Question about Refrigerators
Hi, Magic Chef CSD 2123 AR Side by side: too cold - cooling too much
I have turned the temp control to the warmest setting (almost off) and it is still too cold, Thanks a lot Everything else works fine. Thanks a lot for the help
mikedurland
  • 481 Answers
SOURCE: MAGIC CHEF CTF1920ARA - Freezer works, Refrig. portion does not.
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Posted on Jul 04, 2008
SOURCE: Magic Chef MCWC30MCG not getting cold?
the problem is the PTC Starter I disconected on the compressor and disassemble clean it and put them back together I researching were I can find the part, also I going to call Magic Chef to see I can get the part from them.
Please be sure you unplug the power before you do any repair on the Wine Cellar.
Posted on Oct 11, 2008
  • 5 Answers
SOURCE: Magic Chef MCWC30MCG not getting cold anymore?
Replace PTC Starter and that is it. You can also try to open and clean contacts, I did and it worked.
Posted on Mar 30, 2009
SOURCE: MIni fridge stopped working/cool.
I got mine in 2005. It stopped working 4 or 5 weeks ago. It made a clicking noise and the compressor was very hot. Compressor is under warranty but appliance repair shop wanted $125 to install it and another $75 to charge it with freon. I saw a posting somewhere else that said it was a relay switch. I ordered one from RepairClinic.com for $24.00 incl. shipping, put it in and it's working now. There's a black plastic housing on the left side of the compressor. Just unscrew that, pop the cover off (that was a little tricky) and plug in the new part. Maybe I'll get another 3 years out of it.
Posted on Aug 04, 2009
SOURCE: I am getting an E3 Error message on my temp
Do this...
The e3/e4 problem is the "connectors" for the fans to the middle separator shelf are put in the pathway of condensation. This causes them to get wet and rust. PLEASE NOTE: If you decide to attempt this fix, you take full responsibility for your fridge and the outcome. If you don’t think you can do this…DON’T! Call a licensed electrician. Here is how I resolved my e3 issue: 1) Unplug the fridge
2) Remove all wine and the metal shelves
3) Remove the 2 screws from the middle separator shelf, one on each side on top
4) Remove the 4 screws from the backboard, one in each corner
5) Slide out the middle shelf slowly, on the right hand side towards the front of the shelf there will be 4 connectors you must disconnect before removing the shelf (they are tucked into the shelf). With one hand on the backboard and one on the shelf, slowly take them out together
6) Once you have the backboard and shelf out, you'll see there is a black and white connector, each having a red and black wire on each side
7) These are the fan connectors that are causing the issue. Mine were brown/green and damp (not good for electricity)
8) Using wire cutters, cut as close as possible to the "black" connector on each side to remove it. You will have 4 wires left, 2 from the backboard and two from the shelf (both having a red and black)
9) Take some of the sheath (cover) off of each wire
10) Take the red wire from the backboard and the red wire from the shelf and twist the metal portion together
11) Cover w/ electrical tape!!! Or you will have the same e3/e4 issue
12) Repeat step 10 and 11 for the black wires
13) Move onto the "white" connector and repeat steps 8 - 12
14) Put the backboard and shelf back in the fridge. Be careful not to pull the backboard and shelf apart or your connection may come apart
15) As you slide the shelf in, make sure the wires you disconnected in step 5 are in the "channel" on the side of the shelf or the shelf won't slide properly.
16) Reattached the 4 connectors and then re-attach the backboard and the shelf with the screws
17) Plug the fridge back in
18) Put the metal shelves and wine back in
Posted on Feb 08, 2010
HH error code? on magic chef mcbc580dbt
I, too, have just seen (late June 2013) the "HH" code on my Magic Chef wine cooler (and it is running too cold and I can't reset the temperature). Have you found a solution since your posting of about 1 year ago?
Jun 27, 2012 | Magic Chef MCWC30MCG Compact Wine Cooler
Refrigerator is leaking water under freezer, it is a side by side. model number CSB232AR
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 26, 2011 | Magic Chef Refrigerators
Magic Chef fridge, freezer compartment leaks water (side by side). Can't find a drip pan anywhere on fridge.
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 08, 2010 | Magic Chef Refrigerators
The freezer works properly but the lower part doesn't cool would you please help me
Set the freezer control to Warmest.(more air will go to fresh food)
Make sure the freezer fan is blowing.
Check the door seals on fresh food door especially on the bottom.(may be loose letting in warm air)
Aug 10, 2010 | Magic Chef CTB1821AR Top Freezer...
Actually a side by side freezer's way cold but fridge won't cool.....started it 3 hours ago empty
ck the dampner control as it controls the air flow to the fresh food side. also see if the evap fan is working .. inside the freezer side . this blows the cold air to the fresh food side. mm
Aug 10, 2010 | Magic Chef (CSD2610KRW) Top Freezer...
Magice Chef side by side builds up ice on freezer floor
it sounds like a defrost element on the evap. if ice builts up and the elemet is not working then it will build ice on the evap and not cool.....
Jul 27, 2009 | Magic Chef (CSD2610KRW) Top Freezer...
The refrigerator is not keeping cool. The freezer is working fine
HI, ok, you have sated that the freezer is holding a proper temp. this will confirm proper compressor function. there are only two other problem areas that could cause the fridge to not cool properly. the diffuser and, the cold control device(thermastae). Have both components check for there operational value.
The most common issue here will eb a damaged cold control device(thermoste or , control board)
Jul 09, 2009 | Magic Chef CTB1821AR Top Freezer...
Side by side Magic Chef refrigerator. Freezer
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Could also be begining of a defrost problem.
Jun 14, 2009 | Magic Chef CTB1821AR Top Freezer...
Refrigerators Logo
55 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
