Question about Aiwa Audio Players & Recorders
I need to know the speaker wattage for my AIWA SXWZL500
I have Speaker system aiwa SX-WNT9 Speakers 2 nos.Impedance 6 ohms/6 ohms.kindly tell me how me how much watt capacity amplifier is required for good sound.
Wattage is not the total solution to the problem. The amount of wattage an amp supplies is related to how loud you listen to the music AND how much power is left over so the amp can deliver when needed and not clip the available output signal and cause distortion.
Apr 07, 2017 | Audio Players & Recorders
I have a aiwa cx nhmt75 home theater system which the surround sound rear speakers I believe model # sx-r275 for them has been misplaced or destroyed could you tell me what speakers can be used in place of...
You should be able to use any decent pair of speakers with an impedance between 8 Ohms and 16 Ohms and maximum power capability of at least 33 Watts. The link provided is for the specifications page of the owner's manual.
http://audio.manualsonline.com/manuals/mfg/aiwa/cxnhmt75.html?p=31
Aug 28, 2017 | Audio Players & Recorders
Awia Stereo shuts off when volume is at 25+
That's the system's way of protecting itself from a burnout *(like a fuse). If you are not using the system's recommended speakers, this will continue to happen.
So, I'd highly recommend that you do some research, look for the manual, and get the correct speaker ratings. You might have to custom build your boxes, but, it will sure stop that problem.
Oct 19, 2012 | Aiwa NSX-DS55 CD Shelf System
Hi there i jus wanted to know if the aiwa lcx 337 k has RCA connections so i could connect my mixer to it, and also if i could run 200 watt technics speakers through it aswell? cheers
No external tape loops. This is NOT a component system in the usual sense.
Wattage is not THE major consideration, impedance is.I can't find any documentation on this product but these small units are usually spec'd for speakers with less than 8-ohms to tweak the power output figure at a dreadful distortion level. All other things being equal, 8-ohm speakers would require more power so you'd have to crank it more. Overdriving any amplifier (like this one) will create speaker-killing distortion.
Jun 28, 2011 | Audio Players & Recorders
Aiwa sx-ns552 specifications
Go online, look up the Aiwa website, pull up the model.
Apr 11, 2010 | Audio Players & Recorders
AIWA TS W35U manual >speaker,subwoofer hookup
YOU SYSTEM HAS TO BE DESIGNED FOR A SUBWOFFER, SHOULD HAVE A CONNECTION IN THE BACK RCA JACK THAT STATES SUB WOFFER
Apr 19, 2009 | Aiwa Audio Players & Recorders
Need to know how to wire Alpine 12" 1242D 4ohm Want to use 1 speaker in ported box with Phoenix gold 2200pro amp
As long as the total wattage of the amp does not exceed the total wattage of the speaker, you can bridge the amp. To do this, put the positive wire of the speaker on the positive terminal of channel 1 on the amp, and the speaker negative wire on the negative terminal of channel 2. This allows you to run the amp's full power into one speaker.
Aug 02, 2008 | Alpine Car Audio & Video
Need info
how much power "wattage" does your speakers have and mtx is too powerful right? so need a good quality speakers. reply me with the wattage of the amp and the speakers.
Jan 15, 2008 | MTX 3002 Car Audio Amplifier
Aiwa HT-DV1
cuse u need to go back form the tvs out to the dvds input thers no way it knows cuse u have no signal form tv bakc to it or form cable bocx rca out puts to the awia ins rca on input 2 ok or aux in
Jan 10, 2008 | Aiwa HT-DV1 System
50 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
