Question about Whirlpool AWM6100 Front Load Washer
Door open! My Whirlpool 6100 will not work....keeps telling me that the door is open! The door "clicks shut" when I shut the door. It tries and starts, then flashes "door open" what is wrong with it??
  • suziesdragon Oct 28, 2008
    Thank you for your help, It sounds like the right advice to me, as the washing machine tried to start with the door actually open....I will get this problem fixed asap.
    Cheers, suziesdragon
  • Anonymous Nov 07, 2008
    I have the same problem. Door click shut but door open light flashes. Doesn't look like something you can fix yourself. Better get a service guy.
I had the same prob..and the cure was to change the bushes on the motor.its been fine since
Posted on May 02, 2009
  • 1,952 Answers
Door Lock Mechanism broken or removed from the Door Door open! - globul1a.gif Check Door Lock/Switch Assembly Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU) globul1a.gif Door Lock/Switch Assembly Failure
globul1a.gif Door Lock Mechanism broken. globul1a.gif Check Door Lock/Switch Assembly for foreign objects Door open! - globul1a.gif" alt="globul1a.gif" class="h_mi" /> Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU) Door open! - globul1a.gif globul1a.gif Door Lock/Switch Assembly Failure
Posted on Oct 28, 2008
    New Friend:
I think he screwed something too tight to make it close fast. Is there a screw somewhere that can be loosened?
Posted on May 25, 2014
Integrated fridge door keeps springing open. what is causing this?
the magnetic seal along the door may have gone bad. or bad worn out door seals not keeping or creating the pressure needed to cling door shut
Feb 19, 2015 | Whirlpool Refrigerators
Whirlpool dishwasher model GU2300XTL83; type 577-0 leaving residue on dishes; not cleaning all dishes; upper rack cups and glasses not clean... i have sanitized inside of dishwasher; keep the rinse agent...
this is a game like cat and mouse where you have to open and close the door of the dishwasher in order to assure that the arm is moving and water is coming out of the door notice the postion when you first open the door shut the door open the door maybe a second later has the arm moved at all. this is a diagram of how the upper wash arm is assembled click this link and if you have any further questions message me back and please remember when our chat has fully concluded to rank how this opinion has helped it allows me to continue helping people in similar situations in the future Thanks agian Rick
Apr 29, 2011 | Whirlpool Dishwashers
I have a Whirlpool AWM 6100. The light indicating door is open is on, however there is nothing obstructing the door and is is closed? Won't work with this light on, and can't open door!
Very possible the door latching mechanism is faulty because when door is closed the contacts in the switch will see condition is correct for operation and light will extinguish. With power plug pulled out, remove the lid and buy using a small screwdriver try and wedge the doot latch open from the inside. Possibly it will need to be broken off to remove. Once off, door will open then replace with new one.
Aug 05, 2010 | Whirlpool Washing Machines
Front loader AWM 6100 - door open light flashes and won't wash
I think it may have try and get your local engineer out to have a quick look tell your thinking of buying new and what price can he supply 4. and you like a free estimate .
Feb 11, 2010 | Whirlpool AWM6100 Front Load Washer
Washing machine says door is open and stops
I would make sure the door latch and door lock are both clean and free of debris as this will cause the machine to fault out from the latch not hitting the switch properly. If cleaning it thourghly doesn't do the trick you may need a new door latch/lock mechanism.
Jan 30, 2010 | Washing Machines
Water from the water dispensor not flowing anymore
Do you hear the valve opening at the back of the fridge click when you push for water?
If not may need to be replaced.
If you do hear a click.....the water line may be frozen in the freezer door.
Open the door wide open for a while......1 to 2 hours and occasionally try the water.....cover the freezer compartment with towels to keep the cold in that area but not the door.
Aug 17, 2009 | Whirlpool ED5FTGX Side by Side...
Oven door won't stay shut and light stays on. whirlpool
How old is the oven? Did this problem just start? If this is an older oven, and it started having this problem recently, it sounds like the door is bent slightly. Enough to keep the light on. Anyone put weight on the open door, (or as I saw once, someone trip and land on an open dishwasher door, which didn't shut properly afterwards) You can get a piece of paper, put it at the top corner of the door opening, try pulling it out. Try this all around the opening, you should be able to tell where it doesn't close properly. U might be able to 'tweek' it, by trying to bend it to close tighter at the largest gap, BUT this could make it worse, or if it has a glass panel, u might break it. So, tweek at your own risk. countrycurt0
Aug 05, 2008 | Kitchen Ranges
Whirlpool Frost Free 460 door open alarm check how to repace it with the schematic diagrams you'll see how
Dec 30, 2007 | Whirlpool GS6NBEXR Side by Side...
Whirlpool duet washing machine door lock error
My front loader has the door locked and I can't open it. I have already turned off the power and that didn't solve the problem. The manual says that if you try to open the door too soon after the cycle completes, then the door locks. How do I open it now? What do I do?
Nov 20, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool AWM6100 Front Load Washer Logo
972 people viewed this question
Dan Webster
Dan Webster
Sal De
