Question about Gateway 702GE PC Desktop
Usb boot disk no boot
Only boot error, works on other computers
Change it if you have the warranty as it requires warranty. If you do not have the same, then you may call me at +1 224 636 8057 (10AM EST- 6PM EST).
Posted on Mar 11, 2012
NTLDR compressed on a Compaq Presario SR105CL cant enter bios to set to boot
Step 1:
Which operating system ?
Computer is booting from a non-bootable source. Computer hard disk drive is not properly setup in BIOS. Corrupt NTLDR and NTDETECT.COM file. Misconfiguration with the boot.ini file. Attempting to upgrade from a Windows 95, 98, or ME computer that is using FAT.32 New hard disk drive being added. Corrupt boot sector / master boot record. Seriously corrupted version of Windows 2000 or Windows XP. Loose or Faulty IDE/EIDE hard disk drive cable. Failing to enable USB keyboard support in the BIOS. Many times this error is caused when the computer is attempting to boot from a non-bootable floppy disk or CD ROM First verify that no Floppy Diskette or CD is in the computer, unless you are attempting to boot from a diskette. b> Note: This error has also been known to occur when a memory stick is in a card reader and the computer is attempting to boot from it. If you have any card reader or flash reader make sure that no memory stick is inside the computer. Additionally disconnect all USB drives, cameras, ipods, iphones, etc. from the computer. If you are attempting to BOOT from a floppy diskette and are receiving this error message it is likely that the diskette does not have all the necessary files or is corrupt. If you are attempting to install Windows XP or Windows 2000 and are receiving this error message as the computer is booting verify that your computer BIOS has the proper boot settings. For example, if you are attempting to run the install from the CD-ROM make sure the CD-ROM is the first boot device, and not the hard disk drive. Second, when the computer is booting you should receive the below prompt. Press any key to boot from the CD
Mar 10, 2013 | Compaq Presario sr1055cl PC Desktop
Getting boot error message
The error PXE-E61: Media test failure usually means the hard disk has failed or the hard disk needs re-seating or the disk controller is faulty. First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty. Next - to check if the hard drive is faulty, remove the hard drive and insert it into an USB hard drive adapter and connect it to a working computer's USB port. If this computer cannot see it as an USB mass storage device and you cannot open the various folders and files on this drive, then this confirms the hard drive is faulty. Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Oct 09, 2012 | mpc X3000 Laptop Transport 14.1" Barebone
Ntlrd missing xp tablet on my hp tc1000 with no cd rom
Causes
  1. Computer is booting from a non-bootable source.
  2. Computer hard disk drive is not properly setup in BIOS.
  3. Corrupt NTLDR and NTDETECT.COM file.
  4. Misconfiguration with the boot.ini file.
  5. Attempting to upgrade from a Windows 95, 98, or ME computer that is using FAT32.
  6. New hard disk drive being added.
  7. Corrupt boot sector / master boot record.
  8. Seriously corrupted version of Windows 2000 or Windows XP.
  9. Loose or Faulty IDE/EIDE hard disk drive cable.
  10. Failing to enable USB keyboard support in the BIOS.
Solutions
Many times this error is caused when the computer is attempting to boot from a non-bootable floppy disk or CD-ROM. First verify that no floppy diskette or CD is in the computer, unless you are attempting to boot from a diskette.
If you are attempting to boot from a floppy diskette and are receiving this error message it is likely that the diskette does not have all the necessary files or is corrupt.
Important: When you see this message press any key such as the Enter key immediately, otherwise it will try booting from the hard drive and likely get the NTLDR error again.
Note: If you are not receiving the above message and your BIOS boot options are set properly it's also possible that your CD-ROM drive may not be booting from the CD-ROM properly. Verify the jumpers are set properly on the CD-ROM drive.
Verify that your computer hard disk drive is properly setup in the CMOS setup. Improper settings can cause this error.
