Question about Cell Phones
Insert sim in this case [ battery connecter ] center pin is positive ,please give me solution
  • Davinder kataria Feb 23, 2012
    Sergeant:
  • 167 Answers
What type of problem you have...?describe briefly
Posted on Feb 23, 2012
2 Suggested Answers
ib_yang
  • 1098 Answers
SOURCE: I put thi pin of
Hi there.
What is the exact message that it is giving you? Is it PUK Blocked? Or PIN LOCKed?
Thanks.
Posted on Aug 22, 2011
How do I use sim card for my hp2730p notebook with windows 8.1?
Insert the SIM. To do that you need to remove the battery. You will notice a tiny little slot. Slide the SIM in completely until it is firmly inserted.
Note: There is no need to disable the PIN. Windows will ask you nicely for it when connecting.
With the drivers installed, one might be tempted to think that a WWAN connection can be established. That may be true for you, but in my case more work was required. Windows would allow me to unlock the SIM by entering the PIN, but after that there was no trace of the mobile broadband module left.
As I found out, the WWAN module was disabled. In order to turn it on I had to install HP's Connection Manager software which adds a tray icon for turning WWAN, Wi-Fi and Bluetooth on or off:
Feb 12, 2015 | HP EliteBook 2730p Notebook
Nokia 2700 insert simcard solution
1. Check if battery is looose......if so insert a 3to4 times folded paper piece at the bottom of the battery
2. clean battery connection by scratching it gently with a blade...specially the centeral one ( it is BSI connection and in nokia it causes insert sim fault
3 Check sim connecting tray check and clean its pins.....if pins have got pressed lift them using oil pin
4. If still u have this problem contact service as sim ic might require replacement
Jan 21, 2014 | Nokia 2700 Classic
Insert sim
As far as I know.there are two possibilities to get this error..
1)Sim card not inserted properly:
Try to insert the sim properly..insert it at the desired position
2)Phone may be locked with a particular network:
If the phone is locked with a particular network then you need to unlock it.You can get the unlock service for your Blackberry 9360 Curve from either your network provider or third party unlocking service provider like, unBBlock.com and remove the network lock. Once unlocked it will work with other networks.
3)Sim Problem:
Mostly this won't be in your case because the sim had been working fine with your previous Nokia mobile and also the phone gives the same error message when you insert other sim cards.
4)Hardware Problem:
There might be some loose connection give it to a hardware service shop and check.
May 01, 2013 | Cellet Blackberry T-mobile Curve 9360...
After charging W350i not recognising SIM says, 'Insert SIM Card'. But the same SIM card is operative in other mobile. How can retrieve Phone contacts? Please help.
make sure if sim reader is not pin damaged or water damaged? if problem persist i think you can connect your device without simcard and copy all data to your pc, then give some repairer to check maybe need to flash (if flash you will lose your data).
or try to put your mobile without battery 2 days and then switch on to see may be this problem solves.with S.E. this problem a normal.
Jun 21, 2012 | Sony Ericsson W350i Cell Phone
Insert sim
Hi
Try removing the Simcard and reloading it again.
Try another Simcard on the phone,could be case of a blocked Simcard.
Solved?
Try hard resetting/master resetting the phone.But be warned though,this will delete your data and third party applications.
  • Press menu
  • Select settings
  • Scroll to phone settings and press OK
  • Scroll to reset settings and press OK
  • Press OK on master reset
  • Select on 'Yes and press OK
  • Enter security code and then press OK.[Default security code is 0000].
Now the phone resetts.
Feb 23, 2012 | LG CF360 Cell Phone
Always insert sim card eventhough the sim card is good and in a demo mode. What can I do?
The sim card IC(filter) might be broken or damage coz it is kind of glass/the pin of the sim case may bend or broken.The only solution is to change these thing.....anyway if you can do just follow the link 1661 sim ic jumper - Google Search
Jul 12, 2011 | Nokia 1661 Cell Phone
Samsung gt-c3510 sim not working {insert sim} plz help me
* try to change another sim card
* check the sim socket if the pins are dislocated or damage
* might be a software problem and needs to program the phone
* might be a harware problem,and needs to replace sim ic or other components related to sim..
in that case,bring it to the mobile service center..
if this is helpful,please rate me.. thanks
Jun 03, 2011 | Samsung C3510 Cell Phone
How i will initialize my SIM card?Should i enter my SIM PIN number?
Hi
Remove the battery from your phone. Slide off the back cover of your phone to get to the battery. Gently lift the battery from its compartment to remove.
Insert the SIM card into your phone. Once your battery is removed, insert the SIM card into your phone. Look at the image on the phone to see how to insert the SIM card correctly. Make sure it is pushed all the way into place.
Replace the battery and turn on the phone. Replace the battery back into its compartment and replace the back cover. Turn on your Nokia 2610 phone, and it should boot up. The name of your wireless provider will appear when your phone is turned on.
Allow time for your phone to read the SIM card. Once your phone is booted up, it will say initializing. This means that it is reading your SIM card information. Once your SIM card is read, your phone will go to the home screen. Your SIM card is now activated, and you should be able to access all of your information.
Please accept the solution if it's helpful. Do get back to us for any further query.
Sep 20, 2010 | HP iPAQ h6315/h6365 Pocket PC
Sim lock
The PIN (personal identification number) or PUK (personal unblocking key) are security features provided by your network service.
The PIN and PUK are provided on your SIM package, and can be changed many times. The basic purpose of these codes is to provide a security.These codes are normally used to prevent your SIM card from unauthorized use.
You can get this type of security by enabling the PIN check option in your mobile phone. If this feature is enabled, the phone requires your PIN each time it is switched on.There may be different solutions for your problem.
If you have not changed the original PIN of your SIM then you can get easily this code from the package that has come with your SIM card. Get these codes from SIM package and unlock your mobile phone.But if you have changed your PIN and now have forgotten it then there is also a way to resolve it. When you give an incorrect PIN three times to your mobile phone it will block your SIM card, then in this case you have to provide a PUK given to you by network provider. And you can get your PUK any time by calling at the help line number of your network service center.
Sep 14, 2008 | Nokia N73 Cellular Phone
Cell Phones Logo
16 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
