Question about Baxter OV300E Stainless Steel Electric Oven
How to enter the program code - Baxter OV300E Stainless Steel Electric Oven
  • lou francioni Feb 23, 2012
    i need to add more settings
    Sergeant:
  • 167 Answers
Which program....?
Posted on Feb 23, 2012
F71 code on double oven
These error codes are normally make-specific.
Replace the word 'double' with the 'make' and press enter.
F71 code on double oven Google Search
Aug 07, 2017 | Ovens
Tip
Reset Miele steam oven - enter hidden programming mode
My Miele was stuck in a loop repeatedly asking for more water, and then I got it stuck in a descale loop. I called Miele to ask them how to 'reboot' the factory settings, but all they would suggest is me booking a visit from an engineer. Expensive and pointless.
However, I then managed to find a video of someone entering the hidden Programming Mode for another model, and the same button combination worked for me.
Press and hold the timer button (the one with a bell picture on it) and then press and hold the power button at the same time, and let go of both together at the same time.
Then press the timer button alone 5 more times, and on the 5th press, hold for a few seconds. From there I played around with a few options until I found one that reset and restarted the descaling. I've linked to the video where he enters Programming mode after 2 minute mark.
DG4082SS Steam oven
on Apr 13, 2018 | Miele Ovens
How to find error codes
press the back key twice.
press back + enter at the same time.
type 9-4-2-8 (text the word "what")
then enter
press the faults soft key.
Mar 23, 2013 | TurboChef TORNADO Electric Oven
Ihave a minder shed alarm (4 button model) the batteries ran out and i dont know how to reset it any1 help!
Factory Code settings 1234, To change the factory code press button 1 for 2 seconds, wait for 2 beeps, now enter your new 4 digit code, you will hear a further 2 beeps to confirm the new code. If the battery is removed the code will revert to the preset code(1234)
Nov 05, 2011 | Stoves 720EF Electric Double Oven
I had to pull my oven out of the wall and ever since I did that, I get a message that says "Feature Not Available" on any button I hit. Is there a reset button or something?
It's an error code that will not go away until a technician resets it. Quote straight from the manual :
"The oven may detect a fault during programming or during operation. If a fault is
detected, the message "Fault detected - press power to clear" or "Fault detected -
press enter to try again" may appear. Follow directions in the display. If the fault
reappears or does not clear, call an authorized servicer or the toll-free number in the
display.
If the same operation is attempted before having the wall oven repaired, the message
"Feature not available" will appear. The feature will remain inoperable until service
is obtained":
Mar 15, 2011 | Jenn-Air 30 in. Pro-Style Electric Single...
How to adjust the toasting time on the preprogram
your better off going back to the factory setting. Call turbo chef but here you go this is how you re-program the thing. Remember i took the time to give you these directions. Please take the time to leave a review
PROGRAMMING
Edit Mode
The EDIT MODE enables the operator to manually alter
recipes and the cook cavity temperature (CCSP).
To access EDIT MODE:
1. Simultaneously press the UP and DOWN keys.
2. When prompted, enter the access code “9” and
then press the ENTER key.
Altering a Recipe
Most NGC (Tornado) oven models contain 128
unique recipes. The display shows two (2) pages each
with eight (8) recipe groups. Each recipe group contains
eight (8) recipes. See Figures 11 and 12.
To alter a recipe:
1. Enter the EDIT MODE (see page 16).
2. Enter the access code “9” and set the CCSP. The
screen displays the first set of eight (8) recipe
groups. To access the second set of eight (8)
recipe groups, press either the UP or DOWN key.
3. Select the recipe group that contains the individual
recipe you wish to alter. Select the recipe you
wish to alter by pressing the soft key corresponding
to the recipe item. Figures 11 and 12.
4. Use the UP and DOWN keys to navigate through
the recipe settings. Use the keypad and ENTER key
to alter any of the following three (3) parameters
(see Figure 13):
a. Cook time
Total duration of the cook cycle. Enter the
desired time and press ENTER.
b. IR element temperature (IRSP)
The temperature the lower radiant element
will maintain during the entire cook cycle.
Valid temperatures are between 500ºF (260ºC)
and 1150ºF (621ºC).
c. Events 1…6
Use the keypad and ENTER key to enter values
for % TIME, % AIR, and % WAV.
o Sum of % TIME for all events must = 100.
The operating system will not allow a
combination of events not equal to 100%.
o The % AIR parameter is valid between 10
and 100%.
o The % WAV (microwave) parameter is valid
between 0 and 100%.
5. After making changes, test the recipe by
pressing the TEST soft key. Once the oven has
warmed to the CC set point, press the TEST
soft key again to begin the test cook.
6. Once satisfied with the recipe, press SAVE to
permanently store changes.
7. Press the BACK key until exited from EDIT MODE.
Jan 14, 2010 | TurboChef TORNADO Electric Oven
How to program the controller hobart hr7e
You'll be required to register, but there is a printable manual available here. http://www.hobartservice.com/Manuals/
Hope this helps
Aug 12, 2009 | Hobart HR7E Electric Single Oven
TURBOCHEF C3 AND TORNADO
what setting. the code to get into diagnostic area is 9428.
Nov 22, 2008 | TurboChef TORNADO Electric Oven
Baxter OV300E Stainless Steel Electric Oven Logo
128 people viewed this question
Top Baxter Ovens Experts
Lawrence Oravetz
shannon816
Are you a Baxter Oven Expert? Answer questions, earn points and help others
