Question about Panasonic DMR-E75VEG-S DVD Recorder/VCR
Recorder Problems Does not recognize blank disc to record on. The recorder only recognize disc have been finalized. Thanks Amrool Khan
  • 6 Answers
SOURCE: remote no longer controlls recorder
Remote can be used to control more than 1 recorder, on the remote press enter and 1 simultaneously, this should switch the remote to control dvd 1.
Posted on Oct 27, 2007
SOURCE: Can't Finalize a disk on Panasonic DMR-EH60 DVD Recorder
It sounds like you haven't selected DVD first. When dubbing to DVD, you need to do this in HDD mode. When finalizing, you need to be in DVD mode for the finalizing options to come up.
Posted on Apr 05, 2008
  • 3 Answers
SOURCE: DVD recording problems
I have the same unit with the same exact problem. I ended up taking it in for repair and it's now working perfectly. I paid $100 for the repair. I dropped the unit off and picked it up myself. I think $30 additional is charged for shipping and handling in US.
1590 Touhy Ave
Elk Grove, IL 60007-5319
Part Number
Posted on Jun 28, 2008
  • 39 Answers
SOURCE: Panasonic DMR-ES10 DVD Recorder- does not read discs
this unit has an optical-eye, not recording heads. opening the drawer then unplugging unit will expose the eye. never look into the eye when unit has power. this x-ray can and will burn your owh eyes lens&retina. good luck. clean with 90% isopropyl alcohol and q-tip. mch
Posted on Mar 09, 2009
  • 17 Answers
SOURCE: Problem with Panasonic DVD Recorder DMR-ES15
With a soft cloth, clean the 'hole' area of a DVD that you know worked in the past. Sometimes oils from our fingers get on the disc and then the disk can't spin properly. If the problem persists, open the case and look for two failed capacitors. (See similar solutions on this website.)
Posted on Sep 09, 2009
  • 267 Answers
SOURCE: The dvd recorder will not recognize any discs. It
Hi! there are many reasons why a dvd is note reading. 1. dirty pick up lens, 2. defective spindle motor, 3. defective ribbon wire, 4. defective pick-up lens and defective mpeg board. but first things first try cleaning your pick-up lens with a cd lens cleaner.
Posted on Oct 16, 2009
0 characters
1 Points
Disc load problem
DVD players need a finilized disk. When the program finilizes the disk, it's writing the TOC which is where the players go to find the files.
Mar 12, 2014 | Toshiba RD-XS34 DVD Player/HDD Recorder
DVD Recorder is ruining the DVDs
Here is the link to the manual for LG DR1F9H
read pages 33&34
you may be using wrong
disc or wrong mode
Dec 13, 2007 | DVD & Blu-Ray Players
Did you finalize the disc on the DVD recorder that burned the file? Without more information on your DVD recorder, I can't give you exact directions to find the command on your unit. On my DVD/VCR, after recording, I usually finalize a disc before removing it from the recorder. On mine, I press Menu and go to Disc. I add a title (optional) and then select the Finalize option. Then accept the finalization (which makes it impossible to add more to the disc). For -RW discs, you can unfinalize and then reformat them. Write once discs are permanently stored.
What type of disc did you record to? Some other players may not recognize DVD+R or DVD-R discs or DL discs. Check the specs on the other players and try different brands/types of discs for future recording.
If you add a comment with the type of DVD recorder used to burn the problem discs, I may be able to give additional advice.
Oct 25, 2011 | DVD & Blu-Ray Players
How to finalise dvd recording
Press the menu button on your remote - go to finalize disc - follow instructions. Note that VR discs can be played with many if not most DVD-players without finalizing. In fact I have had problems finalizing and unfinalizing discs back and forth. If the disc manager displays only unfinalize disc, the disc is already finalized.
