Question about Haier 3.5 cu. ft. Chest Freezer HNCM035E
My frezzer is thawing out how to reset it - Haier 3.5 cu. ft. Chest Freezer HNCM035E
How do you reset a frigadaire freezer
Time for a new freezer. The lights are telling you power is on and temperature not being reached. No amount of resetting will alter this.
Apr 11, 2012 | Frigidaire Freezers
Frezzer won't go below -10
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
May 19, 2010 | Whirlpool 19.6 cu. ft. Upright Freezer...
Refrig/freezer not cooling/freezing
your gonna have to let thr fridge defrost buy shutting it down because it soundsm like you have either a build up of ice it the vents in the back of the frezzer unit also check to see if you can hear the fan working in the frezzer if not that would be you main problem
Jul 26, 2009 | Freezers
Having temp problems
for a freezer would suggest a thermostat problem easily replaceable if you follow the removal of the old thermo.use temperature gauge to set to the required degree after instaling new thermo
May 21, 2009 | Freezers
Bosch Frost Free Frdge Freezer Icing Up
Switch off fridge. Put a pedistal fan in front blowing into the cabinet and leave until all ice has defrosted. Locate the drain hole in the back of the freezer compartment, try to defrost ice which blockes up about the first inch or two of this pipe. If water does not run through you need to force it through with a turkey baster. This should sort your problem. ratemeplease
Mar 12, 2009 | Freezers
Frezzer door no loger shutting
check tro make sure the holders ore on correctly, and or you dont have the drawers in wrong positon, some are slanted behind to accomidate slant of freezer section.
Jan 10, 2009 | Freezers
Frezzer not running, light still on
well if the frezzer needs a new compressor is still under the manufactures warranty for five years you can have it check out it might just be a timer or overload , thermostat if you are not handy with tools just call a tech to give a diagnosis
Oct 29, 2008 | Freezers
Frost free frezzer
The drain is probably clogged. Use a pipe cleaner to clear and then use a turkey baster and force hot water through. Follow with a weak bleach solution. Drain is usually in the middle of the bottom. maybe towards the back. It is supposed to drain into a pan underneath the unit and then evaporate. Another solution could be a leaky door gasket. This overwhelms the defrost system and causes leaks.
Jun 16, 2008 | Frigidaire Freezer GLRT183TD
Haier 3.5 cu. ft. Chest Freezer HNCM035E Logo
93 people viewed this question
Top Haier Freezers Experts
Victor Nwachukwu
Victor Nwachukwu
Charles T Nevin
Charles T Nevin
christian nielsen
Are you a Haier Freezer Expert? Answer questions, earn points and help others
