Question about Car Audio & Video
ML320 intermitant Radio unit ON/OFF not working
Hi, My ML320 has problems and the OEM radio combo unit. Often will not turn on, When it will turn on, it stays on! Somtimes if it will not come on, then if I can turn the ignition off then back on it works. However this in getting less and less frequent.
The problem appears to be with the interlocked from the ignition switch.
The face plate control back light buttons always work, but the blue screen stays unlit.
Thanks
Jexx
  • 148 Answers
SOURCE: cd player
First of all, you aren't going to like this solution because it's the truth. If you rate me poorly, it's because you don't understand the truth. The optical pickup is bad and needs to be replaced. Anything made by Xtreme sound is poorly built. Yes, you're lucky to have even gotten four months use out of it. I've seen some that only last for two months and they die. Fortunately, that's why you didn't pay that much for it. I would suggest getting a Pioneer in the future.
Posted on Jul 16, 2006
SOURCE: Pioneer DEH-9600: No power to rear screen
there is a broken ribbon cable that needs to be replaced. parts and labor shouldnt cost you more than a 100 bucks. worth it since it never has the problem again
Posted on Apr 10, 2008
  • 3 Answers
SOURCE: Clarion M5675 won't turn on
Take the stereo all the way out and hook the black wire to the negative terminal and the yellow and the red wire to the positive terminal on a charged car battey. If it still does not turn on you may have fuse in the back of the deck. If not it's probably fried.
Posted on Apr 19, 2009
xscrewdriver
  • 246 Answers
SOURCE: Pioneer 7800MP can't turn on
It looks like the flexible cable worn out. Try to replace the cable.
This link may help:
Intermittent display on Pioneer DEH-P7800MP car audio
Posted on Jun 04, 2009
  • 7 Answers
SOURCE: Car Radio just stoped working.
My same model did this too. The wiring harness may have gone bad. Try direct wiring the stereo or replacing the wiring harness if you can get one. This fixed the problem for me.
Posted on Jun 28, 2009
Why won't the radio/cd player turn on?
Check your radio fuzes usually when the don't turn on the fuze burns out the fuze should be inside of the car on the sides of both doors or on the bottom left hand corner of driver side
Jul 27, 2014 | OEM 1999 Mercedes ML320 Radio / CD Player...
Need master code for radio in a 2000 ml320
Regretfully due to reasons of theft or piracy we do not pass the radio codes here at FixYa. If you contact your local Mercedes-Benz dealer they will give you the 5 digit code. (You must have your registration and know the complete serial number of the radio)
Kelly
May 05, 2010 | 2007 Mercedes-Benz ML320 CDI
Cant restart car radio
This sounds like an easy fix. I would locate the fuse that is for your radio, and try that. It is probably blown.
Feb 19, 2010 | 2007 Mercedes-Benz ML320 CDI
Power antenna does not work for the radio and there is no sound
Does the radio turn on at all? turning on the radio activates the antenna, therefore, no radio, no antenna, assuming you still have the OEM unit
Dec 09, 2009 | 1995 Jeep Grand Cherokee
I need help getting the radio code for my 2000 ml320 vin# 4j6ab54e8ya150540 radio serial Al4910x0909992
hi make a note of your vin number and take it to your nearest dealer he can get it for you please rate this answer thanks
Nov 20, 2009 | 2007 Mercedes-Benz ML320 CDI
How do I reset my ml320 stereo code
what is radio code 4 a 2000 mecedes ml 320
Sep 09, 2009 | 2007 Mercedes-Benz ML320 CDI
ML320 2003-FM radio not working except by turning the volume to maximum and it can only be heard faintly. The AM, cassette, Cd and phone work fine at normal volume. Any ideas??
i was wondering if you were able to find a solution for this. I am currently having this same problem with my vehicle (as a few others as well). if you could please let me know, id greatly appreciate it. my email is josephelara@yahoo.com.
May 15, 2009 | 2003 Mercedes-Benz M-Class
My radio
I can tell you this if you drive your car into any mercedes dealer they will show you how to put radio code/they will not charge you for this / Please rate my response Thak you very much
Jan 29, 2009 | 2007 Mercedes-Benz ML320 CDI
1998 Mercedes ML320 Radio code instructions
does your radio ask for the code when you turn on the ignition key. If you see _ _ _ _ or **** you should enter the code using the pre set numbers for your radio, ie, first code should be entered using the first pre set key on the radio ( number one ).
Followed by the second code number being entered using the second pre set button and so on until all of the code is entered.
After entering the full code the radio should accept, if not enter code again and press the next pre set key following, ie, if the code is 4 digits, press the fifth.
Hope this works.
If all this fails most garages will set the security code for you for a small charge. Make sure you take proof of car ownership otherwise they will normally refuse to reset the code. This is to foil theft.
Nov 12, 2007 | Car Audio & Video
Car Audio & Video Logo
73 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
