail.
most likely the lid switch is bad, listen for a click when closing the lid, try pushing down on the lid, if it works replace the lid switch, if you hear no click try a pen or screwdriver etc to push down the switch lever.
Feb 11, 2010 | Kenmore Washing Machines
Washer will not spin
not much info. from u . few things it could be. a bad lid switch, a bad pump a clogged pump.when you open then close lid u should hear a click if so thats good. if no click your lid switch is bad. if you here a click lid switch good look elsewere, pump clogged , or could have a bad pump,timer, motor..coupling,belt
Oct 07, 2009 | Kenmore 2.1 cu. ft. Portable Top Load...
MY WASHER WILL NOT AGITATE OR SPIN, HOWEVER, IT WILL STILL FILL WITH WATER.NO SOUND FROM THE MOTOR.WHAT COULD THIS BE
Check the lid switch for continuity.
Remove the hoses on the pump and check for a blockage in the pump.
If lid switch is good and no pump blockage it is either a bad timer or a bad motor start switch.
Mar 23, 2009 | Maytag Performa PAV3200
Washing Machines Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
