I have a Trane furnace TUC100B948AO, with a White Rodgers ignition control 50E4760. The fan proves and sends 120 volt to the module but does not send120 volts to the ignitor. Any ideas?
When the thermostat calls the draft fan starts, is proven and 120 volts is sent to the ignition module. But it does not send 120 volts to the ignitor.
bobotfel
  • 236 Answers
SOURCE: Duo Therm Air Conditioner Mod. 59136.331/ Control box E 6360360
Something wrong with your thermostat, but if you are using a electronic thermostat and have the indication of supply like light in your control then you can replace the miniature relay that triggers the cool mode of the unit. But no indication of supply try to check the fuse, then if not works you to replace new thermostat.
Posted on Jan 03, 2008
AlmostBob
  • 550 Answers
SOURCE: a carrier furnace
check the relay
the primary should have a low resistance
there should be a distinct click when 24 volts is applied to the primary
the secondary should be conductive when the primary is energized (contactors can corrode)
not a solution something to check
Posted on Oct 02, 2008
  • 124 Answers
SOURCE: I have a Trane gas
almost a classic sign of a bad gas valve. pilot is lit so gas is available. FAN COMES ON AND 24 VOLTS TO gas valve so there is a call for heat . gas valve doesn't open so it looks like its bad.
Posted on Nov 10, 2008
  • 534 Answers
SOURCE: Furnace blows cold air, ignitor won't glow.
ok this is going to sound funny but it seems as though the polarity is reversed going into your furnance. to correct this proiblem you first need to unplug the unit and where the cord goes into the furnance at that connection disconnect the two wires. Once theses are disconnected switch the wires .All you are doing is reversing the way the electricity flows into the circut board. I would wager that is the problem
Posted on Apr 16, 2009
heatman101
  • 43501 Answers
SOURCE: goodman furnace draft inducer motor doesnt start
Using a voltage meter check and see if you have 120 volts at the motor... if so then the motor is bad....
If there is no voltage to the motor then the board is bad....
Replace the motor or board as needed...
heatman101
Posted on Nov 13, 2010
I replaced my fan control board because blower would not work but now heat is not coming on
Double check your wiring on the new board, you may need to jump your thermostat line to the "R" terminal on the ignition controller. There are two sides on the ignition controller. One is for line voltage (115-120) and the other is for low voltage (24). Be sure of these connections and it should be good to go.
Feb 14, 2013 | whiterodgers White Rodgers 50A55-843...
Gibson Furnace, Model #7106250 can not get a flame going. The furnace runs fine but is pumping out cold air without a flame. Any ideas?
On a call for heat, the 24 volt thermostat sends a signal to the control module. The control module will indicate a call for heat with a light on the control either blinking or remain solid depending upon model. The inducer (exhaust) blower will purge all gasses from the furnace and pressurize a pressure switch. Once the pressure switch tells the module to continue, the electronic ignition will energize and send 120 volts to the igniter. The igniter will glow and you will be able to see it if viewed thru the small inspection port. Once the igniter gets hot enough, it sends a signal to the module opening up the gas valve (24 volts). Either a pilot will come on or the burner tube will ignite then spread the flame to all burners. Lastly a safety sensor will be looking for a certain temperature within a few seconds and the furnace will continue to operate and the room air blower will turn on in a minute or two.
What could go wrong? The unit will not run if there is no signal from the thermostat (bad thermostat or broken wire), the control module does not sense a signal from the thermostat (bad control), the inducer does not energize (bad motor), the pressure switch does not close (blocked vent piping, bad switch, plugged condensate hose, Dirty Air Filter), the igniter does not energize (bad control, bad igniter), the gas valve does not open or there is no gas (bad gas valve, broken wire, no gas), the pilot does not light (dirty pilot), the burner does not light (bad burner, plugged orifice, not enough combustion air), the flame does not spread to each burner (bad flame spreader, dirty flame spreader, more bad burners), the flame safety sensor does not detect flame (dirty or bad flame spreader, bad flame sensor, broken wire, bad control), or the room air blower does not energize (bad fan motor, bad control).
Mar 04, 2010 | Heating & Cooling
80% ducane furnace makes several attempts to ignite then shuts down. glow stick lights but no ignition to main burners. any ideas?
What could go wrong? The unit will not run if there is no signal from the thermostat (bad thermostat or broken wire), the control module does not sense a signal from the thermostat (bad control), the inducer does not energize (bad motor), the pressure switch does not close (blocked vent piping, bad switch, plugged condensate hose), the igniter does not energize (bad control, bad igniter), the gas valve does not open or there is no gas (bad gas valve, broken wire, no gas), the pilot does not light (dirty pilot), the burner does not light (bad burner, plugged orifice, not enough combustion air), the flame does not spread to each burner (bad flame spreader, dirty flame spreader, more bad burners), the flame safety sensor does not detect flame (dirty or bad flame spreader, bad flame sensor, broken wire, bad control), or the room air blower does not energize (bad fan motor, bad control).
Check for 24 volts across the gas valve terminals!
Hi i hope you can help. I have a high effeciency furnace and the burners keep turning off.
Feb 16, 2010 | Dayton Gas Furnace Heater
Fan comes one, should hear whooshing of ignition,
Jan 27, 2010 | Goodman Heating & Cooling
My furnace will not shut off on auto. the fan will not run when switched to on. what should I check?
Some new furnaces have a feature that when it has an issue, it starts the room air blower until you reset the thermostat or kill power to the furnace. Not knowing what you have for a system I can offer you only how a furnace works and what you could look for "generically".
Jan 18, 2010 | Honeywell Heating & Cooling
Furnace not kicking on when thermostat calls for heat
Jan 10, 2010 | Heating & Cooling
Furnace does not come hot surface ignitor does not come on
Dec 29, 2009 | Goodman GMS90703BXA Heater
Carrier furnace, pilot does not light, fans run for a couple minutes and then flashes code 31
Nov 28, 2009 | Carrier 38CKC042 Air Conditioner
Heating & Cooling Logo
89 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
