Question about Dualit Vario 3 Slices Toaster
Dualit Combi model (made in UK)
Had this unit in six months ago - had several elements open circuited, at customers request replaced all four elements.
unit has come back in customers complaining that when using outer slot outside of toast doesnt cook (centre elements are noticeably brighter) The elements we used were supplied by stokes their part numbers TEL24C and TEL24S. i have contacted stokes, they suggested i checked resistance of elements outer around 150ohm (measure 148) centre 110ohm (measure 108). timer active connects to centre elements, outer elements are switched seperately. Unrelated to this one of the outer slots is missing its lifter finger, looks like its part of the lifter bar, any ideas where i would source replacement parts from?
  • 37 Answers
Service center in US:
Electra-Craft
41 Woodbine St
Bergenfield NJ 07621
phone 201-439-1700 ask for Steve Karow
fax 201-439-1701
info@electra-craft.com
www.electra-craft.com
Posted on Nov 20, 2008
The side element in the toatie side of the toaster has failed.
Replacement elements are available on ebay. you can get to the element to replace by removing the bottom of the toaster. not a hard job.
Dec 22, 2010 | Dualit Vario Combi 2+1 65-Slice Toaster
How do you replace a centre element of a Dualit 3 slice toaster?
You can buy the elements from ebay uk and for 110 v also, they are so slim and light that they ship them in normal envelope and arrived in no time.
You can follow the instruction in the link what to order and how to replace.
We have the procedure here in this link
http://www.fixya.com/support/r4472039-procedure_replacing_heating_elements
Good luck
Jun 07, 2010 | Dualit 31213 3Slice Toaster
Not toasting evenly
Inside your toaster there are six heating element plates four in the center and one in left end and one in right end.
Just switch on the toaster without any bread at maximum time and visualy inspect to see which side is becoming red and which not. Then you need to replace the element plates you see that they don't become red.
Remember that the four in center are the same called "CENTER" and the other two on ends are the same called "END"
They can easily be removed if you remove the bottom panel.
Good Luck
Mar 26, 2010 | Dualit 31210 3-Slice Toaster
Dualit toaster - timer sticking.
The dualit all electrical parts like elements and timer switch are all manufacture in china and they are not as they used to be. I have a customer with a toaster of 25 years old and we have replace only one heating element up to now. For recent models we replace electrical parts in about 2 to 3 years, some times every year as you describe.
Feb 22, 2010 | Dualit Vario 3 Slices Toaster
Inherited a Dualit Vario 3 Toaster without instructions
Remember that the two in center are the same called "CENTER" and the other two on ends are the same called "END"
Good Luck
Nov 12, 2009 | Dualit 31210 3-Slice Toaster
Dualit combi heating element 12/95
All the element's are available on e-bay u.k. for about 6.00 gbp. Alternativley you may be able to repair it. Put the toaster on it's side with the bottom facing towards you and the knobs on the top. Remove the crumb tray and then remove the bottom (usually the screws are located in the feet). There may be one more visible screw remove that too, then you will see a rail at the bottom that secures the element's in place. Loosen off the nuts at each end and slide the rail down, undo the two bolt's feeding the power to the element's and slide the element out.Go over it with a continuity meter and see where it's broken then move the element wire about to bridge the circuit.Test it again and reassemble. I repaired mine this way.Or, simply replace the element using the instructions above.Easy!
Sep 18, 2008 | Dualit Vario 3 Slices Toaster
Dualit 4 slice toaster
measure and record the resistance of the elements. attach an ohmmeter to the (unplugged) power cord and push down the toast loading mechanism. wire the elements up until you get the same reading on the ohmmeter you got when ohming the elements out individually. Then make sure the ohmmeter reads open when the toast loader mechanism is deactivated. Then make real sure that the hot side of the ac power plug (the smaller plug) is not electrically connected to the case of the unit. Take the unit outside on a fireproof base and run an extension cord to it but leave it unplugged. Better yet use a switching power socket if you have one. Load it with toast and actuate the toast loading mechanism. Stand away from the unit and power it up. You may want to run it several times to eliminate any smoke from it due to contamination. Be aware that any finger acids or other contaminants on the elements will shorten their lifespan so you might want to clean it and let it dry thoroughly before use.
Nov 18, 2007 | Dualit Vario Combi 2x2 65-Slice Toaster
Dualit Vario 3 Slices Toaster Logo
223 people viewed this question
Top Dualit Kitchen Appliances - Others Experts
Mike Cairns
Mike Cairns
James Cole
Rabbit Brains
Rabbit Brains
Are you a Dualit Kitchen Appliances - Other Expert? Answer questions, earn points and help others
