Question about As Seen On TV Mini Mechanical Sewing Machine
Screeching noise My sewing machine was working properly the last time I used it. I took it out now after awhile and when both the thread and bobbin are inserted through the correct positions, and it is switched on, it makes a screeching noise and stops. The thread seems knotted near the bobbin and I have trouble manually moving the wheel to clean it up. When only either of the thread or bobbin is present, the machine works though the motor sound is a bit loud.
  • SuKris May 01, 2012
    The needle is okay,
    It was working all these days, I kept it inside for a few months and the noise started
    I dont think these chinese made machines can be serviced
    Thanks for your suggestions
  • 3 Answers
It might be clogged up with cotton that in itself is enough to stop the wheel turning. Take out the needle the foot and the foot plate, remove bobbin and undo the two clips where the bobbin goes and pull them out. Sometimes there is cotton hidden in there. Give everything a good clean out and put back together again hopefully that will do it
Posted on Nov 04, 2012
  • As Seen On TV Master
  • 7,365 Answers
Have you tried a new needle--flat side to the back of the machine
check to see if the thread has come off the thread take up lever
it's also possible that there's something wrong with the motor since it sounds a bit loud
it probably needs to be serviced
Posted on Feb 24, 2012
My Juki LU-563 stopped picking up the bobbin thread, changed needle, took out bobbincase to look for thread, none, still won't sew because of bobbin thread not being picked up.
If you've properly installed a brand new needle that is correct for the machine, threaded it correctly, checked that the bobbin is installed correctly and the bobbin tension threaded properly, most likely the machine is out of time. In other words, the needle is arriving at the bobbin at the wrong time in order to intercept the bobbin. (You can open the bobbin area, hand rotate the handwheel and watch how and where the needle moves in relation to the bobbin to see where and why it is not connecting.) You can search the internet for web sites and videos that discuss machine timing or you can take it for service.
Nov 09, 2016 | Juki Sewing Machines
Thread catches in bobbin case and will some times break.
Sounds like the thread is either coming out too fast or too slow, which means the tension spring needs a slight adjustment. Or perhaps the thread has not been wound smoothly onto the bobbin and has loops. Or the bobbin case is not sitting properly in the holder. Poor thread could also be an answer. Hope one of these work for you
Feb 04, 2016 | Sewing Machines
Is not sewing properly
It SOUNDS like your bobbin case is either not in properly, your bobbin is either not correctly wound or too loosely wound, or your bobbin is warped. You can determine if it's warped (happens over time with plastic bobbins) by rolling it down a table top. If it wobbles, it's warped and needs replacing. They cheap to replace; I took a look and visually it appears that it's a Class 15 bobbin. I would also consult my user's manual; there is a troubleshooting section on the last page. If you don't have it, you can download it free at the Singer Sewing Machine site.
Jun 24, 2014 | Singer Tiny Tailor TT700
Bobbin jamming
try changing the needle
make sure the thread has not come off the thread take up lever
clean under the needle plate & in the bobbin area for lint
rethread the top part of the machine using every thread guide
if none of theses suggestions work, the machine needs to be
checked to see if there is a problem with timing
Sep 21, 2012 | Bernina Virtuosa 150
My singer sewing machine is jammed. it sewed awhile, the bottom tension too loose, I adjusted it a tad, now its jammed again
adjust the top tension one number or letter higher till the stitch looks
normal
make sure the bobbin is not warped
make sure the bobbin is inserted correctly into the bobbin case
try rethreading the machine top & bobbin
it's also possible that the machine could be out of time & needs
to be checked at a repair shop
Aug 23, 2012 | Singer 3116 Simple
I have a brother ls-2125 sewing machine. the upper thread is not catching the bobbin thread properly. help please
  1. Tension
    • Your sewing machine tension controls the rate at which the thread is fed through either the upper section of your machine or through the bobbin case. If your upper or bobbin threads aren't threading properly, sometimes adjusting the tension will correct this problem.
    Timing
    • Your sewing machine works by passing the upper thread through the needle of the sewing machine at precisely the same time the bobbin brings its thread to its uppermost position. If either the needle or the bobbin thread reach these positions too soon or too late, the threads won't interact and create the knots that make the seam. You can throw off your timing by sewing too many layers of fabric or hitting a pin with your needle. See you sewing machine repair facility to correct any timing issues.
    Thread
    • Thread can get snagged or caught in the upper section of your machine or on lint pieces in the lower bobbin section. If your threads aren't catching properly, you may be able to fix it by unthreading and rethreading both your upper thread and bobbin threads.
Oct 15, 2011 | Brother LS-2125 Mechanical Sewing Machine
I cannot get the bobbin to wind on my Model 1260 Euro-Pro. It was working fine the last time I used it. Any ideas?
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 05, 2011 | Euro-Pro 1260DX Mechanical Sewing Machine
I've been sewing for awhile and randomly my bobbin started tangling - I've tried all the usual things (actually read the manual and everything ;-) and cannot get it to work properly. Any suggestions.
try changing the needle-just incase it may have bent or be blunt or have a burr
take the bobbin out of the bobbin case & put it back in again
check the thread take up lever to see if it's threaded- when the thread comes off it can cause the machine to jam in the bobbin area
Oct 26, 2010 | Brother CS6000i Computerized Sewing...
Upper thread will not pick up the thread from the bobbin
1.check the needle & see if it's damaged
2.check the bobbin & bobbin case to make sure there inserted properly
3.rethread & try again
4.if the same thing happens,, it should be took to a service technican
Jul 29, 2010 | Singer CG590 Mechanical Sewing Machine
Problems with lower thread tension
Did you bend the throat plate? I have done that and it was a nightmare. I took it off and gently hit it from the backside with a towel over it to bend it back the way it was. It worked fine.
Jun 15, 2009 | Husqvarna Viking 1
Sewing Machines Logo
113 people viewed this question
Top As Seen On TV Sewing Machines Experts
Harjeet Singh
R.A. Ellis
R.A. Ellis
CrisO
Are you an As Seen On TV Sewing Machine Expert? Answer questions, earn points and help others
