Hisense hdi-101 how to open?
A Hisense Chromebook model c11 has a malfunctioning display. Whenever the screen is opened or lifted up beyond 50% the screen goes blank.
It sounds like there is a loose connection. I would disassemble it and check the cable that runs through the hinge. Make sure it isn't getting pinched or being pulled when the screen is opened beyond 50%.
Feb 24, 2016 | Computers & Internet
Hisense americanfridge freezer RS731N4AC1. Can the doors be removed to fit through standard door frames.
yes the doors are always removable. Also you can open the door and swing the fridge till it will reach second door .Open second door and complete the chore
Dec 28, 2014 | Hisense RS731N4AC1 Stainless Steel 562 l...
How to program key on peugeot 307 hdi 2001
put key in icnition turn on but don"t start engine,press door lock and hold for a few seconds,then turn off,key fob should now work,if not try again,also make sure you have the correct battery in key fob.
Nov 29, 2014 | 2005 Peugeot 307 HDi
How do i do my updates for my elite7 hdi from my computer and getting them to my combo . my computer wont open the download through adobe.
Assuming you are using Navionics, plug your charts memory into your computer log into Navionics and follow the prompts for update
Oct 15, 2014 | Lowrance Elite-7 Hdi Sonar/Gps Combo,...
My Peugeot 206 2.0 hdi 02 plate has main beam and sidelights stuck on after flashing another road user they are still on after ignition is off and key removed. I'm having to disconnect battery to turn
parking relay fused. (stuck)
the car may have 2 or 3 Headlight and parking relays
see which one kills the lamp, and then test it for BAD.
google relay tests.
we dont have Peugeot
so cant wax smart or savvy, so answer is generic. (electr 101)
Jun 27, 2014 | 1987 Peugeot Liberte
Peugeot 307 manual hdi
Check if it has faulty struts.
Jun 18, 2014 | Vehicle Parts & Accessories
TV LCD model hslc8129hdi remote controll not working ,new batterys,still not working,only mute is working (model hdi 100 )
If only one function on the Remote works it probably needs repair of some sort.
Remotes are delicate things which can easily be damaged or broken by dropping them, or by spilling fluids such as soft drinks over the keypad. Old batteries can cause internal corrosion of metal parts. I have repaired some remotes successfully but many were beyond repair. The best solution in event of failure is to purchase a replacement of the original (new or second hand)or a multifunction remote which may have the code for your Tv or other apparatus in its memory,
Dec 29, 2010 | Hisense Televison & Video
Hi, my 307 hdi 2.0 79kw, accelerate to slow, my
Clean/Change air filter, fuel filter, air filter, turbo filter. Clean and check EGR valve and Turbo gate. Check the hdi fuel pressure. Open the injectors and clean it. Give it a try and may be you can save 600 euros.
Oct 17, 2009 | 1987 Peugeot Liberte
Need new remote
Why not phone Hisense and ask them. The phone number number should be listed in your directory and they will tell you where the Hisense outlet is to purches .. and u can ask them about a universal one
Jan 27, 2009 | Hisense TL1700 17 in. LCD Television
Televison & Video Logo
109 people viewed this question
Top Televison & Video Experts
Electro Med Services...
