POWER STILL GETTING TO TOWER ,CHECKED ALL CONNECTIONS , NO DAMAGE TO CABLES , WHEN MONITOR IS SWITCHED ON , THE POWER BUTTON GOES GREEN FOR 2 SECS THEN THE WARNING MESSAGE COMES ONTO THE SCREEN FOR ANOTHER 2 SECS , BEFORE POWERING BACK TO ORANGE COLOUR .
-   power is supplied to both monitor and computer, however I keep getting a "no signal" on my screen and have tried multiple 15 pin D-sub cables without any luck. what is going on???
-   pstringall
Oct 29, 2008
-   My monitor turns on for a couple of seconds(light green) the it goes off (light is orange) how do I fix this?-   Guest
You first take post( power on self test) connect power cord & disconnect signal cable you will see massage no signal check siganl cable then problem will be in cpu this problem may be solved by cleaning dust in cpu if montor shows no display then problem will in monitor open it check o/p of smps if not disolder path of eht if o/p comes then eht is faulty replace it
i have windows xp and when i try to dl the drivers it says i need vista OS..is there any where i can...
(More)
i have windows xp and when i try to dl the drivers it says i need vista OS..is there any where i can dl the drivers for my windows xp
For turn on my Samsung I have to push power button 15-19 time.Couple months ago I pushed 12...
(More)
For turn on my Samsung I have to push power button 15-19 time.Couple months ago I pushed 12 times.Now i have to push 19.
Can't get middle monitor to display anything or power off using power button on back of monitor. Can...
(More)
Can't get middle monitor to display anything or power off using power button on back of monitor. Can disconnect it and it shuts down (of course) but when I reconnect it I have no control using it's own buttons. I am guessing there's a power board inside the monitor that is defective. Sound right?
