Question about Canon imageRUNNER C3200 Copier
Hello got a imagerunner C3200, error of 000020-0425
Hello had a error of 000020-0181, changed black drum, now have a error of 000020-0425. Please help as we used this copier daily. Sandra
  • Charles
    Charles Mar 14, 2012
    E020 codes point to issues with reading color density patches produced by the drum units the first 2 gig it's of the subcode point to the color
    E020-xx
    E020-04 would point to a black color issue you may have gotten a defective drum. The code you state you previously had points to an issue with yellow. Check to make sure when you open the front cover of your machine on the right side of the door there should be a plastic cover screwed to the door with a tab sticking out, this tab engages the SALT sensor shutter. Make sure it is not broken or you could get various E020 codes also try putting your old drum back in and if the codes changes you probably got a bad drum. I'll check back with what you find good luck
5 Suggested Answers
fer_nan_14
  • 76 Answers
SOURCE: Canon C3200 imagerunner
go to service mode By pressing * 28 * and you will see a menu COPIER then MISC
Posted on Dec 09, 2008
PATHAMPAD
  • 25 Answers
SOURCE: i have a e 000020-0181 code in a canon ir3200
CHANGE MAGENTA DRUM UNIT
Posted on Oct 31, 2009
  • 6 Answers
SOURCE: Reset id and password System Manager
Enter service mode by pressing the "additional functions" button, then the "2" and "8" buttons together, then the "additional functions" button again.
You will then go to Copier>Function>Clear and select PWD-CLR. Hit "ok".
Hit the yellow reset button a few times to get back to the regular screen, and you should be able to get into the system settings to change IP config and other settings.
Depending on how it was configured, you may have to restart the machine for the reset to take effect.
Once you change the IP settings, do another restart and wait for about 3 minutes for the machine to get on the network...
Posted on Mar 17, 2009
  • 78 Answers
SOURCE: problem on Canon imageRUNNER C3200 Copier Error
replace black drum it is reaching the end of its life also make sure your machine has the latest software version as drums will last longer if it has have seen drums reach 700-800%
Posted on Nov 10, 2009
Hello, i just replaced the black toner of my IR 3200 and i get the error code E000020-04a0. Can anyone help me please
E020-04a0 is a defective drum unit or a drum unit unable to produce the correct color density needed by the machine. E020-0Xa0. X being the color the code points to, count from left to right if you open ur toner door and look at the colored stickers. Just Replace the black drum and ur good to go Part Number is 7625A001AA
Mar 02, 2012 | Canon imageRUNNER C3200 Copier
Hello i have a canon machine c3200 and the code that it give to me is e000020-360 and i dont know what is that
This is most lilely an error with one of the drums. The fist 2 digits indicate the color of drum. 01 is Black, 02 is Magenta, 03 is Cyan, and 04 - Yellow. The "60" is indicating that the developer concentration target value is faulty. This is set when a new drum is installed. Buy a new cyan drum and install it yourself. All adjustments are automatically done by the copier. Good luck.
Mar 09, 2011 | Canon imageRUNNER C3200 Copier
Canon IR C3200--error code E000020-01b0 explain this code please
Hi there
Error code E000020-01B0
That code relates to the yellow drum unit.
The unit was probably damaged taking it in an out.
Needs to be replaced.
Or try.
1. Information UPDATE UPDATE - the Drum units are as follows:
Yellow - 746
magenta - 215
Cyan - 758
Black - 9
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 04, 2010 | Canon imageRUNNER C3200 Color Printer
Problem on Canon imageRUNNER C3200 Copier Error Code We have an error code of e000020-04b0
Nov 04, 2009 | Canon imageRUNNER C3200 Copier
Error code E000020-10b0
The error code is for a Black toner problem. The E000020 is for the drum/developersection, the 04 is for black, and the BO is for the drum unit approaching the end of its life. The quick way is to replace the black drum unit.
Oct 06, 2009 | Canon imageRUNNER C3200 Copier
Error code E000020-01b0, E000020-0260
E020 is a Drum/developer error code
-01b0 is a yellow drum error
-0260 is a magenta drum error
drums need replaced
7622A001AA Yellow drum part#
7623A001AA Magenta drum part#
7624A001AA Cyan drum part#
7623A001AA Black drum part#
Aug 20, 2009 | Canon imageRUNNER C3200 Copier
Canon iR C3200 E00020 02d0
check or change the magenta drum unit
Jul 29, 2009 | Canon imageRUNNER C3200 Copier
Canon error displayed on LCD E000020-0160
The developer concentration
target value is faulty (set when a
new drum is fitted; the value is
extremely small).
The fault is with the yellow drum unit, normally replacing it solves the fault.
Feb 03, 2009 | Canon imageRUNNER C3200 Copier
Error code Canon IRC3200
change the black drum reached end of its life
Canon Tech
Jul 22, 2008 | Canon imageRUNNER C3200 Copier
Error Code
SPECIFICALLY...you need to replace the Black drum unit.
the sequence of that particular error code is;
E020-01XX(Yellow drum)
E020-02XX(Magenta drum)
E020-03XX(cyan drum)
E020-04XX(Black drum)
Apr 02, 2007 | Canon imageRUNNER C3200 Copier
Canon imageRUNNER C3200 Copier Logo
118 people viewed this question
old marine
old marine
