Question about Cameras
Camera wont turn, I have checked that battey its got power to it, terminals are clean. Dont know what else to try.
  • gayebee Jan 08, 2009
    camera won't stay turned on, message says "replace bateries" even after I have replaced batteries with fully charged batteries.
  • 849 Answers
Replace the batteries.
Posted on Oct 28, 2008
Mastercool accu-charge 2 scale
Are the terminals where battey connects clean if not they wont make the connection
Jun 01, 2016 | Mastercool MSC98210A AccuCharge II...
2006 ford explorer wont start and lights wont work on outside or inside. I hear a clicking sound on the inside under dash. The battery is fine checked it what else could it be?
Since your battery is fine and you hear a clicking sound there is a problem getting the power to the rest of the systems on the vehicle. That clicking noise is your starter that doesn't have enough juice to get it going. This may be something as simple as dirty or rusty terminals, a bad connection between the terminals and the cable or even bad battery cables. The ifrst thing you should do is take off your battery terminals and clean them clean them and also while you're at it take a look at those cables to make sure they aren't obviously damaged. Reconnect the terminals to the cables and battey and see what happens. If it doesn't work, you'll need to have a professional look at it.
May 13, 2011 | 2006 Ford Explorer
My car wouldnt turn over..so i got it jumped..it worked 4 two day and now wont turn over agai.
This sounds like a bad battery. Remove the battery and take to to your local auto parts store to have them check it.
Dec 29, 2010 | 2006 Chevrolet Impala
Wont turn on
Check on the battery for voltage, if not charge and try again. make sure the contacts are clean and the terminals are tight.
If not you will need to open the set to check for failure in the power supply within the camera. Check for open fuse links ,failed regulator or a faulty control panel.
Dec 18, 2010 | Kodak EasyShare C1013 Digital Camera
The lens part of the camera wont come out like normally when u turn the camera on, it pops out but its not
This is caused due to in-sufficient power, check the battery for proper functioning and charge, try cleaning the battery contact terminals.
Jun 17, 2010 | Samsung SL102 Digital Camera
Even if the battey loaded there is no power when i press the on/off butten
Try cleaning the battery contact terminals to remove any oxidation/moisture and assure firm contact, check whether the battery is not weared out, if the battery has changed its shape then it has been damaged
Jun 17, 2010 | Canon IXUS V2 Digital Camera
Camera wont turn on
This problem is frequently due to either weak/defective batteries or corroded battery terminals inside the camera. Make sure that you have fresh/fully charged batteries in the camera. If the problem persists, remove the batteries and wipe the terminals with a soft cloth (heavy corrosion may require a fine wire brush, steel wool, or sandpaper). Remove any residue left in the camera by the cleaning. Clean the terminals on the batteries in the same manner, and then replace them in the camera. This cures most problems, but if it doesn't work for you, check the Kodak troubleshooting guide at:
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
It uses a simple Q&A format to diagnose problems and propose solutions.
Aug 12, 2009 | Olympus FE-370 Digital Camera
I have a Kodak M1073 IS digital camera, it's somewhat new and all of a sudden, when i try turning it on, it'll turn on for a second, flash a yellown/green to red light and then turn off. I dont know what...
This problem is frequently due to either weak/worn out batteries or corroded battery terminals inside the camera. If charging/replacing the batteries does not clear the problem, remove the batteries and wipe the terminals with a soft cloth (heavy corrosion may require a fine wire brush, steel wool, or sandpaper). Remove any residue left in the camera by the cleaning. Clean the terminals on the batteries in the same manner, and then replace them in the camera. This cures most problems, but if it doesn't work for you, check the Kodak troubleshooting guide at:
Jul 08, 2009 | Kodak EasyShare M1073 IS Digital Camera
2002 nissan altima it work turn over
you need a light tester to see ifthe starter is getting power and when you turn the switch to see if it is working the solinoid without this informantion there is no way to help you trouble shootthis issue.
Jun 28, 2009 | 2002 Nissan Altima
One day camera just stopped turning on.
Try the following:
1). Check batteries whether they are fully charged.
2). Check with Battery terminal are clean. You can clean them with a ear bud using some alcohol or spirit. Wipe the battery terminal with a clean dry cloth.
3). confirm that the memory car slot/battery cover is securly closed.
4). Reload the battery several times. This will also remove poor contact between camera and battery terminals.
5).Check battery are loaded in the correct direction.
If the probem persists, you might need to take it to the service center.
Mar 02, 2009 | Casio Exilim EXZ1050 Digital Camera
Cameras Logo
64 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
