Question about Canon PowerShot SX120 IS Digital Camera
What is the maximum card size support for Canon SX120IS ??? Would 8GB card work with it ???
  • debjyoti_xp
    debjyoti_xp Feb 23, 2012
    The camera is compatible to SD card.
  • debjyoti_xp
    debjyoti_xp Feb 24, 2012
    Thanks Jason, but I am searching for a concrete answer of my question. Because I am going to buy a SD Memory card, for my Canon SX120IS cam, if it supports 8GB, then I would like to go for it...
  • 356 Answers
The manual, which can be downloaded here:
http://pdisp01.c-wss.com/gdl/WWUFORedirectTarget.do?id=MDMwMDAwMjQwOTA0&cmp=ABR&lang=EN doesn't give a maximum size but does list 8Gb as acceptable.
8Gb should be more than sufficient for this camera, however, as it is rated for approximately 3-40 thousand pictures depending on your settings.
Please leave feedback if this was helpful, or comment with further questions if I can be of assistance. Thank you.
Posted on Feb 24, 2012
  • Jason Burkhardt Feb 25, 2012
    While it unfortunately does not mention the maximum, it does specifically reference the number of pictures it can hold on an 8GB card, so you should be good.
  • 102366 Answers
SOURCE: What is the maximum size
2GB.
Posted on Sep 24, 2010
ginko
  • 19396 Answers
SOURCE: What is the maximum SD
Recommended by factory is up to 512 MB, that will work for sure.
It should support up to 2GB card, supporting cards thet have SHDC technology.
Before buying a 2 GB card, I would go to the shop and test it on the camera, so that you are sure it works.
See the forum here :
PowerShot A510 maximum SD card size - Digital Camera Forums
Posted on Sep 29, 2008
  • 4 Answers
SOURCE: canon isus iis camera
you need an sd card and you should be able to put in at least 2gb card maybe more. any band of sd card is fine but i suggest sandisk they are pretty good
Posted on Mar 25, 2009
old marine
  • 2153 Answers
SOURCE: maximum memory size of sd-card for canon ixus 40 ????
Check to see if your 16GB card is an SDHC card. If it is, your camera is not compatible with SDHC. (The SDHC protocol was developed after the SD300 came out in 2004).
Posted on Feb 24, 2009
shajanrs
  • 890 Answers
Te Camera can support the SD/SDHC Memory Card, MultiMediaCard, MMC Plus Card, HC MMC Plus Card upto 4GB.
Posted on Jan 31, 2011
Memory card maximum size
Your camera only can use SD cards. The SDHC is a newer generation of SD cards, that need a different protocol you access the files. The newest version is the SDXC version.
SD cards never exceed 4 Gbyte. The SDHC never are bigger than 32 GD and the SDXC are over 32 GByte.
When you try to buy a SD card, the biggest you will find will be 2 GByte. I own 2 SD cards that have 4 GByte, but even I can't find them on the net any more.
The cards are from Platinum. But I even can't guaranty you the 4Gbyte will work in your camera.
Some firms used to bring out new firmware, as soon as the SDHC cards came out. I succeeded to update my TomTom to SDHC and the old thing now even accepts 16 GByte cards. But Canon did not offer an upgrade for the V550, so you stay stuck to the normal SD cards.
Dec 30, 2013 | Canon PowerShot A550 Digital Camera
What is the maximum size of micro sd the mp828can support?
microSD cards range up to 2GB in size, and any of them should work in the MP828. Larger cards are actually microSDHC. While they'll fit into the slot they're electronically incompatible.
Aug 07, 2012 | Cameras
Hi I inserted a new 8GB sd and the camera keeps trying to re-format. GZ-MC 200
There are no 8GB SD cards. A card that size is actually an SDHC card. SD and SDHC cards fit the same slots, but they are slightly different. Many cameras won't work with the SDHC (high capacity) cards. SDHC is not backwards compatible.
Unless your manual specifically says that your camera can use an SDHC card, then it won't be able to. The maximum size of an SD card is 2GB. If you need more space, just carry a couple of cards and swap them, like people used to do when they filled up a film.
Dec 25, 2010 | JVC Everio GZ-MC200 Camcorder
Will the canon ixus 30 use a 8GB SDHC memory card, as it shows card locked in display
Your camera will accept a maximum SD card capacity of 2GB. It simply isn't capable of handling anything of a larger capacity and in particular is incompatible with the more technically advanced SDHC cards.
Your fix is to either replace your camera with a later model or to stick to using SD cards with a maximum 2GB capacity.
Sep 11, 2010 | Canon PowerShot SD200 / IXUS 30 Digital...
Why can't I get pictures off of an 8gb but I can off of a 2gb chip?
Some cameras cant manage/format large size memory cards as they where not made to handle that size. Check your user manual which should tell you the maximum size memory card your camera will take.
Aug 04, 2010 | Panasonic Lumix DMC-TZ1 Digital Camera
What is the maximum sd carddo i need to use?can i use 8 gig to my cannon power shot A590 IS
SDHC cards go up to 32GB, which puts the upper limit on the size of cards you can use on the A590. There shouldn't be any problem with a properly-functioning 8GB card.
Jun 16, 2010 | Canon PowerShot A590 IS Digital Camera
Hi We have taken around 170 photos at SX120IS
Use a card reader to download them to a folder you create on your desktop.
Nov 14, 2009 | Canon PowerShot SD500 / IXUS 700 Digital...
My China N96
The maximum microSD card size the N96 can take it 8GB but this doesn't mean your copy will. Sorry I cannot be more specfic than that!
Aug 31, 2009 | Nokia N96 Smartphone
What is the maximum SD memory card size that a Canon 510 and 520 Powershot can use?
Sep 29, 2008 | Canon Cameras
Canon PowerShot SX120 IS Digital Camera Logo
353 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
