Question about Dryers
Power problem Hi; Can anyone help me figure this out. I have burned two of the control boards for my dryer already. First i assumed that it was time for the original control board to go bad, but after I replaced that one, the second one went "puff". Before all of that I have replaced the termination block and I think I mixed those cables somehow. I'm including this picture and hoping this is that problem and one of you guys can help me out. Thanks Mike
  • michalski20 Oct 28, 2008
    This is a Meytag Neptune dryer Model # MDE6800AYW.
    Thank you very much for all your help WAYNEARD.
    President:
  • 1,901 Answers
YIKES!!
Put the white wires on the center lug. Take the blue wires and put them on the right lug. Leave the black wires where they are.
I'm surprised you didn't do more damage than the control board. Make sure the power terminals stay the way they are.
Posted on Oct 28, 2008
The control panel will not work, no lights on panel.
First make sure you house fuse or breaker didn't trip. If you have power to the dryer house outlet, next check the connections where the big 220 volt power cord goes into the dryer. Should be a small access cover you can take off to look at the power cord connections. Sometimes when they are first installed they are not put on tight. Over time they over heat and burn at the connectors. If either side is burned that may be your problem. If all connectors are good, you could have 2 possible circuit boards bad. 1 would be the display board itself (the one with the touch screen) or the main PCB board under the control panel in a tan looking cover box.
Mar 01, 2015 | GE Profile Harmony DPGT750EC Electric...
Kenmore dryer 110.8756 has full power to the control panel bt will not start. I can hear the clunk on the mother board.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 14, 2011 | Kenmore 87561 Electric Dryer
Hi I have a wd640 hotpoint aquarius washer/dryer that has stopped working and been told by a fixya pro that it was the main circuit board,and so ordered this assuming it was the circuit board behind the...
hello there is usually a power board sits at the bottom if the machine is dead there a glass fuse that blows just replace the fuse make sure you use the same rated fuse the value will be on the end of the fuse hope it helps
regards
shaun
Mar 20, 2011 | Hotpoint Aquarius WD640 Front Load...
We have a electric, front load electric Duet dryer that was working fine this morning and when my wife went to put a second load in.... it only beeps...nothing else looks wrong on the control...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
heatman101
Sep 08, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Hi, our gas viking dryer overheated and does not want to stay on when start button is turned and released. when button is held ... motor sounds fine. (so it sounds) prior to the problem... dryer did...
heatman101
Sep 07, 2010 | Dryers
Dryer stopped running, wont turn on, i have power to motor, i hooked a meter to the two blue wires on moter and pushed the start button, power is there, but i assume the motor burned up, not 100% sure but...
Dryer Repair ? The dryer will not start
heatman101
Aug 30, 2010 | Whirlpool LER5636P Electric Dryer
Kenmore 94082 gas dryer: Runs a short time, then stops, E9E error
The error code E9E indicates that low voltage is being detected at the control board of the dryer.
This could be caused by the following factors:
* The electrical power supply to the dryer is bad. Check the dryer outlet for proper voltage (120 volts AC).
* Unplug the dryer and check the wiring of the dryer outlet plug. A loose wire on the terminal block could cause this problem.
* If you are able to safely access the control board in the console, check the red wire that connects to the heater relay on the board.
(NOTE: The dryer should always be unplugged when accessing internal components.)
A loose wire or burned connection in this area could result in this error code.
* A failed control board could cause this problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 25, 2009 | Kenmore 67082 Electric Dryer
Whirpool GGw9250Pw3 no power on Control Panel Inside light works
In my case, the problem was a dead main board. The board cost $190 and the overall repair cost $335. I will never buy another Whirlpool due to this experience.
Dec 11, 2008 | Whirlpool GGW9250PL Gas Dryer
Follow up on an earlier problem
I have had the same problem over the past several months. Typically it would clear itself out (clear 8.8. on display) after several minutes. Today it reoccurred but this time it would not clear. I knew it was a problem with the control board. So I removed the control board and discovered that the capacitor for the 5VDC power had ?popped?. I replaced the capacitor and every thing worked! Hope this helps.
Apr 14, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Dryers Logo
61 people viewed this question
Top Dryers Experts
