Question about KitchenAid Refrigerators
Kitchen Aide, model Ksbp25fkss02 is causing vegetable bin to freeze products
  • KitchenAid Master
  • 4,654 Answers
This sounds like you have a bad 2188820 Thermistor on your freezer vent. Either way it will take someone a little time to decide which side is controlling correctly (freezer or fresh food section cold controls) It may pay to find someone that don't mind a little time locating which one is causing the problem. Here is a PDF Service Manual go to page 16 and begin reading. I will be here later today to answer any questions you may have, Thank You, Sea Breeze
Ksbp25fkss00 Freezer Liner Parts
Posted on Feb 24, 2012
Testimonial: "Yes, it was helpful but I a, still not sure how to proceed and determine which side (freeze or fresh food) section to start with. The freezer seems to working correctly. Any idea how to start the process of elimination? If I were to sell this refrigerator as is, what would a fair price be?"
  • 1 more comment
  • Frank Figg Feb 27, 2012
    Seabreeze: Thanks for the Service Manual. This is a great resource to have.
  • John Tripp
    John Tripp Feb 27, 2012
    Thank You for your Rate! Get your OHM meter ready disconnect the power and read the ohms on the Thermistor. It will take patience and a little time so if you need my help you may run out of room here. Get my emai from top of my web page. You are probally going to need it. I will help out and even assit you on phone eliinating what is causing the problems, Thanks John Tripp
  • John Tripp
    Infact go to page 54 of PDF and start self diagnostics, JT
aborcass
  • 2651 Answers
SOURCE: Vegetable section too cold, freezing the vegetables
if youd like you can remove the affected crisper, locate the "adjustment slidelever" and remove it, behind there youll find a hole(which is what youve been restricting to lessen the cold air flow.) try wadding up a ball of perma-gum, window sealer, some sorta plug forthe hole, its not nessecary for function of refrig, only to make the crispers colder, but usually too cold. blocking of fthe hole willl make the crispers only as cold as rest of refrig
Posted on Mar 28, 2009
  • 531 Answers
SOURCE: kenmore elite trio 24.8 model #596.76603600
may be is the board or or refrigerator door is (ajar)
Posted on Apr 07, 2009
  • 10865 Answers
SOURCE: vegetables are freezing inside vegetable bin
Most likely your refrigerator is set at too cold a setting. Just turn the temperature adjustment to a warmer setting.
Posted on May 03, 2009
  • 10865 Answers
SOURCE: My food in my vegetable bin is freezing.
This is a common problem that often doesn't have a clear, permanent solution. The first thing to check is the overall internal refrigerator temperature (see the Appliance Accessories section for a refrigerator/freezer thermometer). The proper temperature should be between 35 and 42 degrees. Here are some things to try:
  • If your refrigerator temperature is closer to 35 degrees, try turning the temperature up slightly.
  • If you find that the temperature varies a lot from the top shelf to the bottom (where it is coldest), try putting produce and other sensitive products on a higher shelf.
  • If the temperature is too low and you can't make it warmer by adjusting the thermostat, you probably have a defective thermostat. If so, you need to replace it, because they cannot be repaired. Other possible problems are a leak in the sealed (refrigerant) system, cold air migration (in side-by-side models) or a defective air damper. These problems can be quite difficult to locate and correct, we recommend you contact a qualified appliance repair technician.
Posted on May 20, 2009
woodchuck789
  • 4070 Answers
SOURCE: vegetable crispers freezing my vegetables
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Posted on Dec 17, 2009
Vegetables are freezing in lower bin Model # rs22aqxmq
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Apr 20, 2011 | Roper Refrigerators
Freezing in refrigerator compartment - particularly in the back and vegetable bins. Not sure if this is my model.
Hi, There can be many reasons why your refrigerator is freezingyour food. To see what could be happening and to figure out how to possibly fixyour problem. Take a look at this tip which contains many of the causes andsolutions to fix the problems.
Refrigeratoris Too Cold and Freezing Food
heatman101
Apr 05, 2011 | Amana ABB1927DE Bottom Freezer...
My vegetables are freezing in the vegetable/meat bin. How can I keep them from freezing?
Check your settings for your thermostat. Turn it down in increment's one letter or one number at a time. Higher letters and numbers normally mean lower temperature. Also, the veg bins have settings also.
Feb 13, 2011 | Kenmore 57029 Side by Side Refrigerator
Vegetables in fruit and vegetable bin is freezing.
I solved my problem by going someplace that wasn't going to charge me!
Jan 07, 2010 | Amana AFD2535DES French Door Refrigerator
Water is collecting under fruit and vegetable bins and then leaking out onto kitchen floor.
sounds like a problem with defrost drainage system. would need model #. older GE refs had problem with rust holes in drain trough. how old is it? do you see any rust on back wall of ref? newer refs had problem with drain hole freezing shut and heat probe had to be installed to prevent it from freezing shut.
Jan 05, 2010 | GE Profile 24.7 cu. ft. Top Freezer...
Vegetable crispers freezing my vegetables
Dec 17, 2009 | Refrigerators
May 20, 2009 | Refrigerators
Vegetables are freezing inside vegetable bin
May 03, 2009 | Refrigerators
Too cold in vegetable bins
Air flow ports adjusted correctly? Air flow fan running? I once had a bad temp sensor on the freezer coil that would not let the fan run.
May 29, 2008 | Amana ABB2227DE Bottom Freezer...
Refrigerators Logo
389 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
