Question about LG CF360 Cell Phone
Insert sim in this case center pin is positive ,please give me solution,
    Top Expert:
  • 1,575 Answers
Hi
Try removing the Simcard and reloading it again.
Try another Simcard on the phone,could be case of a blocked Simcard.
Solved?
Try hard resetting/master resetting the phone.But be warned though,this will delete your data and third party applications.
  • Press menu
  • Select settings
  • Scroll to phone settings and press OK
  • Scroll to reset settings and press OK
  • Press OK on master reset
  • Select on 'Yes and press OK
  • Enter security code and then press OK.[Default security code is 0000].
Now the phone resetts.
Posted on Feb 24, 2012
Nokia 2700 insert simcard solution
1. Check if battery is looose......if so insert a 3to4 times folded paper piece at the bottom of the battery
2. clean battery connection by scratching it gently with a blade...specially the centeral one ( it is BSI connection and in nokia it causes insert sim fault
3 Check sim connecting tray check and clean its pins.....if pins have got pressed lift them using oil pin
4. If still u have this problem contact service as sim ic might require replacement
Jan 21, 2014 | Nokia 2700 Classic
Insert sim
As far as I know.there are two possibilities to get this error..
1)Sim card not inserted properly:
Try to insert the sim properly..insert it at the desired position
2)Phone may be locked with a particular network:
If the phone is locked with a particular network then you need to unlock it.You can get the unlock service for your Blackberry 9360 Curve from either your network provider or third party unlocking service provider like, unBBlock.com and remove the network lock. Once unlocked it will work with other networks.
3)Sim Problem:
Mostly this won't be in your case because the sim had been working fine with your previous Nokia mobile and also the phone gives the same error message when you insert other sim cards.
4)Hardware Problem:
There might be some loose connection give it to a hardware service shop and check.
May 01, 2013 | Cellet Blackberry T-mobile Curve 9360...
Insert sim
what type of problem you have...?describe briefly
Feb 23, 2012 | Cell Phones
Showinf offline message when i changed its profile showing message please insert sim card
Check your sim card,might not inserted properly or try to clean the sim card interface using a pencil erase,scrub it,might corroded,try to replace another sim to be able to check if that is the only problem or also check the simcard socket if it is clean,check the pin if its align too, if this thing never works,probably need to repair or replace component such as sim ic,better ask assistance to a mobile service center for parts replacement.
Jul 21, 2011 | Nokia E66 Smartphone
Samsung gt-c3510 sim not working {insert sim} plz help me
* try to change another sim card
* check the sim socket if the pins are dislocated or damage
* might be a software problem and needs to program the phone
* might be a harware problem,and needs to replace sim ic or other components related to sim..
in that case,bring it to the mobile service center..
if this is helpful,please rate me.. thanks
Jun 03, 2011 | Samsung C3510 Cell Phone
Nokia insert sim track mising problam
try your sim in a different phone and make sure its not just a bad sim. if it is a bad sim most companys will give you a new one free of charge. if it works in another phone you'll want to do a master reset to see if its a software problem or a problem with the actual hardware (the metal connections that interact with the sim). to do the master reset per,http://nds1.nokia.com/phones/files/guides/Nokia_1600_UG_en.pdf select menu, settings restore factory settings, then restore all. if it asks you for a code it will be 12345 or 1234 unless you set another pin in which case it will be your pin. i hope this helps
Dec 24, 2010 | Nokia 1600 Cellular Phone
I have nokia 3120.problem is when i insert sim card.mobile screen show "please insert sim card" please find this problem.give me ans. In my e mail ID .thanks to you
First All Check:
1.Confirm whether same sim card is working in other h.s or not.
2.Make sure the sim slot is o.k. only try these two.
3.If all the above steps fails, check the SIM card connector pins for damage.
if so try to get serviced.
4.if ur sim card is good then it is problum form sim card ic u have u raplace it with SMD.
u can make it jumper mean u can fix this prob with out sim card is for this contact.
5.take sim connector slight up by pin then cheak by inserting sim.
6.hot air gun on sim i.c. then cheak it.
Last Option:
IF make sure that the sim card hasn't been damamged at all sO Please You Go to Service
& Sim Office and Get the Duplicate Sim Same Your No From Office Oprator
Problem will Solved Quickly
Oct 16, 2010 | Nokia 3120 Cellular Phone
Says insert sim
Before you do anything with it, please clean the sim card and sim card connector on the handset. Even a small rust/dust can create this problem.
If it doesn't help, you need to check the Sim card on another Handset. In most cases, this is damaged sim connector, and will be necessary to replace or re-soldered/refreshed. Sometimes even sim IC is the culprit which you need to replace or play jumper tricks. I would suggest you to get it done from a service center or from a nokia mobile repairing center.
Good luck.
Thanks for using FixYa.
Jul 03, 2010 | Nokia 1600 Cellular Phone
My Sidekick LX is asking for a "Special Code"
once it says to enter your "special code" you hit cancel and it enables the sim pin. then you go to change sim pin, put in your old sim pin and put in a new one. then go to network settings and select "scan and select manually". once you find at&t click done and you can use the sidekick.
Apr 09, 2009 | T-Mobile Sidekick II
Sim lock
The PIN (personal identification number) or PUK (personal unblocking key) are security features provided by your network service.
The PIN and PUK are provided on your SIM package, and can be changed many times. The basic purpose of these codes is to provide a security.These codes are normally used to prevent your SIM card from unauthorized use.
You can get this type of security by enabling the PIN check option in your mobile phone. If this feature is enabled, the phone requires your PIN each time it is switched on.There may be different solutions for your problem.
If you have not changed the original PIN of your SIM then you can get easily this code from the package that has come with your SIM card. Get these codes from SIM package and unlock your mobile phone.But if you have changed your PIN and now have forgotten it then there is also a way to resolve it. When you give an incorrect PIN three times to your mobile phone it will block your SIM card, then in this case you have to provide a PUK given to you by network provider. And you can get your PUK any time by calling at the help line number of your network service center.
Sep 14, 2008 | Nokia N73 Cellular Phone
LG CF360 Cell Phone Logo
47 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
