Question about Kyocera Mita FS-3820N Laser Printer
Waste toner box error who do i solve the problem in kyocera fs-3820n
When blinks red ! with beep codes present
    Sergeant:
  • 192 Answers
When I go to print it starts beeping and telling me to check waste toner box?
The waste toner box is located on the right hand side of the printer. There is a door/cover that opens up on the right side. It is a milky white plastic container. Check to make sure it is there and installed properly and the door is fully closed. If all that is correct it my be full.
There should be a new waste toner container in the toner box (along with a toner). The toner and waste toner are normally replaced at the same time.
If you don't have a new waste toner container you can tray emptying the one that is in the printer BUT be very careful. The toner is a fine powder and can get all over if spilled. If you ever spill toner never use water or any other liquid to try and clean it, that will just turn it to a liquid ink.Brush it off your cloths and vacuum it up.
If you do try and empty the container and the machine continues to tell you it needs to be replaced it can be because there is still toner on the inside of the toner container and the sensor is seeing it there.
I hope this is helpful,
Shawn
Jan 29, 2011 | Kyocera Mita FS-3820N Laser Printer
Error code 7001:0014607
Hello, This error code (7001) refers to a Toner motor error.
• Toner motor is overloaded. TNMOC is detected by sampling every other
100 ms in 2 seconds since the main and toner motors are activated following
the Replace toner Clean printer, message after the "Toner low" is detected.
Recommended action is to change the toner pack.
If this does not resolve the issue then the developer should be changed.
If neither of those resolve the issue, then likely the internal circuit board called the engine controller may be bad.
If this is the case the printer will need to go to an Kyocera Repair Depot.
I hope this has been of assistance.
http://www.fixya.com/uploads/images/prefab_21.jpg
Jan 18, 2011 | Kyocera Mita FS-3820N Laser Printer
Check waste toner box
We have a Kyocera Mita FS-3820N and sometimes when the toner box message does not go away, even after emptying the box, we simply hit it a few times in the area of the box. Works every time!
Jun 02, 2010 | Kyocera Mita FS-3820N Laser Printer
Hi, moved my FS 3830 and it now says check waste
If you are in Ho Chi Minh City,you can go to Dinh Cao Trading and Service Company at 63 Vinh Vien street district 10 and we'll solve the problem for you.
Mar 10, 2010 | Kyocera Mita FS-3830N Laser Printer
Kyocera FS-820
As far as I know this is a new pcu required
Jun 11, 2009 | Kyocera Mita FS-820 Laser Printer
Error code 4200-002678 call for service
best case scenario... laser scanner harness or cable loose or bad... medium case scenario... laser scanner unit is bad... worst case scenario main board is bad...
May 20, 2009 | Kyocera Mita FS-3820N Laser Printer
Check Waste Toner Box message
Clean the neck of the bottle and the black sensor the neck sits in.
Feb 04, 2009 | Kyocera Mita FS 1900 Laser Printer
Kyocera Printer C5030N
Remove the developer and toner cartridge from the front of your unit. This will allow you to take out your drum where your waste toner box is. Once you have your drum with your waste toner box make sure to detach the waste toner box from the drum. Take a damp linen free cloth and wipe down the inside of the drum unit where your waste toner box goes in. Now take your waste toner box and make sure to secure the waste toner box really well to the drum. This has to be in very tight or else the printer will not think that there is a toner box attached the drum and this error will continue to appear. Important thing is to make sure that the toner box is attached really well to the drum unit.
Oct 18, 2008 | Kyocera Mita FS 3800 Laser Printer
Kyocera Mita FS-3820N Laser Printer Logo
267 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Henry Gertcher
Adorjani Laszlo
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