Feb 05, 2009 | Samsung DVDR120 DVD Recorder
Recording error
mine was doing the same thing.and we found out that if you recorded something and dont finalize it will not recored anything else till you finalize what you recored then it works again
Jul 07, 2008 | Philips Magnavox MWR10D6 DVD Recorder
Can anybody help me, I purchased a Samsung dvd recorder model dvdvr350m, since purchasing the unit it will not recognize that it has recordable dvd's in it (dvd-rw),it tells me no disc inserted please...
Did the sales guy use the same DVD-RW that you did? Maybe the brand you are using is not of good quality and can not be recognized by the recorder. If he did not use the same disc did you notice if he used DVD-RW or DVD+RW? Some DVD-Recorders only recognize one or the other but this is kind of rare these days. I recommend verbatim brand discs. They should be available for sale at any shop. If you want the ultimate in quality DVDs then go with Taiyo Yuden. This Japanese brand invented recordable media and in addition to that they are obsessed with quality. is always where I get my discs.
Thanks for reading!
Hope this was helpful
Apr 30, 2008 | DVD & Blu-Ray Players
Can't finalize disc
You could use your home computer to finalize the disk.Nero will do it.
Mar 17, 2008 | Philips Magnavox MWR10D6 DVD Recorder
Recordes but dont play back
before you can watch a recorded DVD on another DVD player you must finalize the disc. to finalize the disc put the recorded disc into the DVD recorder, when the DVD loads it will show the titles that are recorded on the DVD on the screen
push the stop button it is the button with the square on it. the screen will go blank or it may let you watch whatever tv channel you are on if you have your tv ran through the recorder, push the setup buton a new screen will come up, with the arrow down button scroll down and highlight disc edit, press ok another screen will come up, with the arrow down button scroll down and highlight "finalize", press "ok" it is the button in the middle of the arrow keys
scroll up and highlight "yes" press "ok" the recorder will finalize the disc and it can be watched on any DVD player, just remember when you finalize a disc you cannot add anything else to the disc.
Mar 02, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
Samsung R155 Recording from VHS Issues
The reason why you are having this problem is because you haven't finalized the disc. In able for you to play that Burned DVD that you have you need to Finalized the disc. Finalizing a recordable optical disc means writing the disc's lead-in (the Table of Contents or TOC) and lead-out information (blank data that fills up the unused space at the end of the disc) so that a DVD player will know where the various tracks begin and end. Without the TOC, a conventional DVD player will not be able to read the contents of the disc. Once the disc is finalized, no more information can be written to it. Finalizing takes about two or three minutes. To finalize a DVD-RW/DVD-R: 1. Press the Menu button with the disc stopped. 2. Select Disc Manager and press Enter or the right arrow. 3. Select Disc Finalize and press Enter or the right arrow. You will be asked twice if you are sure that you want to finalize the disc. Select Yes and press Enter. Once the disc is finalized, you cannot delete entries from the record list. After being finalized, the DVD-R/DVD-RW (video mode) operates in the same manner as a DVD-Video. Recorded discs must be finalized in order to play back in non-Samsung DVD players. A DVD-RW disc that has been recorded by DAO (disk-at-once mode) in a PC cannot be unfinalized. A DVD-RW disc that has been recorded in Video Mode on a non-Samsung recorder cannot be unfinalized by a Samsung recorder. A DVD-R disc cannot be unfinalized. Note: Finalization does not apply to DVD-RAM. If you cannot finalize a DVD-R or DVD-RW disc, make sure that Disc Protection is turned off. If you are still having difficulty, you may try calling technical support of SAMSUNG. Note: Do not turn the recorder off while it is finalizing the disc. Data on the disc will be damaged if the finalization process is interrupted.
Sep 17, 2007 | Samsung DVD-R155
Panasonic DMR-E75VEG-S DVD Recorder/VCR Logo
26 people viewed this question
Top Panasonic DVD & Blu-Ray Players Experts
Are you a Panasonic DVD and Blu-Ray Player Expert? Answer questions, earn points and help others
