Question about RIM BlackBerry Curve 8520 Smartphone
Bb 8520 keyboard does not work and trackpad does not function as enter
My keyboard stopped working. the lights are turned on, but the keys does not respond, I can only navigate with the trackpad but it doesn't work the enter function. this issue started first when my A button stop working then it worked magically after a few weeks and then I started having issues with the letter E. and today the keyboard doesn't respond at all. Please HELP
  • Sabrina Urbina Feb 29, 2012
    Now the whole keyboard is unresponsive. only the trackpad works but I cannot hit enter with it. I tried a hard reset pulling out the battery. and even re-installing the software and nothing happened.
SOURCE: Trackpad on Blackberry Curve 8520 has stopped
i had the same prob with my bb 8520 .. i have got this info 4rm a site n it waz a video telling u how to remove ur trackpad ... i have removed my trackpad according to the video n cleaned the sides n the trackpad .. n connected it carefully ..Now it works Perfectly ! its not hard but its risky .. n now have a look at the video ' http://www.youtube.com/watch?v=-HgLXRgedvI ' believe me it really works :D !
Posted on Apr 07, 2010
SOURCE: Trackpad freezes BB 8520 Options
i know what ur talking about and its so annoying what i do is i take the battery and sim card out and then put them back in and it seems to work only tho it takes forever!!!!
Posted on May 23, 2010
  • 846 Answers
Sounds like your trackpad needs replacement. The part is available on major auction websites for around $10. If you want somebody else to do it for you go to Blackberry Repair. If you want to do it yourself, here is an Blackberry 8520 Repair Guide that shows how to repair a Blackberry.
Posted on Jul 05, 2010
SOURCE: where to enter airtel gprs settings in bb 8520
no net settings available for blacberry 8520
Posted on Jul 14, 2010
aurinje
  • 181 Answers
SOURCE: i just updated my bb 8520 to 5.0, assuming that my
I would have thought if a software update did not fix this issue that it is a fault in the hardware. Contact your network/point of purchase to see if you can get a replacement.
Posted on Feb 03, 2011
Hey can you please unlock bb curve 8520 ...imei:357257.04.904092.1
Hi, You can get the unlock code for a Blackberry Curve 8520 from http://www.unlocking4u.com/blackberry-8520-curve/rs6wp9/ at affordable cost.
Here are the steps for unlocking a BB Curve 8520,
1 - Switch on your Blackberry 8520 Curve with any Sim card and Turn off all Wireless connections.
2 - Go to Settings.
3 - Go to Options.
4 - Select Advanced Options.
5 - Select SIM Card.
6 - Type MEPD using your Blackberry 8520 Curve keyboard (NOTE: You will not see any text appear on the screen while typing MEPD),
7 - Type MEP then hold 'ALT" key and type number 2.(NOTE: You will not see any text appear on the screen while typing MEP2),
8 - You will then be presented with a prompt "Enter Network MEP Code". Type in the Unlock Code and press in the track wheel / jog dial to confirm,
9 - Your Blackberry 8520 Curve will now be unlocked.
Sep 20, 2012 | RIM BlackBerry Curve 8520 Smartphone
How can I reset my blackberry curve8520 myself?
The fastest way to reset your BlackBerry Curve 8520 back to factory settings is to peform a security wipe. it will result in the loss of all user data! It is recommended to perform a backup of the BlackBerry 8520 data. .
To reset BlackBerry Curve 8520 to factory settings: Press the BlackBerry key, Go To Options > Security Options > General Settings > Menu > Wipe Handheld > Scroll to Continue, press the Trackpad. it will reset your BlackBerry 8520 quickly.
Hope this helps, if so do rate the solution
Jan 04, 2011 | RIM BlackBerry Curve 8520 Smartphone
I can not pair my headset HS820 with my BB 8520. My BB does not recognize it...what can i do?
First Ensure that your Blackberry 8520 is in discoverable mode (Settings>Options>Bluetooth) once in Bluetooth hit Menu (the button to the left of trackpad, Select options to turn Discoverable on, once you have done that ensure your bluetooth is in Pairing mode (solid blue light, except Plantronics brand which will alternate Red and blue lights) then have the device search and it should find it, select connect, then enter the headset (typically 0000 unless Bluetooth owners manual says otherwise) and it should pair just fine from there
Hope This Helps!
William
Sep 20, 2010 | Cell Phones
I've got the Blackberry Curve 8520... Yesterday the 'ALT' key got stuck, and wouldn't come off, so i done a battery pull... but when i turned it back on, most of the keys didn't work.... so i cleaned the...
Yes, your never suppose to put it under heat to dry, nor put any type of spray because spray obviously contain water, which kills your phone. So, if even the battery isnt orange indicating 'water damage', the keyboard itself is damaged. If possible, which is the best solution: you should call your cellphone provider and tell them that your phone all of a sudden stopped working, and most likely they will look into getting you a new phone. But dont tell them what you did, because they wont do anything about it after. Also, connect your phone to Desktop Manager on your computer and back up on all your information (phonebook, bbm contacts, ect.) so nothing gets lost, if anything was lost.
Good luck,
sp
Aug 16, 2010 | RIM BlackBerry Curve 8520 Smartphone
Trackpad on Blackberry Curve 8520 has stopped working and whenever the phone is switched on the trackpad heats up considerably.
May 15, 2010 | RIM BlackBerry Curve 8520 Smartphone
How to fix blackberry 8520 app error 523
just wipe it or reload with the new updated OS
May 09, 2010 | RIM BlackBerry Curve 8520 Smartphone
Trackpad on Blackberry Curve 8520 has stopped working, and whenever the phone is switched on, the trackpad heats up considerably.
Mar 30, 2010 | RIM BlackBerry Curve 8520 Smartphone
Track pad not working 0on 8520 blackberry
I had same problem and now solve it :) Just disassembly the phone and check trackpad connector ( just take it off and return on its place ) It will work perfektly :) U can find more videos for replacing trackpad on UTube .
Mar 20, 2010 | RIM BlackBerry Curve 8520 Smartphone
Mar 19, 2010 | RIM BlackBerry Curve 8520 Smartphone
Gateway notebook MX6930 trackpad issue
Has the left mouse button ever worked? If so when did it stop working, make a system restore to that date
Nov 17, 2007 | Computers & Internet
RIM BlackBerry Curve 8520 Smartphone Logo
478 people viewed this question
Top RIM Cell Phones Experts
Computer Repairing
Computer Repairing
Jason
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