Corrupt NTLDR or NTDETECT.COM file
Windows 2000 users
Windows XP users
Sep 24, 2011 | Computers & Internet
Ntldr is mising
Related errors
Below are the full error messages that may be seen when the computer is booting.
NTLDR is Missing
Press any key to restart
Boot: Couldn't find NTLDR
Please insert another disk
NTLDR is missing
Press Ctrl Alt Del to Restart
Causes
  5. Attempting to upgrade from a Windows 95, 98, or ME computer that is usingFAT32.
Solutions
Feb 19, 2011 | Microsoft Computers & Internet
When my computer starts it goes to a black screen and says "no bootable device jnsert boot disk and press any key" what can i do
Normal 0
This error message - "No bootable device. Insert boot disk and press any key" means -
The PC cannot see a boot file/disk on either the hard disk or floppy drive.
Check the floppy drive and remove and floppy disk.
If there was no disk in the floppy drive then it is a hard disk problem.
Check the BIOS to see if the hard disk is detected, if not open the case and re-seat the data cable on the hard drive and also where it connects to the motherboard disk controller.
If it still gives this error message and the BIOS does not detect the hard drive, then the hard drive is probably faulty.
A further check on the hard drive, remove the hard drive and connect it to an USB hard drive adapter and connect it to a working computer's USB port, if this computer does not detect it as an external storage device then the hard drive is faulty.
To get the computer working again, install a new hard drive in your computer and then install Windows on the new hard drive plus the computer's device drivers and your programs.
Oct 02, 2010 | Computers & Internet
Clicking, and the computer states that there is a disk boot error, insert boot disk and press enter
Remove all the components like usb pendrive or usb CD Drive and check if there any CD in CD/DVD, if its there remove it. Then refix the Hard disk data and power cable and restart your pc. it will work .if its not still booting, you need to reinstall operating system
Apr 01, 2010 | Computers & Internet
When my friend turns on his computer on the screen it automatic says the "No bootable device" what could i do to fix it
THis error comes when your hard drive not recognized in bios.
For that make sure your hard drive is detected in bios.
When you power up the computer press F1 or F2 or "del" key to enter in bios.
Then disable SATA option in Ide configuration .
Then save and exit.
Then If still not detected in bios then you need to reattch hard drive in to laptop.
For that you need to open back cover of laptop the reattach hard drive.
Let me know if you need further assistance.
Thanks for using FixYa.
Dec 11, 2009 | Acer Aspire 4315 Notebook
My acer 7520 opens with an error reading NVIDIA boot agent 249.0542, then reads PXE-E61 media test failure, check cable, PXE-M0F exiting NVIDIA boot agent.
This error message could be a faulty hard disk or a faulty disk controller.
Reseat the hard disk to see if the problem is fixed.
If not go into the BIOS settings and check if the BIOS can detect the hard disk.
If the hard disk is not detected then remove the hard disk and connect it to an USB hard disk adapter and connect it to a working computer's USB port. If the this computer cannot detect it as an external hard drive then the hard drive is faulty. Then the Acer needs a replacement hard disk and Windows installed together with the laptop's device drivers and programs etc.
Oct 20, 2009 | Aspire Acer 7520-5324 Laptop
Need help
Is error happens mostly when usb devices or diskettes is inserted to the computer.. The computer tries to boot from them but when there isn't any boot data it just keeps making that error..
Just try to remove all extra usb-devices, cd's/dvd's and floppies/diskettes connected to the computer, so it's only monitor, power, mouse, keyboard and internet that is plugged in..
PS: Please rate this solution
Mar 11, 2009 | Ulead Videostudio 8 for PC
Boot error message
Do you have a disk inside your floppy drive? If you do, remove it and try to boot your computer again.
Do you have a USB hard disk connected? If you do, try disconnecting it first.
If those two things don't work, you will need to have your computer checked by a technician. Maybe there is a problem with the hard disk or with the BIOS configuration (boot sequence).
May 28, 2008 | Computers & Internet
Gateway 702GE PC Desktop Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
