Question about Daewoo KOR-630A Microwave Oven
Thermal fuse daewoo kor-6n9rr - Daewoo KOR-630A Microwave Oven
4 Suggested Answers
MicrowaveSvc
  • 9098 Answers
SOURCE: How to change light Daewoo KOR - 63F7
If there's no obvious removable cover over the bulb (most often on the rear or side) and the owner's manual doesn't address it, then disassembly will be required.
You'll need to remove the outer cover (wrapper) to get to the bulb.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
If you don't have your instructions, please reply back with your brand and model number.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph.
See these links before proceeding:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had locally in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch halogen types with your bare skin, as the oils will shorten the bulb life.
Posted on Aug 20, 2009
heatman101
  • 43501 Answers
SOURCE: Thermal fuse needs replacing.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
hjkj
Posted on Sep 30, 2010
heatman101
  • 43501 Answers
SOURCE: just brought a daewoo kor-6n9rr
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Posted on Feb 20, 2011
Daewoo KOR-6N9RR
It may be that the door interlock system has not worked properly, and blown an Internal fuse inside the case.
Did you slam the Microwave door when you last used it? This is a common cause of the fuse blowing.
As it is still new, I suggest that you contact your supplier, or local service agent to carry out the neccesary repair, probably for FREE. :)
I hope this helps?
Mar 25, 2015 | Daewoo Microwave Ovens
Set my microwave there is no light at all
When you say there is no light at all, do you mean that there is no light where the time comes up or that there is no light coming on even when you open the door? If you have no power at all, no light when you open the door and no timer numbers, you probably have a blown fuse. If that is the case, unplug your microwave and turn it around and remove the screws holding cover on and then remove the cover. Look for where the power cord goes into the back of the unit and follow the black wire from the cord to where it ends. It should stop an either a circuit board or a fuse holder. Make sure that you replace the fuse with the same amperage fuse as what you take out. You will find the amp rating stamped on one of the silver collars on each end of the fuse. Good luck!
Mar 02, 2015 | Daewoo Microwave Ovens
Hi I have a daewoo microwave kor/6n9rr 800watt the upper fuse has blown ,enquired with spares suppliers ,only fuse showing on their parts was one with wire attached each end with terminals which I...
Hello Mary
You shouldn't be working on, or inside a microwave oven. They are not a consumer repair job due to the debilitating effects of microwave energy, the high voltages inside the capacitor, and the highly poisonous core to the magnetron.
Fuses blow for a reason, you have to find the reason before replacing the fuse. Unless you are an electrical engineer, take it to an authorised repair centre, or just buy a new one.
Apr 17, 2017 | Daewoo KOR6N9RR Microwave Oven
Just brought a daewoo kor-6n9rr , it is very noisy and does not heat up at all, is there something i have not done.
Basic
heatman101
Feb 20, 2011 | Daewoo Microwave Ovens
My DAEWOO KOR-1B4H. BLEW A FUSE WHEN I OPENED THE DOOR. CAN I FIX IT MYSELF?
which fuse has blown, was it in the plug or in the microwave itself?
Feb 17, 2010 | Daewoo KOR-1B4H Microwave Oven
Nothing turns on. replaced blown fuse.still nothing!
it could be a thermal fuse inside the unit or the thermal cutout on the mag tube isn't closing again after overheating, or possibly the triac or main power relay
Oct 06, 2009 | Daewoo KOR-1B4H Microwave Oven
heatman101
hjkj
Apr 18, 2009 | Daewoo KOR-630A Microwave Oven
User manual
Download the manual here:
http://www.nodevice.com/user_manual/daewoo/microwave_oven1/kor-630a.html
Sep 29, 2007 | Daewoo KOR-630A Microwave Oven
Daewoo KOR-630A Microwave Oven Logo
Top Daewoo Microwave Ovens Experts
William Miller
William Miller
Ian Summerfield
Ian Summerfield
Are you a Daewoo Microwave Oven Expert? Answer questions, earn points and help others
