Question about NTI Backup Now EZ
Bootable CD not loading Backup Now EZ for full system restore
Using Windows Server 2003 SP2 and I created a backup .NBF about a week ago. I created a bootable CD by going to Tools>Create a Bootable CD. However, when I go to boot the disk on the sytem it just brings up a line that says Linux and nothing below it. I need to run a full system restore but I need this server to boot that program to restore. Help please! :)
2 Suggested Answers
byteguy
  • 2229 Answers
SOURCE: I used the backup now
This might be one of those programs that must be installed in order to work. I would imagine that you must install the program and have it do a restore.
Some programs keep a record of the backup on the hard drive. When you upgraded, the record might have been destroyed. If this is true, your backup software will have a utility to rebuild the index of the backup so it will work.
var fctb_tool=null; function FCTB_Init_b57a4ca77bce4177981a716bb3d932c6(t) { fctb_tool=t; start(fctb_tool); } var fctb_tool=null; function FCTB_Init_37914be2a9c340639799c674a792b2dd(t) { fctb_tool=t; start(fctb_tool); }
Posted on Feb 05, 2011
My computer crashed, how do I recover my NTI Backup Now EZ program? My computer can't find the NTI setup.exe.
Many people confuse system back-ups with system restore and/or recovery programs. They are very different. A backup makes a copy of selected (or all) files and stores them to a disc, tape, hard drive, or other device that will allow you to protect your files in the event of data loss. Say you accidentally delete an entire directory instead of a single file. Your backup would allow you to re-load that directory. System restore/recovery files are used in the cases where you either want to reload the computer back to a certain condition (factory restore), or need to completely recover your computer in the event of a crash. These types of files usually need one of two things to work. If the recover/restore software was OEM manufacturer supplied, there may be a BIOS routine that, using a hotkey on boot-up, will allow you to access the recovery/restore file. If it is an aftermarket program like your, recovery/restore files usually need to create a bootable USB or CD/DVD that can be inserted on boot-up, and then the files on that device will perform the recovery/restore. If all you have a a system backup, you may have to reinstall the operating system, drivers, and then the backup software. After that, you can use you backup file to recover your remaining programs/data.
Sep 29, 2015 | NTI Computers & Internet
I have 100+ NBF files on my backup drive. When can I safely delete them?
If the files are labled backup_01.nbf, backup_02.nbf, ect; the yes you can delete them. These are files created by the backup now program. If they are not this type, then they are possibly related to your graphic card, the NVIDIA fraphic card software uses the .nbf file for scene graphic files.
Mar 11, 2012 | NTI Backup Now EZ
Hi I'll briefly describe my problem I've an external HDD (Toshiba) with NTI Backup Now EZ software installed on it, and I used it to back up my files the problem is that I can't restore my files now...
You might need to get an older version of NTI Backup Now. I had the same issue. I was using Backup Now 4 which saved everything as .nbf.files. I downloaded a trial version of Backup Now 5.5 and tried to restore the files only to find .nbf files are not compatible with version 5.5!
I sent a rather facetious e-mail to NTI moaning about this issue and they sent me a trial version of version 4. If I were you, I'd do the same. http://www.nticorp.com/en/us/product/backup_now5.asp
All my .nbf files are now restored.
Jan 08, 2011 | Newtech Tech InfoSystems NTI Backup Now EZ...
Windows not loading
http://www.ehow.com/how_4478845_restore-acer-computer-factory-settings.html
Run Acer eRecovery Management Copy the Acer factory default backup disk Image Create backup of the system Create a complete backup Creating an incremental backup Erase a backup point Using the option ‘‘Burn Disk’’ Burn a backup disc with the factory default settings Burn a backup disc with the parameters of user Copy the current system configuration to disc Burn a disc backup software Restore the system Restore system to factory default settings Restore system from backup user Recover the system from CD / DVD Re-install applications / drivers Other means of System Restore No Restore CD / eRecovery / password / ALT + F10 or F10
May 05, 2010 | Computers & Internet
I have an Acer Aspire 5720, ive had it for a year now and it is starting to slow down. I have lost the booklet to it and i need to do a master reset on it. Ive already backed everything up im just finding...
This was taken straight out of the manual for your model, which can be found here.
Acer eRecovery Management is a tool to quickly backup and restore the system.
