Question about Samsung RS2630SH Side by Side Refrigerator
Hole in the freezer
I used a sharp object to remove some frozen food stuff, by bad luck there was a hole in the freezer, can the hole be fixed.
  • 40 Answers
If you made a hole in the veins/tubes that carry the freezing chemical, then no, not by you.
Do not inhale this chemical and keep your children away from it.
You must call a professional to fix this because of the metals involved but especially the chemical that runs inside it.
As the chemical drains out your unit will work less and less cold. I do not recommend you leaving it turned on.
I know this next part sounds a bit weird, but if you have any bubble gum, chew some up and stick it in the hole until a repairman can come. Bubble gum actually dries hard and with no chemicals so it plugs holes very well. Keep the door closed until you talk to a repairman.
Thank you and good luck. Please remember to rate my answer.
Posted on Oct 28, 2008
Whirlpool fridge freezer stopped making ice
Make sure the freezer plug cord has power on the outlet. Also check the thermostat control if working, in desired settings especially in low degrees, it should have some freeze. If not, then thermostat is defective.
See to it that the evaporator has no dent, punctured cause by sharp object ( knife, screw driver, etc.) when removing frozen food or drinks. If it has small hole, it will cause refrigerant to evaporate hence freezer will stop making ice.
A defective defrost timer will also cause that same problem. You will know it by dialing the knob, it should smooth and no friction and if it has failed to go back to original position.
Thanks for asking.
Jul 03, 2011 | Whirlpool Refrigerators
Water dripping in refrigerator.
The drain hole in the freezer section is frosted up . Easily fixable .
Remove the food and the ice maker from the freezer ( if equiped ) . Remove the rear freezer panel . Using a hair dryer , start in the middle , below the coils , defrosting , until you see the drain hole . Use hot water to help defrost the hole . Once water starts going thru the hole , use a small hose inserted into the hole , and blow thru , to remove any unseen debris in the drain line . Use an ALUMINUM or COPPER solid wire , 14-16 guage , with the insulation completely off , and insert one end into the drain hole as far as possible without any force . Wrap the other end about 1 1/2 to 2 turns , around the black rod (defrost heater) , above the hole . When refrig goes into defrost , the heat will transfer from the heater , to the wire , keeping the hole from freezing up again .
Jun 25, 2010 | KitchenAid KTRS19KMSS Top Freezer...
Water pooling in bottom of amana top freezer fridge
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
May 25, 2010 | Amana ATB1832AR Top Freezer Refrigerator
Water pools in fridge under light bulb at top. This fridge has a freezer & icemaker on top. Water is not pooling in the freezer.
Water has frozen in the separator between the two cavities. Remove the freezer rear panel and the floor.
Nov 19, 2009 | Refrigerators
Water in my refrigerator
The defrost drain is stopped up, or frozen up. You will need to turn the refrig. off defrost the drain. This can take time. Locate the drain hole in the center of the back of freezer. You will need to remove the back panel. The fastest way is to find a bottle with a plastic tube about 1/4 in attached and fill the bottle with HOT water and squeeze it into the drain
Nov 18, 2009 | Frigidaire FRT15B3A Top Freezer...
Water collects under the vegetable bins but there is no sign of water anywhere else.
The defrost drain inside the freezer , behind the back wall , is frozen . Remove the food , then remove the rear freezer panel , If you have an icemaker , it too , will have to be removed . Use a hair dryer to melt the ice layer below the coils . Once you see the drain hole , defrost the hole , hot water helps sometimes . Once the hole is defrosted , use a small tube inserted into the hole and blow thru it to clear any debris inside . Reinstall removed parts and problem solved . Easy repair .
Aug 18, 2009 | GE GTS22KBP Top Freezer Refrigerator
My GE refrigerator, freezer is a side by side, model # TFH30PR - 1994 purchase. Sudenly I am getting ice build up on the freezer floor. My research suggests a plugged drain hole - but I cannot find the...
Remove the food from the freezer from the icemaker down . Remove the 6 (?) screws holding the rear panel on . At the bottom below the coils , there is a drain hole . Start from the center below the coils , defrosting with a hair dryer . Eventually you'll see the hole . keep defrosting the hole until excess water starts going down the hole or if you think the hole is clear , use a small hose inserted into the hole and blow thru to remove any built up food debris in drain . After clear , reinstall the panel and frozen food .
Aug 09, 2009 | Refrigerators
Leaking freezer into fridge
Hi, What has happened is that the drain hole in the freezer has frozen up and the defrost water is dripping into the fresh food area.
Remove the floor panel and the rear fan cover in the freezer and you see the ice that is blocking the drain.
Be carefull when removing the ice. DO NOT use a sharp object. The best way is to use a hair dryer.
Once you locate the drain hole, you will need to melt the ice down in the drain hole too. For this, you can use the hair dryer or poor a few glasses of hot water (sopping up the water between each glass).
What you will need to do after the drain is open is to put an after market drain heat transfer kit on to prevent this from reaccuring.
Please let me know if this is the case and I can get you the right part# or even send you the part.
May 14, 2009 | Whirlpool 18.2 cu. ft. Top Freezer...
Frozen drain line from top freezer to drip pan
Hi, Remove everything in the freezer. Get as much ice out as possible with out using sharp object. You will need to remove the rear evaporator panel inside the freezer and locate the drain hole below the evaporator. The safest way is to use a hair dryer. Once you can get to the drain hole and get the ice down inside the drain thawed (a few glasses of hot water usually gets the job done) Try and run a wire (I use a hose or biasting seringe) and get that drain hole flushed out real good. Sometimes it takes 45 minutes or so. After that is cleaned out, put the rear panel back on and you should be all set.
I hope I have helped you. Please let me know if I can be of more assistance.
May 12, 2009 | Freezers
Water dripping into refrigerator from freezer
Jan 28, 2009 | Estate TT21AKXKQ / TT21AKXKT Top Freezer...
Samsung RS2630SH Side by Side Refrigerator Logo
93 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
