Question about Dremel 112001 Dremel Driver Cordless Screwdriver
Dremel driver battery fix - Dremel 112001 Dremel Driver Cordless Screwdriver
  • jonathan sanders Feb 23, 2012
    battery will not charge.
How to troubleshoot a problem on a Dremel battery charger ?
These are not user serviceable. Return it to Dremel, a Dremel service center in tyour area, or if it was recently purchased to the seller and request an exchange.
Feb 08, 2015 | Cell Phones
New Dremel 7700 not working on higher speed
I'm having the same issue. Can't find any more nformation to fix it
Jun 21, 2013 | Dremel 7700-1/15 7.2V Cordless Two-Speed...
Have Dremel MOD 395 motor runs and speed control works bot shaft won't turn--worth fixing ??? and how
Hi Larry, The tool that you require parts for was discontinued many years ago. Limited parts are available from Dremel. Inside the tool is a flex coupling and spline driver. The flex coupling is # 2615294309 and the price is about $ 1.25. This is the hollow plastic sleeve about 1" long with grooves on the inside, that goes between the motor shaft and the output shaft. The spline driver is # 2615294308 for about $ 1.00. Spline driver sits on the direct end of the motor shaft. The flex coupling sits over the spline driver. Spline driver is about 1/4", hard plastic with grooves on the outside. Total shipping for orders under $ 5.00 is $ 2.50. Orders over $5.00 is $ 4.00. There could be a tax charge depending on which state you live in. Here is how to order: Call Dremel Customer Service at 1-800-437-3635 , Monday-Friday from 7 am to 6 pm central time. VISA, MasterCard or Discover to place a Visa, MasterCard or Discover order. To order by mail: Dremel 4915 21st Street Racine, WI 53406 USA 1-800-437-3635 ext. 3636
Feb 14, 2013 | Dremel Variable - Speed Multipro Rotary...
Dremel charger model 856 won't charge. Charging light will not come on.
I had a similar problem. I was going to take the charger apart but I ran into triangular socket head screws so in desperation I gently bent the 5 contact wires out from the battery socket. After slipping in the battery and plugging the charger into the wall socket, the charging light returned. The charger contacts that come into contact with the battery are easily pushed back and after a few battery insertions fail to make contact with the battery.
Feb 10, 2013 | Dremel 10.8V Lithium-Ion Cordless Rotary...
Where can you find a Dremel model 780 battery
I'm not sure why but, the Dremel 9.6 volt battery is only available through a Robert Bosch retailer or authorized service center. Their homepage is at www.boschtools.com/Pages/default.aspx where you can search for the nearest service center under the 'Service' tab.
Jul 12, 2012 | Dremel Drills
Did not receive manual in my box, for Dremel Driver 7.2v model # 1120-01, how could I get a copy. thanks mark
go to Dremel.com and they can get you one if they are not available online at that site.
Jan 20, 2010 | Dremel Drills
Dremel 398 is dead as a Dodo.
I would contact Dremel direct at 1-800-437-3635 or Dremel.com and talk with one of their techs about this tool. Let me know if this doesn't work
May 15, 2009 | Dremel 3981 - 01 Electric Rotary Tools
Model 800 Dremel cordless won't work
try putting the battery in the charger with the power turned off (unplugged from wall socket ) leave over night then start recharging fresh and dont disturb for 10hours after 10 hours see if any better hope this helps glenn.........
Nov 16, 2008 | Dremel 8000 01 Cordless Rotary Tool Kit...
Dremel 112001 Dremel Driver Cordless Screwdriver Logo
80 people viewed this question
Top Dremel Drills Experts
richie46
Tom Chichester
Are you a Dremel Drill Expert? Answer questions, earn points and help others
