Question about AEG Dishwashers
Water is not draining out of my AEG OKO Favorit 4040
At the end of its cycle there is still water sitting in the bottom
TheMazz
  • 78 Answers
SOURCE: The drain pump on the AEG oko favorit 6050 keeps
This can only be the controller.
Only the controller (timer) turns the pump on and off.
If this was helpful, please select YES to the first two RATINGS questions. Good Luck!
Posted on Oct 17, 2009
Testimonial: "very quick, thankyou"
pride applia
  • 232 Answers
SOURCE: I have water in the bottom of my AEG OKO-Favorit
did you take the air gap by the faucet apart they plug alot the fist thing i usually check disconnect drain hose lay it in a pan does water drain, may need new pump
Posted on Dec 27, 2009
Testimonial: "Very quick answer. Great help"
joe_lishman
  • 192 Answers
SOURCE: AEG OKO FAVORIT 6050 trips earth leakge
This is typical of a water leak onto electrical connection OR the electrical element has shorted internaly . Check this with a Ohm meter and itshould show the problem
Posted on Jan 19, 2010
joe_lishman
  • 192 Answers
SOURCE: drain pump keeps running AEG oko favorit
This seems like the anti flood system (polystireen float / micro switch) at the base of the washer is triggered,\. This puts the washer in pump out mode and stops inlet of water via the inlet solinoid. Dry the water on the base and then check for any water leaks. (pipe leak
Posted on Jan 20, 2010
  • 500 Answers
SOURCE: Hi there, Do you have a
Hi ntalbany,
The Part Number is 8996461335607.
It can be found here:
http://www.apart4u.co.uk/dishwasher-drain-hose-aeg.html
Hope it helps :-)
If you found this solution helpfull, please rate my answer.
Posted on Apr 27, 2011
AEG OKO FAVORITE 4070 - AFter not using for a week dishwasher is flashing dry & end together, will not switch off unless turn it off at the power point, there is no water left in the machine.
If the END or DRYING indicator on the programme progress display is flashing, you can probably rectify the fault yourself.
After rectifying an END or DRYING fault, press the button for the wash programme that has been started.
The wash programme continues. If the fault is displayed again, than check water leakage in the battom of dishwasher.
Malfunction: END and DRYING on the programme progress display are flashing simultaneously.
Possible causes: The leak prevention system has been triggered.
Remedy: Try to find and repair water leakage otherwise close the tap and call customer service.
Dado
Mar 16, 2014 | AEG 24 in. Favorit 60870M Free-standing...
Aeg favorit 40010vi dishwasher won't fill with water
I have a similar issue on oko favorit 50700. I have checked the flow from the inlet hose into a bucket and it really seems ok, so I think maybe a problem at the inlet to the machine? Plea update if you get a fix!
Mar 24, 2013 | AEG Dishwashers
Aeg oko favorit 40300 service manual
AEG OKO FAVORIT 40300 When switching dishwasher on no water is flowing into the the dishwasher
Please help
Jan 11, 2012 | AEG Dishwashers
Dec 27, 2009 | Dishwashers
Dec 20, 2009 | AEG 24 in. Favorit 60830 Free-standing...
Have an Aeg oko 4020 dishwasher. Installed a new pump and it worked for awhile. It now won't switch off but the cycles do not run. Someone suggested there maybe water in some area that has caused some sort...
it probably has water in the bottom tray
take bottom front panel off and this exposes the bottom tray
mop out water and machine will run
if fault reoccure then you have a leak
Nov 29, 2008 | AEG Dishwashers
Aeg dischwaher model oko favorite
Nov 15, 2008 | AEG 18 in. Favorit 64800 Free-standing...
Drain pump keeps running AEG oko favorit
Aug 29, 2008 | AEG Favorit 50500 Built-in Dishwasher
AEG OKO-FAVORIT 50800
C3 error means that there is water at the bottom of the dishwasher. Unplug the dishwasher, slide it forwards and push it back. So it stands on the 2 back knobs. Do this atleast at a anle of 45 degrees. You will see water flowing at the floor.
If this happens often you have a leak somewhere. Time to cal the technician then.
Mar 03, 2008 | AEG Dishwashers
Dishwashers Logo
70 people viewed this question
Top AEG Dishwashers Experts
Oloyede Monsuru
Mike
Are you an AEG Dishwasher Expert? Answer questions, earn points and help others
