Question about Ingersoll Rand Stationary Air Cooled Rotary Screw Compressor 10 Hp, 35 Cfm At 125 Psi, Model# Ep
IR air compressor SSR-EP-150 low sump pressure
dee73ten
  • 40 Answers
SOURCE: WILL NOT BUILD PRESSURE ON LOAD. SOUNDS LIKE A
Not the valve is not closing but the valve is not open. Check solenoid valve for the inlet valve.
Posted on Aug 23, 2010
  • 205 Answers
SOURCE: When our standby IR-Sierra H75A compressor is
What type oil are you using? I recommend Ultra coolant a poly glycol base lubricant. Also a heater of some type during cold weather.
Posted on Nov 14, 2010
SOURCE: We have IR SSR 150HP compressor, where when
to change rotaion on a three phase motor just which 2 leads.
Change L1 to the wire now on L2 and take the wire on L2 and move it to L1. the rotation will now change. or L2 and L3... just two wires
Posted on Dec 03, 2010
SOURCE: I have a ssr ep-15
I would say it's the piston ring(s) or vlave(s) or both leaking by -- in that case it would need a rebuild.
Charlie
Posted on Mar 31, 2011
  • 9 Answers
SOURCE: We have a UP6-30 compressor,
On 100+Hp units it typically involves replacing the oil separator/filter
Posted on Apr 14, 2011
Ssr up series 30e-40 Ssr 50 - pe low sump
compressor idling to long or inlet valve not opening
Oct 07, 2014 | Air Tools & Compressors
SSR EP 40 SE shuts down on low unload sump what is probable cause
I would look at the minimum pressure check valve first. If it is stuck in the open position you can not build sump pressure before the unit shuts down. MPCV is located on the top of the separator tank. You can remove it. Check to see if the plunger with the teflon disc is free and not damaged. These valves often seize up due to dirt,rust and condensation. If it is stuck it will need to be disassembled, cleaned and lubricated. It needs to be free enough to slide in the valve body by hand. If the o-ring is bad or damaged you will need to get a kit from IR. I have not been able to find one with out buying a kit. Next I would look at the blow down valve. It is located beside the MPCV at the top of the separator tank. If this solenoid is open it will not let the sump build pressure. Next I would check the Inlet valve actuator cylinder if so equipped. With out the serial number I dont know which type inlet valve is on the unit. If it does have a cylinder does it operate correctly. Is there any free play in the cylinder. If so replace it. Is the cylinder to inlet valve coupling cracked. Remove and inspect. Is the bolt tight at the rear of the cylinder. Will it let the cylinder move. If so you will need to loosen the bolt. Set the controller so you can see sump pressure. Start the unit and Slowly open the inlet valve by sliding the cylinder in and out to get 25psi sump pressure. Then tighten the bolt. if sump pressure drops below 15 psi it will shut down on sump pressure alarm. Good luck !!!
Aug 30, 2011 | Ingersoll Air Tools & Compressors
WILL NOT BUILD PRESSURE ON LOAD. SOUNDS LIKE A VALVE IS NOT CLOSING IR SSR 40HP
Mar 19, 2010 | Ingersoll Rand Stationary Air Cooled...
Ingersoll Rand SSR compressor shuts down loaded or unloaded with no alarm, and then shows ready to start . Will not run more than a few minutes either loaded or unloaded. installed meter on incoming power...
When it shuts down, press DISPLAY SELECT button once and use the up down arrows to see the code just before shutdown.
HIGH AIREND TEMP
HIGH AIR PRESSURE
LOW SUMP PRESSURE
PRESSURE OR TEMP SENSOR FAIL
CHECK MOTOR ROTATION
MOTOR OVERLOAD
FAN MOTOR OVERLOAD
STARTER FAULT
I am assuming this has a Intellisys controller.
Aug 25, 2009 | Air Tools & Compressors
Ingersoll Rand Stationary Air Cooled Rotary Screw Compressor 10 Hp, 35 Cfm At 125 Psi, Model# Ep Logo
135 people viewed this question
Top Ingersoll Rand Tools & Hardware - Others Experts
elunsford
Phil Walker
Phil Walker
Are you an Ingersoll Rand Tool and Hardware - Other Expert? Answer questions, earn points and help others
