I need wiring diagram for My anthes Furnace, so I can control the turning on & off the gas and fan.
Presently have it hooked to a thermostat, when I plug the fan in the furnace ignites thermostat shuts the gas on and off but not the fan.
Therinnaiguy
  • 1420 Answers
SOURCE: Goodman GMS90904CXA Wont ignite, light blinks 3 times
Ok, you either have a inducer fan issue or a pressure switch issue or a plugged vent pipe. The inducer turns on to establish a draft for the exhaust. If it is not working you will get this error code. If the pressure switch does not sense pressure caused by the inducer, it will give this code. If either the intake pipe or exhaust pipe is blocked (even y just a little) it will give you the same error code. If the condensate hose or receptical is plugged, again it will give you this error code. Good Luck!
Posted on Oct 21, 2008
boanhtgclg
  • 34 Answers
SOURCE: New honeywell thermostat on new gas furnace not working
sometimes there's a differential setting anywhere from 1-3 degrees, see if you can make sure it's down to 1
Posted on Nov 12, 2008
  • 12 Answers
SOURCE: hooking up new thermostat to new furnace
Letter designations for honeywell tsats R=24 volt power, W=heat, Y=cooling, G=fan, C=common wire for the 24volt power to tstat. Generally R is the red tstat wire and so on. Blue tstat wire can be hooked up to common at the tstat. On the heater the blue tstat wire would be hooked up to the C terminal. But this also depends on the manufacturer of heating unit.
Posted on Jan 22, 2009
  • 232 Answers
SOURCE: My husband just installed the Honeywell RTH2310
need to make sure there is a jumper between RC and RH if the red wire is connected to the RC terminal the heat wont work you will need a jumper wire to tie the RC and RC together with the red wire.
Posted on Oct 20, 2009
heatman101
  • 43501 Answers
SOURCE: Coleman furnace -- fan runs, ingniter won't light,
The chances are that the furnace was running when the power went out. This will cause the high limit switch to cutout and needs to be manually reset.
You will find that switch in the blower compartment near the blower. Usually somewher near the highest point of the cabinet.
Push the little red button firmly till it clicks.
When the power goes out while the furnace is running the heat builds up because the blower shuts down immediately and causes this limit switch to cut out.
If you have a electric tester you can also follow the low voltage circuit till you find the open switch. Ther is usually a wiring schematic on the door cover of most furnaces.
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Posted on Dec 09, 2009
How do you hook up the thermostat to a Central Electric feh-017ha-04 furnace? Also, where do the A/C wires hook up to the furnace?
The standard color code for the HVAC is as follows....
Red=Hot or 24v
White=Heat
Green=Fan
Yellow=A/C
White 1=secondary heat.
Blue=Spare
Orange=Heat Pump
C=Common
The thermostat has the terminals marked R,Rh,W,G,Y.
The furnace should have a terminal strip with similar markings.
If you only have 1 control transformer this will be easy.
Hook the wires up using the colors I have listed. If you don't have the same color wires go with whats close to them....such as use Orange for Red etc. It really doesn't matter as long as they are landed on the same terminals on the thermostat and furnace. Two wires running to A.C unit outside put one on Y the other on C. If you need any more help let me know!
Jun 02, 2014 | Intertherm Heating & Cooling
Honeywell manuals
Turn the fan in the ON position to verify you have power to the furnace. If the fan turns on, turn it back to AUTO. Pull the thermostat off the wall to get to the low voltage wiring. If you have a gas furnace, pull the red & white wires off and pinch them together. If the furnace starts, the thermostat is bad. If it doesn't start, then begin looking for flame roll out switches in the furnace burner compartment to manually reset. If the furnace inducer (combustion motor starts, & you get no flame, then it is either an ignition problem, or someone didn't pay their gas bill. :0
Dec 11, 2013 | Honeywell Programmable Thermostat Heater
Bryant programmable thermostat doesnt keep the temp have to put it on fan instead of auto
My guess is that you have gas heat. If this is the case, sounds to me like your main control board or depending on age of furnace, fan controller is not working. With gas furnaces, it utilizes 2 fan speeds. High for cooling, & Low for heating. Your thermostat only controls the High speed - switches when you turn your fan on & when there is a call for cooling. The only other thing I can think of is it is possible that the Low speed windings on the blower motor are open causing it to not turn on. Most motors have 3 to 4 speeds & only 2 are used. Switch the heat motor wires in the furnace (on the control board) with one that is on a spare terminal.
Feb 21, 2013 | Bryant Cube Series 1 Stage Heat/ 1 Stage...
Ac/fan stopped cooling/blowing/ i hooked up red & green wires and fan blows. now what?
Just to understand what you are saying; You are hooking a wire between the R terminal & the G terminal on the fan control board and the fan runs. When you turn the fan on by the thermostat is does not.
Assuming that you have 24 volts at the G terminal (or wire) at the air handler/furnace when the fan does not run, I would have to say, based on the information that I have been given, that you have a bad fan control board.
