Question about Sony DRX-510UL DVD±RW Burner
INSTALLATION WINDOWS 7
ERROR ,NEITHER PX HELPER OR WINASPI LOADED CORRECTLY ONE OF THE TWO IS NEE3DED
  • Sony Master
  • 27,725 Answers
Are you having problems with your dvd or installation of windows ??
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps you
or
or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if you need more help or if i have missed the problem post a reply
hope this helps
Posted on Feb 25, 2012
How to upgrade a toshiba L305 to a 500gb hard without hardware failure error
I'm a bit confused? You are trying to install a HDD with Windows 7 on it from another computer in a Toshiba L305 laptop? If that's correct, it will not work, first, you must format the 500GB SATA HDD, then load the Windows 7 OS to get a clean install. Clarify the question if I am incorrect.
Jul 03, 2013 | Toshiba Satellite L305-S5875 Notebook
I'm trying to load musicmatch 10 to window 7 64 bit i keep getting missing px.dll file
download the px.dll file from http://www.dll-files.com/px.zip?0WMgQDZIfU and then copy it to your Musicmatch 10 folder.
May 02, 2011 | Computers & Internet
My plextor digital video converter px-av100u cant work in my laptop. in my laptop i have windows 7 operating system. please tell me how can i use my capture card.
I could not download a Plextor driver that works w Windows 7. I purchased a Gigaware Video Converter from Radio Shack for $49 which works great with Windows 7. Software also converts video captures into mpeg files so saves time converting from codex.
Dec 20, 2010 | Plextor ConvertX PX-AV100U Video Capture
I have this unit, and the driver CD for windows XP. Now, I am installing this unit to my new computer running windows 7. Do I need a undated driver, or my existing CD will work. My unit model number is...
It will work though it will show certain problems while performing it's functions. Updated driver is necessary as Windows 7 and XP are different.
Also, sometimes, the drivers won't get installed as it is made for XP.
Sep 05, 2010 | Plextor ConvertX PVR (PX-TV402U-NA/MAC)...
I am starting to see we are sorry,but an internal error occured please reinstall the product to fix the problem. error-code:1/-3/10900 see doc#5305 And again the INCD helper service is not correctly...
That INCD service or component is a part of Nero. It gets installed with Nero. This was a common problem of Nero 7. What you can do is uninstall and re install the product. You have to use an uninstaller program available (such as your uninstaller) to remove the registry keys as well. Its clearly indicating that the programs is not successfully installed. Note: If you try to install Nero 9 in a Windows XP SP2 environment or in a Windows 7 environment you might receive the same error. Those are compatibility issues. You have to use SP3 in XP and you have to purchase Nero 10 for Windows 7. Incd is not necessary to function Nero. Try to install without Incd. You can do that while installing. Choose the Customized Installation. If you are using Nero 7, I recommend to use Nero 6 or 8 and upwards.
You can download Nero from their web site or using a torrent as well. Some funny things may happen when Nero gets installed partially. Go to Properties by Right Clicking the Taskbar and untick "Hide inactive icons" check box. Click on "Customize". Check the "Behavior property and for the programs which have the setting "Always Hide", select "Always Show" option. Then Apply and click on OK button.
Contact me further if you still have the problem. If the solution works for you please be kind enough to rate the answer as well :-)
Jun 09, 2010 | Computers & Internet
Loaded autodigitizing onto our new computer with Windows 7. Everything loaded just fine but when I try to open program it does not recognize the dongle.
There is an update for dongles and windows 7.
Info on Husqvarna Viking website - http://www.husqvarnaviking.com
When installing the 4D Embroidery System onto Windows 7 computers, the dongle drivers may not initially work correctly, as the 4D Embroidery System installs a set of dongle drivers which were created before Windows 7.
Download and install the latest dongle drivers prior to installing the 4D Embroidery System. Failure to do this, may result in the "Dongle driver not found (E0009)" when you try to open the 4D modules.
Please follow the steps below to install the latest dongle drivers BEFORE installing the 4D Embroidery System
  1. Download and install the latest Dongle Drivers.
  2. Insert your 4D Dongle.
  3. Install your 4D Embroidery System software (and all updates).
  4. Open your 4D Embroidery System software to confirm that your dongle is working correctly.
If you installed the 4D Embroidery System software before installing the latest dongle drivers and if you experience problems such as the error message "Unable to start hasplms service..."; download and install the latest Dongle Drivers.
Link to dongle drivers - http://www.vsmsoftware.net/downloads/HASP/haspusersetup.exe
Good luck.
Feb 09, 2010 | Husqvarna Designer I
Windows 7 will not run due to missing PX.dll
this dll file is related to sonic software you can try this linkhttp://patches.sonic.com/PX/pxengine1_08_34a.exe or try downloading the dll from www.dll-files.com/dllindex/dll-files.shtml?px
Jan 09, 2010 | Sonic RecordNow! Deluxe 7.3
Sony DRX-510UL DVD±RW Burner Logo
57 people viewed this question
Top Sony Computers & Internet Experts
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
