Question about Frigidaire Dishwashers
My Dishwasher do not evacuate
MODEL No FPHD2481KF1
  • 3 more comments
  • Electrolux
    Electrolux Feb 24, 2012
    Can you be more specific? Does the unit not drain? Do you have any standing water in the bottom of the unit, or hear any unusual noises?
  • Federico Aoun Feb 25, 2012
    The unit doesn't drain and I have standing water in the bottom; no unusual noises.
    Thanks.
    The electronic panel works until the draining.
  • Electrolux
    Electrolux Feb 27, 2012
    Do you notice dirty or clean standing water?
  • Federico Aoun Feb 27, 2012
    Thanks i resolved the problem it was a piece of glass in the blades of the pump.
FPHD2481KF1
Thank you for your post, nansie Bento!
Based off the information you have provided your Frigidaire dishwasher is flashing "ER clean S". That error stands for a membrane switch failure, which means that your main control board has detected a key stuck or pressed in for more than a minute. You can push all the buttons down to attempt to locate the key that is stuck. It could be a potential issue within the keypad or main control board. You could try to clear the error code by resetting your appliance, which can be done by flipping the household circuit breaker for roughly ten minutes. Hopefully this is helpful. -Matt
Aug 24, 2014 | Frigidaire Dishwashers
Bosch Model shu9925uc/u12 not draining throughout cycle. Dirty, soapy water left in bottom of dishwasher at end of cycle. Help!
ensure filter in bottom of machine is not blocked. if clear
suspect blocked pipe or defective evacuation pump.
i hope this was helpful
Dec 12, 2010 | Bosch SHU9925UC Built-in Dishwasher
Hello, My Bosch she44c dishwasher is not evacuating the water from the machine. I checked the line and i can hear the motor trying to pump. I've tried to make sure the impeller was clean, so at this...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Sep 09, 2010 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Water will not drain .cycle stops , will not start even on new cycle
The water will have to be evacuated first. there may be a blockage either in the outlet of the dishwasher or the drain connection under the sink. The dishwasher tries to drain at the very start of the cycle. If this doesnt happen then a new cycle wont start.
Jul 31, 2010 | Dishwashers
Dishes and glass ware are covered with a light film when done. This problem just started. It appears that there is soap residue left on the contents of the dishwasher. The dishwasher is cycling properly...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Apr 30, 2010 | Maytag 24 in. MDB3700 Built-in Dishwasher
Water pump evacuates water but does not pump in the wash or rinse
You assume correct. The control board switches the direction, but if there's a mechanical problem like a bad start capacitor, then it won't run
Jul 29, 2017 | Kelvinator MDB121RF Dishwasher
Whirlpool gold gu1200
Sounds like glass fragments against the pump impeller. This may jam the impeller and reduce water pump volume giving poor wash performance and possible inability to evacuate the wash tub. It will not go away and may cause the impeller to fail. Remove screens and get the glass out. Do not poke around with your fingers unless you like cuts.
Sep 26, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
D3350 - Code F9
Service manual says:
LED L1+L2/Fault code F7, Pumping out fault
(machines with pressure sensor)
Water not evacuated after 120 seconds’ pumping
out. Programme interrupted.
Check: Drain pump, hoses, installation of drain
hose, control unit and wiring.
Jan 19, 2008 | Asko 24 in. D3350 Dishwasher
Dishwashers Logo
46 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
