Question about Brother SE-270D Computerized Sewing Machine
F04 comes up when i plug my foot pedal in - Brother SE-270D Computerized Sewing Machine
  • BJ sewing Feb 26, 2013
    There are 2 things that cause the F04 error. 1 - Wrong foot control: If you have 2 machines, you might have them mixed up between machines. 2 - Burned out foot control. Bring the machine to a Brother shop; try the new foot control on your machine before you buy it. The part number is XC7290051 Alternative Part Numbers Include XC6651321, XC6651221, XC6651121, XA3931051, XC1154051 & XC6651051
  • Brother Master
  • 7,365 Answers
Either the computer part of the machine is messed up or
there's something wrong with the foot pedal
Posted on Feb 24, 2012
Foot pedal isn't working
if the foot pedal is plugged in correctly, you may need to replace the foot pedal or have the plug that the foot pedal plugs into checked
Feb 29, 2016 | PfaFF Sewing Machines
How can I unplug the cord of the foot pedal without breaking it?
In my experience they all come with the cord attached to the foot pedal and you plug one wire into the mains outlet and the other lead into the sewing machine. You should be swapping like for like, so if your has a hard wired lead, then the replacement should too.
If you unscrew the screws on the foot pedal, you should be able to see if it is hard wired or the wire is in a socket. If it won't come out, it is possible it has got hot and melted the plastic to lock it in place.
Feb 04, 2016 | Sewing Machines
How do I fix my singer 6333? I plugged it in the light comes on the foot pedal is attached but no air coming the machine to the foot pedal therefore no sewing action how do I fix it?
There are some sewing machines that the foot pedal is driven by air pressure. Sometimes they will develop leaks so the air does not build up enough pressure to activate the machine. You might see about finding a replacement foot pedal--however if that is not the problem, you may waste your money. Perhaps a sewing repair shop can help you.
Oct 28, 2015 | Singer Sewing Machines
What can I do the foot pedal of js 1022 is not working.
check to make sure the foot pedal is securely plugged into the machine and there could be something wrong with the foot pedal
or the motor could have a problem,, the machine probably needs to be checked to see what's wrong with it..
Dec 19, 2014 | Sewing Machines
What does error code F04 mean something with foot pedal? It is really hard to plug in. Could I put WD40?
the receiving plug would have something wrong with the pins in it or the foot pedal plug could have something wrong with the pins in it,, it would be better to have a sewing technican look at the machine.. don't use wd 40 on the plug
Dec 14, 2014 | Sewing Machines
Nx400 error message F04?
I had the problem with the error code F04 and found out that it is your foot pedal for the machine. Unplug it and it should start right up as ours did.You will need to fix or buy a new foot pedal. When they repair and or clean your machine they don't use your foot pedal but they use their own so they will miss the broken foot pedal.
I hope this helps you.
Bob
Jan 19, 2011 | Brother NX-400
What is err code F04
It most likely is your foot pedal. Unplug your foot pedal and start the machine without it. If it works properly without the foot pedal plugged in then your foot pedal needs repaired or replaced. This worked for us with the NX400 machine and I am sure the NX450 is closely similar. Don't bother to buy a Manual if you didn't already get one with the machine. A Service manual and parts manual is best; But just so you know they don't show the error codes unless you are a qualified and authorized repair person for the machines. I got my info from the repair man where my wife buys and repairs her machines. I am an electronic technician and mechanic so I understand how this system works. I will be repairing my wife's machines from now on.
Aug 21, 2010 | Brother NX-400
Fo4--What does it mean and where do I find the translations?
F04 is foot control error. It is probably a bad foot control, but it may be the plug in on the machine or a circuit board.
You can run the machine without a foot control for now; just unplug the foot control from the machine and use the Start/Stop button like you would when embroidering.
Before replacing the foot control, you should bring the machine to a Brother shop and try a new control. If the new one works, then the control was the problem.
Aug 03, 2008 | Brother SE-270D Computerized Sewing...
Brother SE-270D Computerized Sewing Machine Logo
131 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