Nov 20, 2011 | Heating & Cooling
Just purchased and installed a Honeywell programmable thermostat (RTH6350) and for some reason, the furnace just decided to turn on, and it won't turn off - even when i turned the thermostat off!!!...
I would recheck your wiring..... Shut the furnace off at the breaker or SSU.... Then get a pen and pad and write down the color of wires and where it is connect on the Terminal strip at the furnace..
Example: Red wire hooked to R terminal etc They should all match up with the subase of the new Thermostat.
Then go up to the thermostat and Check and make sure the colors match what you have wired at the furnace. R= Power W=Heat G=Fan Y=Cooling C=Common
There are two possible ways the heat could be power on all the time..... You have the white wire or W wire wired to G and the thermostat is set to Fan ON... or the insulation on the R wire and W wire is split and touching each other or they got pinched and are touching together which will make the furnace come on with out the thermostat controlling it..... Good Luck, Its is where I would start first.... there our other possibilitys the control board may of gone hay wire.....
May 22, 2011 | Honeywell Programmable Thermostat Heater
I just purchased a house with brand new furnace wired to a RTH2300 Honeywell thermostat. It only has two wires running to it. I can't seem to get it to work in "manual mode"-where I set it on...
?? Connect Wires 5.
Labels don't match?
If a wire does not match any terminal on the thermostat,
see next page.
Quick Installation Guide
6
Alternate Wiring
If a labeled wire does not match any terminal
designation, see diagram below.
Do not use C, C1 or X wire. Do not use B wire if you already
have O wire. Wrap bare end of wire with electrical tape.
This thermostat cannot be used if your old thermostat had
any two of the following wires: R, RC, RH, 4 and V.
Place a jumper (piece of wire) between Y and W if you have
a heat pump without auxiliary/back-up heat.
?? Connect Wires (cont'd)
Programmable Thermostat RTH2300
7
Set jumper JP1, on the back of the thermostat, if you
have connected a wire to the G terminal.
Incorrect jumper setting: An incorrect setting is
noticeable in a gas or oil heating system. When heating
starts, you will initially feel cold air coming out of the vents
as the fan is running before the furnace has enough time
to heat up the air.
?? Set Heating Fan Control 6.
HG Leave the jumper in this factory-set
position if you have a gas or oil furnace.
HE Place the jumper to this position if you
have an electric furnace.
JP1
8
Set jumper JP2, on the back of the thermostat, if you
have a heat pump.
Incorrect jumper setting: The heat pump operation
will be reversed, i.e., it will cool in Heat mode and will
heat in Cool mode.
?? Set Heat Pump Reversing Valve 7.
O Leave the jumper in this factory-set
position if you have connected O wire to
the O/B terminal.
B Place the jumper to this position if you
have connected B wire to the O/B terminal.
JP2
9
1) Install 2 AAA
batteries on the
back of the
thermostat.
2) Align the two
brackets on the
top of the
thermostat with
the corresponding
slots on the top of
the wallplate.
3) Push the
thermostat
against the
wallplate.
4) Tighten the screw
at the bottom of
the thermostat.
5) Turn power back
on at the heating/
cooling system.
Nov 27, 2010 | Honeywell Programmable Thermostat Heater
My furance is running and will not turn off the air-condition was on but now will not run but the furnace is still running but but does not turn off at themastatic can you tell me what to do for this...
I suspect the sequencer is stuck. However, you may have a thermostat problem or a short in the 24V. If it is a heat pump then likely the reversing valve is not kicking in. There can be numerous causes for this and you should probably call a pro in for this one. Diagnosis is not such a simple thing.
Jun 29, 2010 | Goodman CLQ36AR49 Air Conditioner
I WANT TO HOOK IT UP TO A FAN,BUT ARE NOT SURE WHICH CONNECTIONS TO ATTACH TO.
In order to hook this up to the fan on your furnace, you will need to either have or install a Fan center @ the furnace. (Unless it is gas, and has a circuit board that will simplify the process) All this is, is a transformer, a relay, and a set (or two) of NO and NC contacts. You will need to run 3 wires from the thermostat back to the furnace, if you do not have them already. If you have a gas furnace with a circuit board then all you have to do is connect the three wires from the thermostat to the board. (R to R; W to W; G to G. If you are using an older furnace, or a oil fired appliance, power should go out of the transformer (secondary side) to the thermostat on R. It should then come off W and another wire off G back to the furnace. Connect to the appriately marked terminals on the fan center. Hope this helps
Nov 19, 2009 | Honeywell International Honeywell&...
I'm trying to change the thermostat and hook up the wires but the heat does not turn on How do the wires need to be hooked up?
Here is the basic wiring diagram for a gas furnace thermostat
Red wire to R terminal
White wire to W terminal
Green wire to G terminal
Blue or Yellow to Y terminal
Jan 17, 2009 | Heating & Cooling
Heating & Cooling Logo
53 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
