Question about GE Dryers
GE DRSR483GG7WW service manual
Looking for service manual showing how to gain acces to inside for lint cleaning
3 Suggested Answers
SOURCE: dryer not heating, I have cleaned inside of dryer from lint
jvc turntable belt
how to get it on
Posted on Dec 19, 2009
wiringlunati
  • 576 Answers
SOURCE: It takes much longer to dry clothes than it once did.
There isn't really a need to clean around the drum. Try cleaning the ductwork inside it and the vent to hte outside and that should fix it.
Posted on Jan 03, 2010
How to remove panel to clean out lint for GE electric dryer model DDC0580BBLWH
most ge dryers you unplug it,open the door and look up you'll see two phillips screws there,remove them and then slide the top panel to left to remove it,then remove two screws on front panel,move front panel to the left,now you can clean out the front panel where the lint screen is,if you have a shop vac set it up to blow and blow all the lint in the cabinet up to the front so you can vac it up,this way you don't have to remove the drum,if you do remove the drum vac out the back side of the drum,if you don't want to remove the drum look inside the drum,if you see lint there vac it out through the holes,then set up the vac to blow and blow through the holes in the back of drum,vac up any lint you see,then remove the vent line,if it's a long run stick a leaf blower into the line and blow it to the outside,when you're done start the dryer,go outside and make sure the air is blowing out strong,if not check the vent line again.hope this helps you out.if you go to order parts the number you sent doesn't come up,if you remove the wh it comes up.
Jan 24, 2018 | GE Dryers
How do I clean lint from inside GE Harmony Profile Dryer?
You have to remove the panel. The assume the lint filter works better then they usually do and do not make it easy to open up and clean inside. You may have to open it from the back side which does open up to allow repairs, etc.
Aug 12, 2014 | GE Profile Harmony DPGT750ECPL 7.3 Cu. Ft....
I don't have a manual, but I need to get inside to
Unplug the dryer and remove it to the outside if possible.
Remove them lid switch wires off and raise upwards on the front to release the bottom clips.
You will see this:
Get the tub out and it will look like this
Get the back dust cover off
Service manual, repair videos, and MORE HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 06, 2011 | Kenmore 64952 Electric Dryer
My condo has a Hotpoint dryer. It is about 3 years old and last fall it no longer dried. I took the dryer hose off from the wall and the dryer works fine, heats the condo. The dryer vent goes into the...
Hi.
With most Hotpoint/GE dryers the blower motor is not spin by a belt. The problem is unlikely the blower motor. The problem is lint in the air ducts and in the blower housing. The lint results in overheating and the high limit switch cuts off the power to the heater (burner or element depending on the model).
As a result the dryer does not heat up.
Access the heating group and remove lint from the air ducts. Also clean the lint filter.
Hotpoint appliances are built by GE. Below service manuals for different GE-manufactured dryers:
Technical Service Guide
Service manual
ELECTRIC & GAS DRYER SERVICE MANUAL(Kenmore)
Jun 14, 2011 | Hotpoint Dryers
Jan 02, 2010 | Frigidaire FDE336RE Dryer
Why do it smell like something is bruning
It usually happen when there is a lint build-up inside the machine. Do not use the dryer. It is now a fire hazard. Read and follow the instructions from the user manual. It needs to be cleaned inside periodically as regular maintenance.
Dec 01, 2009 | GE DBXR463EDWW Electric Dryer
Front load ge washer does not finish cycle
This model does not have a drain filter. There are filter screens inside the inlet valve where the hoses attach onto the machine. Take hoses off and look inside where the water goes into machine to see screens. Also, take the other end off hoses to make sure there are not screened hose washers in either end of the hose which may need to be cleaned or replaced.
Oct 18, 2008 | GE WSXH208A Front Load Washer
Will not drain or spin
There is another posted problem similar to this one if you look at GE front-loading washers.  I can tell you right now, though, that we just cleaned the filter (had the same problem as you) and everything is working perfectly now.  The bottom panel (on the front) of your washer comes off by removing 3 screws.  Our filter was full of lint, change, barrettes, etc.  I would highly recommend looking for that other post (has more information) or trying to clean the filter.  Hope this helps!
Oct 11, 2007 | GE WSXH208A Front Load Washer
Dryers Logo
41 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