You can create and save a backup of the current system configuration to hard
disk, CD or DVD. You can also backup/restore the factory default image, and
reinstall applications and drivers.
Acer eRecovery Management consists of the following functions:
1 Create backup
2 Burn backup disc
3 Restore and recovery
This chapter will guide you through each process.
Note: This feature is only available on certain models. For systems
that do not have a built-in optical disc burner, plug in an external
optical disc burner before entering Acer eRecovery Management
for optical disc-related tasks.
When using Acer eRecovery Management, you may be prompted to enter the
Empowering Technology password to proceed. The Empowering Technology
password is set using the Empowering Technology toolbar or when first running
Acer eLock Management or Acer eRecovery Management.
Create backup
You can easily create full and fast (incremental) backup images of your system
configuration to hard disk from the main Acer eRecovery Management screen.
Note: Fast (incremental) Backup is only available after a Full
Backup is made.
1 Press <Alt> + <F10> or select Acer eRecovery Management from the
Empowering Technology toolbar to start Acer eRecovery Management.
2 In the Acer eRecovery Management window, select the type of backup you
want to create using Full or Fast.
3 Follow the instructions on screen to complete the process.
83
English
Burn backup disc
Using the Burn Disc page of Acer eRecovery Management, you can burn the
factory default image, a user backup image, the current system configuration,
or an application backup image to CD or DVD.
2 Switch to the Burn Disc page by selecting the Burn Disc button.
3 Select the type of backup (factory default, user, current system,
application) you would like to burn to disc. Choosing to burn a user backup
will burn your most recently created backup image to disc.
4 Follow the instructions on screen to complete the process.
Note: Create a factory default image when you want to burn a
bootable disc that contains your computer's entire operating
system as it was delivered to you from the factory. If you wish to
have a disc that will allow you to browse the contents and install
selected drivers and applications, create an application backup
image instead — this disc will not be bootable.
The restore and recovery features allow you to restore or recover the system
from a factory default image, from a user created image, or from previously
created CD and DVD backups. You can also reinstall applications and drivers for
your Acer system.
2 Switch to the restore and recovery page by selecting the Restore button.
3 Select the backup point you would like to restore from. You can also
choose to recover the system from a factory default image, recover from a
previously created CD/DVD or reinstall applications and drivers.
Dec 20, 2009 | Acer Aspire 5720 Notebook
How get sql data backup
there is facility in enterprise manager to take back of database!
Feb 04, 2009 | Keystone Active Server Pages (ASP)/Visual...
COULD NOT LOAD OS - TRIED 2000 & 2003 SERVER
Reinstall OS without repairing. Sometimes people make the mistake between a choosing repair and a full reinstall. Also backup any files before doing so.
Sep 20, 2008 | Acer Altos G530 Server
Backup and restore
you can just install with window xp but take data backup in another drive
Aug 25, 2008 | 1991 Isuzu Impulse
Iv loaded new windows on my acer aspier5600 and i need a recovery cd so all the drivers will work where can i buy one from australia
u can create your own recovery software using norton ghost software.Install in and create a backup file on the next partition of your lap hdd or on a dvd cd.At any time u can restore the backup file.Make the dvd cd bootable.
Jul 17, 2008 | Computers & Internet
Restoring files from the database
I suggest you use the Enterprise manager (gui tool to manage SQL).
Restoring a single table is not an option.
You can however restore a file or filegroup.
Make sure to backup before you start and NOT to restore database to its original name or original file location, to avoid acidents.
Normally you will have databases with only 2 files: the data at its Primary file group, and log file.
You may wish to create a new file group and move tables to the new group by recreating them there and exporting data from old table to new table. Then recreate indexes. This may prove to be complex as all tables and indexes have unique names and can't coexist with exact duplicate of them.
oh yea..... did I say backup?
well just in case backup backup backup backup backup backup backup backup backup backup backup backup backup backup backup backup backup backup backup backup backup backup backup
but dont overwrite that backup
Feb 11, 2008 | Microsoft SQL Server 2000 Standard Edition...
Computers & Internet Logo
168 people viewed this question
Top NTI Computers & Internet Experts
Lawrence Oravetz
k24674
richie46
Are you a NTI Computer and Internet Expert? Answer questions, earn points and help others
