Question about Onkyo A-9555 2-Channel Amplifier
Fuse type for onkyo a-9555
Main fuse size volts slow or fast blow
  • bob nonni Feb 23, 2012
    what hifi tuning fuse would replace the original
    Guru:
  • 513 Answers
The main power fuse for most amplifiers is a fast blow, 125 volt fuse for the US and a 250v fuse in countries with 220v. This unit is 125 watt so the main fuse should be 2 amps or so. The correct fuse size is written on the circuit board next to where the internal fuse was located.
Posted on Feb 24, 2012
Toshiba 37E200U LCD television
T5.0AH 250V used in this TV is a ceramic fuse Time delayed (Slow-Blow) and the dimensions are probably: 5 mm (3/16 in) x 20 mm (3/4 in). You just measure the old one.
Regards GJ
Jun 20, 2014 | Toshiba 37E200U 37 in TV
I have Aragon 8002. I have a problem because I have no fuse. What fuse is used at 220V? Thanks, John
Have you the remains of the fuse, or was it just not in place when you got it?
The reason I ask is that the amp's fuse doesn't have much to do with the voltage of the mains supply (in your case a 250V fuse will cover it). It goes on the load in Amps or Milli-amps. Shown as A or MA. If you have the old fuse you might be able to see it on the case of the fuse. It might say 1.5A or 500ma etc. Also there are two main types of fuse, known as fast and slow blow fuses. Again if you have the old fuse the remains of a coil inside will mean it's a slow type. The other type is just a wire. However you can fit a fast blow for a slow one. If the fuse blows again it will be a fault that causes it.
If you have no fuse left at all you will either need to find someone who has the same amp and to tell you what it is, or the circuit diagram for the amp. Sometimes it's even printed on the PC board!
Feb 15, 2011 | Aragon Audio Players & Recorders
What kind of fuses are needed for JVC HR J692U VCR? Slow blow or fast acting? What termination style 1.25 a 250 volts.
I don't know what you mean on "termination style" but I can help you on the fuse type. If you have the dead fuse look inside and see if you can see a coil of wire. If you can it's a slow blow. If you haven't got it or it looks just like a broken wire or it's gone too much, then fit a fast blow. It won't make any difference. If it blows again after a new one is fitted then it's not because it's a fast blow. It means you have a short-circuited semiconductor somewhere causing it to blow.
Feb 14, 2011 | JVC HR-J692U S-VHS VCR
Does anybody know how to identify the fuse in this vcr? It is a 1.6a 125 volt and it has yellow,red,blue,orange bands on it. I can't tell if it's a fast blo or slo blo fuse.
The colour bands simply tell you what you know already! IE it's a 1.6 Amp 125 volt fuse. As for if it is slow or fast, if you can see a coil of fuse wire inside it's a slow blow. If the remains look like a single wire it's fast. If you can't see any remains fit a fast blow. If it goes again, it won't be the fuse type that's the problem, but a short-circuited device somewhere.
Sep 23, 2010 | Mitsubishi HS-HD2000U VCR
Is there a fuse in ge jvm1350 model if so where?
there are many fuses in this microwave,,,but you may not get the right sizes, there not normal sizes that you have in the home,,there are slow blow fuses fast blow fuses and some are very high voltage fuses,,
a point i should tell you now is that inside your microwave it could still have 1000's of volts still in it,,if you go poking about inside it and tuch this voltage it will realy bite you!!! it could easly kill you,,,,
is it realy worth that? if a fuse has blowen there is another fault in it that caused this fuse to blow in the first place,,,
Jun 06, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Everything works except the microwave function
yes there are fuses inside it,,,but,,,there is also a lot of volts still in it too, "ie, 1000's" and they bite too,
bit like a police stun gun will,,but they may not just stun you,,they could very well kill you,, so be warned!
also the fuses are not the normal sizes you would have at home, and some of them are "slow blow" type and some are "fast blow" type,,, and one is at least 1 to 4 1000 volts type?
and my gess is a fuse has poped becouse the magnatron has given up the ghost and poped its clogs!!! like its dead! and a new magnatron would be dearer than a new microwave to have fitted,,
so,,,get a new unit,,dont tinker with it and stay alive!
Jun 06, 2010 | Frigidaire PLMV169DC Microwave Oven
Does The Onkyo TX-8210 take a slow blow or fast blow fuse?
slow blow (aka time delay) fuses are used in motor circuits. Electronic devices use normal or fast blow fuses
Oct 02, 2009 | Onkyo TX-8210 Receiver
Blown Fuse, needs fix'n
You CAN open the unit (keep in mind that even unpluged there is still voltage runing through the system, so.... dont fry) and you will notice, if the face of the unit is towards you you will see on the left hand side a power supply board, the fuse is on that board, and it is a tube fuse, 125V 8A. Most stores do not carry the 125V version anymore, but will carry a 250V. This is okay to use where the voltage is not the main purpose of the fuse.
Oct 19, 2007 | Onkyo HTR500 Receiver
Onkyo A-9555 2-Channel Amplifier Logo
272 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
