Question about Cell Phones
How to calibrate touch screen on a Panasonic DP-C406
Touch screen stops working
common problem. might need tho be calibrated. turn off front power switch and then the rear main power switch. turn on the front switch, hold down energy save button and copy button, turn on rear switch and continue to hold energy and copy buttons until the screen displays an X in the top left of the display. immediately release the buttons and touch the X with a pen/pencil/pointed object. the X will move to the center and them to the bottom right of display. touch the X as it moves position. the copier will reboot and the display may work. if not, replace the touch screen. part #n2baayy00771.
Sep 13, 2014 | Panasonic WORKiO DP-C322 Printer
Why the touch screen not displaying
If thr display is visable but not responding to touch, replace touch screen part #n2
Sep 03, 2014 | Panasonic WORKiO DP-C322 Printer
Manual for panasonic DP c305
Are you needing a service manual for this model of machine?
May 19, 2014 | Panasonic 12606 Dp-C265 Dp-C266 Dp-C305...
Problem is the touch donst funcition give me full information about this
You'll need to replace the touch screen Panasonic part# DZTE000044RA
Nov 08, 2013 | Panasonic WORKiO DP-2330 Copier
Calibration for 8060 touch panel
Press and hold down energy saver button and function button together then power on the machine. keep on holding the two buttons the machine will once show screen calibration marker then again show the calibration markers now touch the shown marker it will go to a new place keep on touching the final marker will be at center of screen . after touching it the calibration completes
May 05, 2011 | Panasonic Workio DP-3530 Copier
Driver compatible with vista
(Laungage : English)
OK : Available
�� : planned.
�� : Currently undergoing compatibility testing
N/P : Not planned. OK��Update on Mar 31, 2010
Model 32 bit
(English)
64 bit
(English) Others
DP-MB300/320/340/350 GDI
DP-MC210 GDI
DP-8060/8045/8035 GDI
DP-8032/8025 GDI
DP-8020/8016 GDI
DP-6030/4530/3530 GDI
DP-6020/4520/3520 GDI
DP-6010/4510/3510 GDI
DP-3030/2330 GDI
DP-3010/2310 GDI
DP-1820/1520/1515 GDI
DP-190/180 GDI
UF-9000 GDI OK N/P
UF-8100/8000/7100/7000 GDI
UF-7950/6950 GDI N/P N/P
UF-8200/8300/7200/7300 GDI
DX-800 GDI N/P N/P
DX-600 GDI N/P N/P
UF-6100/6000/4100/4000 GDI
UF-6200/6300 GDI
DP-3000/2500/2000 GDI N/P N/P
DP-1810/1510 GDI
DP-150/135/130 GDI N/P N/P
UF-990/890/790/590/490 GDI N/P N/P NOT PLANNED
UF-895/885 GDI N/P N/P
UF-595/585 GDI N/P N/P
UF-880/770/560/550,DF-1100 GDI N/P N/P
DX-2000/1000 GDI N/P N/P
FP-D605/455/355/305 GDI N/P N/P
DP-C406/
Apr 29, 2010 | Panasonic PanaFax UF-490 All-In-One Laser...
How do I cancel a print job - Panasonic DP-C354?
Go to controll panel touch the print button on the left bottom, touch print queue, it will ask for password which is 8 zeros. touch print job and hit cancel
Sep 27, 2009 | Panasonic DP-C354 Copier
Touchscreen calibration in ubuntu
The touch screen on these models do not have a calibration setting. They work or they don't. If it not working properly you can try uninstalling the drivers for the touch screen, then reboot. The machine will find the touch screen and reinstall the drivers automatically. Also check for any updated drivers at Panasonic's support site. Then check the connection for the touch screen, the touch screen has a separate connection than the screen, and it may have worked loose or have a little dirt or corrosion built up. If this doesn't work, then I'm afraid that the touch screen may be wearing out, nothing you can do for this.
Sep 01, 2008 | Panasonic Toughbook 28 Notebook
Cell Phones Logo
55 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
