Question about NorStar M7324 Telephone
Need to factory reset a meridian m7324 - NorStar M7324 Telephone
SOURCE: MERIDIAN M7324
Do you know how to program the system?
You will need to log into system programming. Got to lines/trunks and enter your extension. You will see the line appearances to appear only. You need to change those to appear and ring.
If you do not know how to get into programming. Call a professional.
Posted on Jan 08, 2008
SOURCE: Change the time
Depending on the software of the Norstar it is connected to, you would log in to the key system by using Feature **23646 and then follow it up with the administration password.
If this is a pre 1.0 system, i.e DR5.1 do the following. If not, go to the bottom and click on the link and find the manual for the system your phone is connected to. Generally the system coordinator guide will have what you are looking for.
Setting the date
Begin with the display showing
l.Sys speed dial
1. Press [NEXT] (second key from the top on right for a 7310) twice.
2. The display shows 3.Time and date.
3. Press [SHOW] (first key on the top on the right for a 7310)
The display shows the time, for example, Time 01:00.
- All times and dates must be entered using numerals. For
example, February would be entered as “2”.
- The time may be entered in either 12 or 24-hour format. If the
display is in English, and the hour entered is less than
thirteen, the display prompts you to specify “am” or “pm”.
Press [Show] This will open the time change function. Simple rule. If you want to modify a value, press [CHANGE] and you'll get a cursor. Once you're done with that entry, press [NEXT] to go to the Minutes, press [CHANGE] etc...
I have also included how to change the date below.
Press [Next].
The display shows the date, for example, Date 31 Mar 91.
4. Press CHANGE (softkey under screen). The display shows Year: 88.
5. Set the year.
a. Press CHANGE.
A cursor replaces the number on the display.
b. Enter the year using the dial pad.
For example, press a a to enter the year 1990. ?
c . Press [Next] The display shows the month, for example Month: 01.
6. Set the month.
a. Press [CHANGE]
b. Enter the month using the dial pad.
For example, press 02 to enter February.
c . Press [Next].
The display shows the day, for example Dar: 01.
7. Set the date.
a. Press CHANGE
: A cursor replaces the number on the display.
b.” Enter the date using the dial pad.
For example, press 14.
Posted on Apr 09, 2008
TallBourbon
  • 30 Answers
SOURCE: Merian M7324 display name
you would need to get into the admin programming to change the name, have your system admin person make the change for you.
Posted on Jan 07, 2009
consultel1
  • 860 Answers
SOURCE: How can i change the time on my meridian M7324
Programming should be done from the M7310, M7324 or the T7316E set. Administration access code: Feature * * 2 3 6 4 6 which also is Feature * * A D M I N.
If asked for a password enter the same 2 3 6 4 6.
If that doesn't work you may have the newer Compact ICS or the Modular 0x32 control unit which will be Feature * * 8 4 6 3 which is T I M E. Password is 2 2 7 4 2 which is B A S I C or A D M I N which is 2 3 6 4 6.
When in programming just press the next button(lower right arrow) until you see what you want to change. Then press show ( top right arrow) ,then change if you want to change it. If you pass it, press back (lower left arrow)
Example: To change the Time & Date Press next until you see Time & Date. Then show Then Chng Then change again, change it if you need to, Then next again until you see what you need to change. For example; only the hour needs to be changed for day light savings time. Just press next until you come to the Hour. Then Change it. Then press release RLs when your done.
Posted on Oct 28, 2009
SOURCE: Meridian M7324, Mailbox locked, feature 983 not
How can I change the password
Posted on Apr 14, 2010
Tip
Nortel M7324 Manual Download
Download Nortel M7324 Telephone User Card Manual
Have you misplaced your Nortel M7324 Telephone User Card Manual?
Would you like a digital, searchable, pdf version of the Nortel M7324 Telephone User Card Guide?
Follow this link
(& click FREE) to download a pdf version of the Nortel M7324 Telephone User Card manual.
I hope that helps.
_________________________________________
Nortel Meridian 1 Manual Download
on May 04, 2010 | Lands Phones
Tip
Download Nortel Meridian 1 Administration Manual
Have you misplaced your Nortel Meridian 1 Administration Manual?
Would you like a digital, searchable, pdf version of the Nortel Meridian 1 Administration Guide?
Follow this link
(& click FREE) to download a pdf version of the Nortel Meridian 1 Administration manual.
I hope that helps.
Meridian M7324, Mailbox locked, feature 983 not available, #120000 is invalid. Help
Feature 983 defult password is 120000 for 2digit locals and 1020000 for three digit locals and 10020000 for four digit local > Don't use # key
Nov 24, 2009 | NorStar M7324 Telephone
We have Meridian M7324 phones. They are on pulse dialing and need to switch back to touchtone signal.
And did the system default back to 2 lines? It probably lost programming, which will require a system technician or a very good end user to reprogram the whole thing.
Have fun.
Carl
Aug 21, 2009 | NorStar M7324 Telephone
Meridian m7324 - another phone in office - DND - unable to remove
You almost had it right . You need to do this press the feature button then # 85 to remove the DND .
Feb 02, 2009 | NorStar M7324 Telephone
Feature 71 on my meridian M7324
Feature 71 isa link key. It generates a link signal(also known as hookflash, flash, recall, or tap). it can be programmed on your set by entering feature *3 pressing the button where its to be located and entering in feature 71.
I think thats all to know about a link key, hope that helps.
Jan 27, 2009 | NorStar M7324 Telephone
Jan 02, 2009 | NorStar Meridian M7310 Phone
MERIDIAN M7324
Jan 07, 2008 | NorStar M7324 Telephone
NorStar M7324 Telephone Logo
65 people viewed this question
Top NorStar Lands Phones Experts
Oloyede Monsuru
Computer Repairing
Computer Repairing
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
