Question about HP Pavilion zd7000 Notebook
I have black screen
I shut down and never turn on the monitor even his sound look well but nothing on screen what ever i do even with fn or alt f8 and other
  • HP Master
  • 32,281 Answers
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Posted on Feb 24, 2012
4 Suggested Answers
  • 154 Answers
SOURCE: screen dim HP pavilion dv1000
The lid actuator switch may not be working correctly. It's a small switch above the keyboard and led's on either the right or left side. Try pressing it 2 or 3 times to see if the display starts working correctly again. If so, it will need to be replaced.
If that doesn't work, you can also turn it on with the ac adapter plugged in. After it boots, press the power button and hold it in until it shuts off and then turn it on again and see if the display has returned to normal.
If neither of these options work, your laptop may need to have the backlight replaced.
Posted on Aug 13, 2009
SOURCE: Hi, I was using my HP Pavilion notebook with Vista
I have an HP pavallion DV 6000 it about 2 yrs old and the cd rom has quit working.. Any ideas?
Posted on Dec 29, 2009
  • 36 Answers
SOURCE: The screen remains black when computer is turned
maybe a hardware problem, on booting the pc, move the screen to every angle to see if there is a connection problem.
If so, then use your warranty if you have one.
Posted on Jun 13, 2010
No display upon turn on
Did you press and hold the FN function key plus the key that toggles the display? In your case it might be the FN+F8 if F8 is the key that toggles the display.
Shine a flashlight on the dark screen to see if you barely see the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If the video shows on the external monitor that proves your video card is ok, ,but your lcd screen is bad. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works, then your screen is bad. If you see no icons by shinning the flash light and nothing shows on the external monitor, then most likely your video card is bad.
If your video card is bad you will not see anything on the laptop's lcd screen or the external monitor.
Jun 10, 2012 | ASUS Eee PC 1005HAG Notebook
Toshiba A305-s6858 black screen
I have same problem with HP laptop, one of the things i did the first time was to take off the battery and press on/off button for twenty seconds, put the battery back and turn it on. That works for me and i hope to help you.
THX.
Apr 25, 2012 | Toshiba Satellite PSAG0U-02D00M Notebook
Jun 13, 2010 | HP Pavilion dv1000 Notebook
Dell latitude830 completely black screen even on external monitor, took out hard drive and put in pc,was able to retrieve data to be clear i get absolutely nothing on the lcd or the external monitor...
Sounds like you need a new video card. Thank goodness you were able to retrieve your data. The new USB flashsticks are great for backups.
Good Luck
Sep 13, 2009 | Dell Latitude C610 Notebook
I'm having an IBM notebook in the house, when u turn on power nothing comes on the screen...? what should i do
Does your sound work? If so there is a button on your keypad that allows you to toggle your screen source back and fourth between Projector/monitor and laptop. The icon looks like a monitor and usually you will have to hit your "FN" (Function) key along with pressing the monitor key. On most laptops it is F8 - so you will need to press and hold the FN key and press the F8 (or key with the picture of the monitor) and toggle through until you get your screen back.
Good Luck and feel free to rate me..
Happy Holidays..
Dec 24, 2008 | Computers & Internet
Dell Inspiron 1501 black screen
Post the error codes that are given and I'll be able to tell you what's going on exactly.
Jun 19, 2008 | Computers & Internet
No Signal
You have to use the FN key and F5 to change between the LCD screen and the external monitor. It may be F8 also, depending on the laptop model.
Look on the F keys for a little picture of a monitor.
Once you have found it, hold the FN key and tap the F key and it should switch to the external monitor.
Jan 18, 2008 | Liquid Video E15LCD1 15"
Computers & Internet Logo
29 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
