Question about Neff Freezers
Install thermostat in G4343X0GB - Neff Freezers
My freezer is not working and everything looks fine. The light is on but there is no sign of the motor working. Is there anything wrong?
Check the thermostat setting and set it. If not check compressor
Which installed back bottom of freezer its working or not .
May 17, 2016 | Freezers
Kenmore frost free freezer model253.24452100 turns on but does not freeze. The compressor kicks over then stops. What might it be?
Is the compressor still receiving 120VAC when it kicks off? Kenmore Freezer Temperature Control Thermostat 216788000
If not, replace the cold control. If yes, install a URCO410 hard start kit and listen to it purr... Relay overload capacitor URCO410
Mar 22, 2016 | Kenmore Freezers
Why is the pilot light on my ERN7926 frost free flashing?
To Start the Appliance
Allow the appliance to stand for 2 hours after
installation. Plug in the appliance and switch on at the mains
supply. Turn the thermostat control (B) to a midway
setting and adjust the slider control, situated on the
back wall of the fridge section, to a midway position
between "MIN" and "MAX".
The pilot light (A) will illuminate. Leave the appliance for approximately 4 hours for the correct temperature to be reached before placing food inside.
To switch off the appliance turn the thermostat
control to position "?"
After 4 hours, measure the temperature in the refrigerator and freezer. Should be between 2 and 10 degrees centigrade in refrigerator and app. -18 in freezer.
Dado
Sep 07, 2014 | Electrolux Freezers
Chest freezer power light on, run light off and all my food is defrosted. How do I fix it
Take off the service panel and check for the compressor running. Can you place your hand on
it or is it too hot. If it is you might change the relay to the compressor.Take your model no. to your local parts store and they will help you look at the part and exactly where it is located (on the compressor) Easy change out.
If the compressor is not running at all then remove the two wires to the thermostat and plug them
together (They will plug together if you turn one backwards and plug it into the other.)
Make sure you have unplugged the freezer while you are doing this.
Now you have routed around the thermostat.
If it runs then replace the thermostat and youre done!
If not after the relay and thermostat check it wont run then you have a bad compressor.
On the relay ask for a hard start relay for a freezer or ref. at the parts store. They know exactly
what it is. Its even easier to install. Don't be shy to repair this. You can do it or condemn it
Thank you for using fixya
Leo Ponder
Please rate me if this helped.
Jul 24, 2011 | Magic Chef Freezers
Electrolux fridge freezer, Motor never turns off. replaced thermostat, still motor keeps running. The back, top half of fridge freezes over but the temperature remains cool?
dear sir/madam
i think this is thermostat setting problem please make sure freezer,s thermostat nobe (nidle) is in correct position .then see thermostat temperature settings . may be thermostat is not controlling to compressor motor that why it,s running continuously.
hope answer the question,
thank you
please vote!
Sep 02, 2010 | Electrolux Freezers
Freezer thermostat was set at 0 degrees unit went down to -30 degrees. I increased temp on thermostat 3 degrees 3 times each over a 3 day period. The thermostat is not responding. I have the thermostat set...
I would start there. If the thermostat has an off setting, turn it there and see if it goes off. If not, try turning it to it's warmest setting while the box is cold to see if it turns off. To test to see if the relay/ contactor is stuck/bad, kill power to the unit (Unplug or turn off breaker). Disconnect one wire to the thermostat. Restore power. If unit runs, bad relay/contactor. If unit does not run, I'd replace the thermostat. Make sure the sensing bulb of the thermostat is in the conditioned space of the box or in the return air (intake) side of the evap so it can sense the box temp.
Aug 02, 2010 | Nor-Lake KLF7766C Commercial Freezer
Freeezer with no compressor activity
If all fans are running, but not compressor You could try to install 3 N 1 start kit, thats might help 50/50. If it will start compressor - be ready for compressor to go out soon. might work for a year.
Dec 13, 2009 | Kenmore Freezers
Refrigerator/freezer in garage doesn't keep food frozen in winter
Yes there is a solution. You need to install a garage Thermostat Heater. This will trick the thermostat into thinking it is in a warm environment. This article will tell you why this is happening and the solution as I described. Sorry but for some reason I cannot post this as a link. Copy & Paste into your browser. http://applianceparts.wordpress.com/2009/01/12/why-won’t-the-freezer-in-my-garage-refrigerator-freeze/
Dec 07, 2009 | Kenmore Freezers
I want to use one condener unit to cool a freezer and a cooler at two different temperatures, how do I do that? with a head master?
You need to split the delivery and return tubing, then install a solenoid in each delivery tube. The solenoid valve will be controlled or powered by a thermostat in each compartment. You then install a low pressure switch on the suction or return side near the compressor. This will switch the compressor off when both solenoid valves are closed. Hope this makes sense.
Nov 05, 2009 | Freezers
The thermostat is out on my Kenmore 14.8 cu ft freezer
I asked a local repair shop. Just pull ******* the sensor wire and it will slip out of the tube through which it runs. Run the new wire which is attached to the new thermostat thru the same tube. Prior to purchasing the thermostat, I tested with a ohm meter for continuity ( there was none) and jumped the attaching power wires. The compressor ran verifying the problem with the thermostat. Thermostat cost $47.00.
Jun 07, 2008 | Kenmore 14.8 cu. ft. / 419 liter Chest...
Freezers Logo
22 people viewed this question
Top Neff Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Neff Freezer Expert? Answer questions, earn points and help others
