Question about Home Security
Liftmaster 1265-267 clicks but drive chain and gears do not move
I have a Liftmaster 1265-267 that clicks when I hit the remote but is not moving drive chain or gears. Any ideas if there is a reset or something I can check? Have a new garage spring. signal is getting recieved but it is only clicking. Also, there is a little yellow/orange flashing light on one side.
5 Suggested Answers
mxcaltrz
  • 20 Answers
SOURCE: car is NOT starting. Lights are not
is the car starting using the key? (manually), if so, then replace the remote battery, if problem still persists, then check the remote & the car's receiver...
or
the car's battery or some controller might be out-of-service!
new cars are electronically controlled, if any problem occurs, it jams the whole car,  perhaps this might be your case.. For your Safety: it is recommended to ask help from Honda Service Centre!!
Posted on Apr 24, 2009
  • 3197 Answers
SOURCE: door dosent close.move about 1 ft then opens
You may not have had the motor shaft pushed all the way back when you tightened the coupler after replacing the worm gear. Loosen the coupler up and from the front of the motor (opposite end in which the coupler is on) push the shaft back as far as it will go. Hold it there while you tighten the coupler back up and then try it.
Posted on Jul 24, 2009
  • 118 Answers
SOURCE: liftmaster garage door opener not working
Your safety eyes need to be properly aligned. Make sure they are clean and pointing directly at each other
Posted on Oct 18, 2009
  • 3197 Answers
SOURCE: I have a 1265-267 opener and I accidentally
On the rear of the motor unit near where all those white wires go you will find the smart/learn button. Press and hold the button on your clicker while you press and immediately release the smart/learn button. Should do the trick.
Posted on Dec 31, 2009
With my door closed, i push door button to open and the chain and opener continues inthe closing mode. any help?
Shop for sears craftsman liftmaste... on Google
Garage Door Opener Gear...
$31.45
Sears Parts D... Liftmaster 41C4220A Ge...
$21.75
Preferred Do... Chamberlain/l... Sprocket, Gea...
$17.95
eBay Direct Replacement f...
$20.95
Moving Up G... Liftmaster 41c4220a gea...
$31.67
North Shore... Search Results
    Liftmaster Gear And Sprocket Kit 41c4220a Chamberlain ...
    www.sears.com/search=liftmaster%20gear%20and%20sprocket%20...
    Searsmore info. + -. Chamberlain LiftMaster 41C4220A Gear & Sprocket Assembly Kit. $31.40 ... Chamberlain Sears Craftsman Liftmaster 41A2817 Gear Kit. $27.65 ...
Jan 10, 2016 | Sears Craftsman LiftMaster Chamberlain...
Motor is running but the chain is not moving. When I assist it moves a few inches then stops again....in both directions. Almost as if teeth are boken in a wheel.
You are correct. There is a gear drive system and the gear is stripped. you can have the gear replaced and not have to purchase a new lift.
May 17, 2011 | liftmaster Garage Door 1/2 Hp
My 20 yr. old Craftsman 1/2HP chain drive GDO (139.18590) will click and hum for a second but the door doesn't move when I press a remote or wall console. The door moves freely manually and I checked the...
If your door is stuck in the open position the trolley is most likely jammed against the bolt just in front of the motor unit. You should be able to loosen the chain enough that it releases the pressure on the trolley and then close the door. While the door is closed, locate the 'up limit' control which is on the side of the motor unit. Turn this control 2 full turns in the opposite direction of the arrow printed on the cover and then tighten the chain.
Feb 21, 2010 | Sears Craftsman LiftMaster Chamberlain...
Garage door does not open or close
You have a stripped drive gear. Remove the cover from the motor unit and you will find white sawdust all over. The part number for the gear kit is 41A2817 and is available at any good door opener service company. It comes with instructions.
Feb 12, 2010 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster door opener, motor hums but chain and door does not move. Any ideas? Thanks
If the motor is running but the chain isn't moving you have a stripped drive gear. Remove the cover from the motor unit and check. It should be obvious.
Jan 08, 2010 | Sears Craftsman LiftMaster Chamberlain...
Garage door chain isnt engaged. motor is running
SOUNDS LIKE A BAD GEAR KIT
IF THE CHAIN MOVES BUT THE DOOR DOESN'T IT WOULD BE THE TROLLEY RELEASE. IF THE CHAIN DOESN'T MOVE IT WOULD BE THE GEAR KIT.
HOPE THIS HELPS
Jan 03, 2010 | liftmaster Chamberlain Garage Door Opener...
Motor run chain not moving when i hit hardwired stop and start button
You need to check the drive gear. Remove the cover and it is a white nylon gear just in front of the motor. Most likely stripped. The part number is 41A2817 and is available from Sears or any good door opener service company. It comes with instructions.
Jun 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
Motor sounds like it is running but sprocket doesnt move
how old is unit. sounds like gears are shot, takes $25 of parts and 2-3 hours to fix if you are handy. Take cover off, If it has white powder (Not ****), gears are shot.
Jan 14, 2009 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster 1265LM 1/2 HP does not open or close with remotes
is chain moving. if not, gears are shot. if moving, is trolley connected.
Dec 10, 2008 | Sears Craftsman LiftMaster Chamberlain...
Craftsman garage door opener
you can order a new gear kit from amazon for $20. It's and easy fix.
Dec 12, 2007 | Sears Craftsman LiftMaster Chamberlain...
Home Security Logo
80 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
