Problem with my PC
How toget system configuration information.
    Scholar:
  • 191 Answers
Click o start menu goto RUN and type dxdiag and then enter. you will get the system information.
Posted on Oct 28, 2008
How to enable wireless on acer
Enable the wireless in the BIOS if it has been disabled.
Next install the wireless card driver if it has not been installed.
Download the device drivers from the Acer WEB site. Makesure you select the model of your laptop the drivers you that require thatmatches the Windows version that is installed on your laptop. Use this link toget to the Acer support: -
http://www.acersupport.com/drivers_download.aspx
Next - your wireless router needs to be configured with the wireless settings.
Then the wireless card in the Acer needs to be configured with the routers wireless settings.
Jun 15, 2011 | Acer Aspire 5535-5050 Notebook
Tip
How to check your System configuration.
System configuration can be seen through a lot of different ways such as going to System Properties.
But the fastest and most effective way is dxdiag, which stands for Direct X Dialog.
To check your system configuration details you only have to follow my easy recipe as easy as 1-2-3.
1. Click the Start Menu Button on the taskbar.
2. Click "Run"
3. Type in "dxdiag"
4. A dialog box will appear, click Yes and wait.
5. After few seconds a new window will appear.
You can see your system configuration on the first tab, if you want a detailed information about a specific item, click the most relevant item and you'll get specific details about it.
on Apr 05, 2010 | Computers & Internet
I have acer desktop and S/N no. of my system is AWP04DS4739040299LE I need Driver of my PC
May 19, 2011 | AcerPower Sn PC Desktop
Nvalid configuration information - please run SETUP program, The system configuration information does not match the hardware configuration. ...and it will stay there.
Hi oyemsdetosin,
I see that you are encountering an issue with you machine.
try to boot into safemode, once in safe mode unstall what ever program was install recent on the machine and mahy need reinstallation, also check if your drivers are all ok possible windows update may have changed some of your system drivers.
If you cant boot into safe mode try running a system restore using your window disc by running a recovery. If still that does not work I believe you will need to reinstall windows.
I hope this will be helpful.
Have a nice day,
mvincentc
May 16, 2011 | Dell Latitude D600 Notebook
Did Dell sell the Inspiron 546 desktop computer with a Network Adaptor, or was it an additional purchase
It probably didn't come with a network adapter. Most desktop system don't unless someone did a custom configuration from dell. The easiest way you could check though would be to put the service tag information in at dell's website then click on the tab that says "original configuration" this will give you all the information regarding the hardware that was installed when dell shipped the system.
Hope this helps
May 02, 2010 | Dell Inspiron 546 MT PC Desktop
Will not down load properly from disc unable toget smart wizard unable to go wireless
Download the drivers for the adapter from the below link:
http://kb.netgear.com/app/products/family/a_id/1268
Download and install the drivers and configure the wireless connection using it.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Oct 24, 2009 | NetGear : WG111 54 Mbps Wireless USB 2.0...
How to know dell 370 precision battery
If the battery is changed, that will mean that the BIOS was set back to january 1 1980.
Go into BIOS, set the clock to the correct time.
For DELL 370 precision , here is the BIOS instruction:
http://support.dell.com/support/edocs/systems/ws370/
Replacing the Battery caution.gif CAUTION: Before you begin any of the procedures in this section, follow the safety instructions located in the Product Information Guide. notice.gif NOTICE: To prevent static damage to components inside your computer, discharge static electricity from your body before you touch any of your computer's electronic components. You can do so by touching an unpainted metal surface on the computer.
A coin-cell battery maintains computer configuration, date, and time information. The battery can last several years.
The battery may need replacing if you have repeatedly reset the time and date information after turning on the computer or if one of the following messages appear:
Time-of-day not set - please run SETUP program
or
Invalid configuration information -
or
Strike the F1 key to continue,
F2 to run the setup utility
To determine whether you need to replace the battery, reenter the time and date in system setup and exit the program to save the information. Turn off your computer and disconnect it from the electrical outlet for a few hours; then reconnect the computer, turn it on, and enter system setup. If the date and time are not correct in system setup, replace the battery.
You can operate your computer without a battery; however, without a battery, the configuration information is erased if the computer is turned off or unplugged from the electrical outlet. In this case, you must enter system setup and reset the configuration options.
Jul 03, 2009 | Dell Precision 360 PC Desktop
Dell inspiron 6000 invalid configuration information
ok wen you turn on your pc can you see anything on your screen ?
number letters ? anything ?
an for how long ?
can you describe with more detail whats going on wen you turn the pc ?
Aug 26, 2008 | Dell Inspiron 6000 Notebook
Games
dear-rjkumar....
hanging of pc during playin game is not a big problem...
i would like to suggest folling to do-
1.check u r system configuration configuration....does in complete the game configuration.....BECAUSE some games need a very hi fi configuration.....
2.check u r display driver & try to update u r display driver...
i m sure u r problem will be solved.dude..
for more information on this topic u can mail me too
at-sigma_shiva1@rediff.com
Nov 12, 2007 | Microsoft Windows XP Professional With...
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
